在NX中,我们可以在图形窗口中,通过按住鼠标右键的方法调出挤出菜单 Quick View Popup menu ,默认情况下该菜单包含下面功能: 当然我们可以对这个挤出菜单中包含的命令进行定制.下面我们就会通过一个例子讲解定制的方法。 在这个例子中,我们要把原来的Studio 和 Face Analysis 命令替换为 Measure 和 Add Component. 修改Menu 文件 到UGII_BASE_DIRugiimenus 目录中查找到文件ug_view_popup.men 首先我们要删除Studio 和 Face Analysis.这两个命令 他们的内容如下: BUTTON UG_VIEW_POPUP_STUDIO LABEL S&tudio MESSAGE Renders faces (in the view where the cursor is positioned) realistically according to assigned basic materials, textures, and lights. BITMAP image_on_sphere.bmp POPUP_LABEL S&tudio POPUP_MESSAGE Renders faces (in the view where the cursor is positioned) realistically according to assigned basic materials, textures, and lights. POPUP_LOCATION 1 ACTIONS STANDARD. BUTTON UG_VIEW_POPUP_FACE_ANALYSIS LABEL &Face Analysis MESSAGE Renders Face Analysis faces (in the view where the cursor is positioned) with surface analysis data, and remaining faces by edge geometry. BITMAP face_analysis_display.bmp POPUP_LABEL &Face Analysis 11POPUP_MESSAGE Renders Face Analysis faces (in the view where the cursor is positioned) with surface analysis data, and remaining faces by edge geometry. POPUP_LOCATION 5 ACTIONS STANDARD 然后我们增加新的命令到men文件中: BUTTON UG_VIEW_POPUP_UG_INFO_GEOMETRIC_DISTANCE LABEL Measure MESSAGE Calculates the distance between two objects, the length of curves, the radius of an arc, circular edge, or cylindrical face BITMAP analyze_distance.bmp POPUP_LABEL Measure POPUP_MESSAGE Measure Distance POPUP_LOCATION 1 ACTIONS STANDARD BUTTON UG_VIEW_POPUP_UG_Assy_INSERT_COMPONENT LABEL &Add Component MESSAGE Adds components to the assembly by selecting loaded parts or parts from disk BITMAP comp_insert.bmp POPUP_LABEL Add Component POPUP_MESSAGE Adds new component parts POPUP_LOCATION 5 ACTIONS STANDARD 注意: POPUP_LABEL 的信息将会再鼠标划过对应icon的时候显示. POPUP_MESSAGE 的信息将会在鼠标停止在icon上面显示出来 POPUP_LOCATION 定义了命令显示的对应位置,因为我们的挤出菜单只有第一行和最后以行,所以位置 4 和 8 没有被使用到。 现在重新启动NX,挤出菜单已经按照我们的定制要求显示了。 |
