A11 利用最新模内感测技术监控温度与压力以提升导光板质量
2009-8-19 17:23| 查看: 40780| 评论: 0|来自: 产学联盟
摘要: 利用最新模内感测技术监控温度与压力以提升导光板质量Application of the newest sensor technology in LGP quality improvement by monitoring cavity temperature and pressure parameter林志展、戴仲强Chih-Chan ...
林志展、戴仲强
Chih-Chan Lin, Chung-Ching Dai
新舟科技股份有限公司 Uniplast Tech Co.,Ltd
中文摘要
此案例乃是利用国际知名传感器大厂PRIAMUS模穴感测系统,针对导光板成品质量改善并搭配国内科盛科技公司所研发Moldex3d软件,作为导光板模具开发与成型过程中优化设计与监视模穴内温度、压力的工具,藉由实际使用PRIAMUS模穴感测撷取系统的量测能力,于实际成型时将真实的模内温度与压力情形反映出来,并且对照CAE分析结果探究其模穴内温度分布与整体成型压力历程差异性存在的原因,最后藉以掌握实际模穴内的温度与压力,稳定产品质量、减少调机时间,达到提升生产效益之目的。
英文摘要
This case is the use of internationally renowned manufacturers PRIAMUS cavity sensor sensing system. Light Guide Plate for product quality improvement and with the core tech companies develops Moldex3d software, as a light guide plate mold with molding of optimal design and monitoring cavity temperature pressure. By the use of the PRIAMUS cavity sensor measurement acquisition system to response the true cavity temperature and pressure. Comparison CAE analysis results to discuss reason of difference.Finally to get actual hold of the cavity temperature and pressure to stabilize product quality, reduce adjusting time, to achieve the purpose of enhancing production efficiency.
关键词: Priamus,模内传感器,CAE分析,导光板
PDF文档下载:A11.pdf
Copyright © 2002-2024 www.iCAx.org
