Stratasys汽车案例研究 Minimizer
2013-11-22 14:20| 查看: 27195| 评论: 0|原作者: Stratasys|来自: Stratasys
摘要: 汽车案例研究 原型制作是制造卓越汽车的强大推动力 汽车巨头 BMW 和 Jaguar Land Rover,以及 Minimizer 等精密零配件供应商,都发现 3D 打印是加速汽车设计和制造的最佳方式。
Minimizer
If necessity is the mother of invention, sometimes destruction is its father. This was the case with the tough-as-nails semi-truck fenders that Minimizer designs and manufactures in its Blooming Prairie, Minnesota, facility. The idea for these thick-gauge polyethylene fenders came from a pair of accidents: An errant forklift dented Dick Kruckeberg’s metal semi fender and, later, Dick’s wife flattened a plastic garbage can with her car. The metal fender was ruined; the garbage can popped right back into shape. Three generations of Kruckebergs have been designing and manufacturing flexible, durable, lightweight polyethylene fenders ever since.
Minimizer prides itself on constantly improving products and incorporating customer feedback. The latest challenge is to enter the growing market of truck owners using fuel-efficient super-single tires. On these rigs, one wide tire on each side takes the place of two narrow ones. This lighter-weight configuration allows drivers to haul more payload and reduces rolling resistance so trucks go farther on less fuel, according to Minimizer mechanical engineer Martin Larsen.
Black ULTEM mounting assembly prototype for semi truck fender
Making narrower fenders and the bracket assemblies that go with them means creating all-new tooling — a big investment. It’s crucial for Larsen to get the designs right before committing to tooling, so functional prototyping is essential. And in Minimizer’s trademark rugged testing environment, Fused Deposition Modeling (FDM) is the only 3D printing technology up to the task. Its real engineering thermoplastics include ULTEM 9085, the all-around toughest rapid-prototyping material in terms of mechanical strength and resistance to heat and chemicals.
With Minimizer’s onsite Fortus 3D Production System, Larsen can build functional prototypes in just hours or, for large parts, days. And now that Stratasys offers ULTEM in black, those parts are right at home on the shop floor, masking grease and fingerprints and taking abuse with no painted finish to scuff and scratch.
In the truck bay outside his office, Larsen drills into a black FDM prototype of the super-single fender he’s developing and bolts it to a truck with its bracket assembly (also an FDM prototype) to verify alignment and clearance. “I look at it in CAD, but it’s hard to be sure until you get the prototype on the truck and make sure it’s the form you want,” he says. On a dirt road nearby, the FDM part holds up to a dusty ride, with gravel flying.
FDM semi fender prototype in black ULTEM
The material’s new black color also offers Minimizer the chance to make concept models look more like production parts. “About 90 percent of our products are black in this industry,” says Minimizer CEO Craig Kruckeberg. Black ULTEM models look like the real thing right out of the build chamber, which is helpful for a business that’s constantly trying out new ideas.
“As trucks change, we need to change. People are always coming to us for new products,” Kruckeberg says. Now that its fenders are indestructible, it is customer needs that drive Minimizer to keep inventing.
- See more at: //www.stratasys.com.cn/resources/case-studies/automotive/minimizer#sthash.AeslhKbF.dpuf
GMT+8, 2025-4-26 05:09 , Processed in 0.029279 second(s), 11 queries , Gzip On, Redis On.
