B04 TOOLING APPLICATIONS WITH EOSINT M
2011-12-20 16:21| 查看: 45399| 评论: 0|来自: 产学联盟
摘要: EOSINT M systems manufacture solid metal parts by locally melting and resolidifying metal powder using a focussed laser beam, layer by layer, to build up the desired geometry fully automatically fro ...
4. Materials and building strategies
A variety of different metal materials are available for EOSINT M machines, and new
materials are continuously being developed [4]. The most relevant material for series
production tooling is a high-grade 18 Maraging 300 type steel (1.2709, X3NiCoMoTi18-9-5)
which is marketed in powder form under the name EOS MaragingSteel MS1. This material is
fully melted in the EOSINT M machine to produce fully dense parts with a hardness of 36 –
39 HRC as built, which can be easily post-hardened (6 hours at 490°C) to increase the
hardness up to 53 – 55 HRC and produce an ultimate tensile strength of more than 1900
MPa. Tool components built in this material can be machined, eroded, polished etc. in a
similar way to conventional tool steel materials. The middle and right examples of Figure 7
were built in EOS MaragingSteel MS1. In cases where lower strength and hardness are
sufficient, often the material of choice for DirectTool is a proprietary bronze-nickel based
alloy material called DirectMetal 20. This material has the advantage that it is very quick
and easy both to build and to finish, and is therefore very popular for prototype tooling and
low-volume production tooling. The high build speed is achieved partly by using processing
parameters (laser scan speed etc.) which produce a partially porous structure inside the
parts, whilst the outer surface region is built with higher density. The projects shown in
Figure 1 through Figure 3 and Figure 6 were produced using this material. Other DMLS
materials may also be useful for DirectTool applications in some cases, for example stainless
steel materials are available which can be beneficial for moulding corrosive plastics. EOSINT
M systems build parts on top of a metal plate called a build platform. When building mould
cavities, the platform is typically integrated into the cavity design so that the DMLS
geometry is melted directly onto the platform. Figure 8 (a) shows how multiple tool inserts
can be built on one platform (these are components for the tool shown in Figure 6(b)). The
individual inserts are cut out, typically by sawing or wire cutting, to produce inserts or
onserts like those shown in Figure 1 and Figure 2. In cases where it is not convenient to
integrate the platform, for example loose inserts or cooling pins, these are built on a support
structure which attaches the DMLS geometry to the platform, and which is removed after
building.
An example is shown in Figure 8 (b), which also shows how long parts (in this case 305 mm)
can be built lying down to save time. Figure 8 (c) shows a case where standardized cooling
pins were being produced as a series product by EOSINT M. Here the most efficient and
cost-effective method was to build large numbers of pins standing up – in this case 200 pins
fitted on one half of a build platform and could be produced fully automatically (unmannedoperation) in just 30 hours. They can be efficiently separated from the build platform by wire
cutting.
Aligning parts for post-machining can often be simply done using for example the side walls
of the insert or other regular geometries. However, in more complex cases or where similar
post-machining is often repeated, it can be beneficial to use a clamping and positioning
system to save time.
Such a system based on the widely used Erowa Powerchuck 150 system is available as a
commercial option for EOSINT M systems (see Figure 9), which is particularly relevant for
users who have this system on other machining stations. But various other solutions have
also been implemented, according to requirements and wishes of particular users. The
process software of the EOSINT M system includes a feature to enable easy alignment of the
machine coordinate system to any suitable mechanical reference.
5. Summary
The examples presented above are just a small selection from the very wide range of tooling
applications which have already been published by EOSINT M users. Other documented
tooling applications include for example vulcanization, wax injection for casting patterns,
extrusion, thermofoam moulding, die casting, thixomoulding, sheet metal forming and
stamping, glass forging and paper injection moulding. Also many other applications and
methods of applying the technology can be considered. With the expansion in recent years
from Rapid Tooling into series production tooling and advanced tooling, DMLS has
established itself as a very versatile production method to complement traditional methods
like CNC machining and EDM. Its ability to produce a wide range of geometries, including
extremely intricate forms which are difficult to produce conventionally, rapidly and with
very low effort, gives it unique advantages which have been driving the increase in the
usage and acceptance of DirectTool.
References
[1] F. Choblet, B. Le Razer: DMLS activities at PEP – France tooling applications. In: EOS
International User Meeting, Fuschlsee, 14-16th May, 2007.
[2] R. Mayer: Lasergenerativ hergestellte Großserienwerkzeuge aus MS1. In: EOS
[3] J. Tenbusch: EOS Metal Technology and Rapid Tooling. In: EOS International User
[4] M. Shellabear, O. Nyrhilä: Advances in materials and properties of direct metal
laser-sintered parts. In: 5th LANE, 25-28th September, 2007, Erlangen.
About the authors
Dr. Mike Shellabear graduated in mechanical engineering at Loughborough University of
Technology, England, where he also gained his Ph.D in vibration analysis
using laser interferometry. In 1991 he joined EOS, Germany, as
Engineering Manager for 3D Optical Metrology, later taking over
responsibility as Market DevelOPMent Manager and then Assistant to the
Management Board. Following that, he was appointed Product Manager
for the Direct Metal Laser Sintering (DMLS) technology and became its
Vice President in 2006. He has more than 15 years of experience in the
Rapid Prototyping & Manufacturing industry.
Joseph Weilhammer, studied mechanical engineering at Technische Universität München,
Germany, where he did his diploma thesis about post-processing
methods for DMLS tools and parts for EOS GmbH. In 1996 he joined
EOS and worked there in the development department for Metal-Laser-
Sintering. Then he changed to Application department and in 2007 he
became Product Manager for the Direct Metal Laser Sintering (DMLS)
technology. He has more than 12 years of experience in the Rapid
123
GMT+8, 2024-5-19 15:05 , Processed in 0.015342 second(s), 11 queries , Gzip On, Redis On.
