iCAx开思网 首页 行业观点 查看内容
SIEMENS的HD战略?
2011-7-7 15:14| 查看: 40656| 评论: 0|原作者: 咋不乐|来自: 它山的石头
摘要: 这个系列的帖子将涉及到新产品开发,产品策略的改变,以及工程软件公司的收购对工程领域相关人士的影响。新帖子主要针对软件供应商的动向做评论。今天的主题是Siemens PLM的HD 策略,这个帖子包括这个新策略对不同人 ...
What is the Impact of Siemens PLM’s HD Strategy on Decision Support?
SIEMENS的HD战略?
原文 by Chad Jackson
翻译 by 咋不乐
This series of posts will cover new product releases, changes in product strategy and acquisitions by engineering software providers affect engineering stakeholders. New posts in this series will be published based on software provider activities. Today’s post focuses on the relevance of Siemens PLM’s HD strategy for NX and Teamcenter. This post includes a breakdown of the impact of these new offerings on different stakeholders in the engineering organization.
这个系列的帖子将涉及到新产品开发,产品策略的改变,以及工程软件公司的收购对工程领域相关人士的影响。新帖子主要针对软件供应商的动向做评论。今天的主题是Siemens PLM的HD 策略,这个帖子包括这个新策略对不同人员影响的解析。
Dates and Events: Since fall of last year, Siemens PLM (wikipedia entry) has introduced had a series of announcements centered around a new framework called HD-PLM. First, as part of the October 2009 launch of the 7.0 version of NX (wikipedia entry), they released HD3D (HD3D press release). Then, in May of this year, Siemens PLM launched a Visual Reporting offering called HD-PLM (HD-PLM press release) as part of Teamcenter (wikipedia entry). In June of this year, I attended the PLM World event in Dallas and received public and private updates on Siemens PLM’s HD strategy. These announcements from Siemens will be part of an ongoing strategy that will result in the future release of other new capabilities and products.
日期和活动:从去年秋天开始,Siemens PLM (wikipedia entry)开始发布了一系列的声明宣布引入称为“HD-PLM”的框架。首先,09年10月NX7.0发布了一部分NX (wikipedia entry) 的新功能HD3D (HD3D press release).然后于今年的5月份,他们发布了“可视化报告”的功能,被称为HD-PLM(HD-PLM press release).在六月份的时候,我参加了在达拉斯举行的PLM World会议。从中我得到了一些关于Siemens PLM的HD的最新战略。Siemens的最新声明将左右未来产品的发布和动向。
New Capabilities: In short, the HD3D capabilities of NX and Visual Reporting capabilities of Teamcenter provide a means of visually navigating 3D models to access and report on data and information. Stakeholders in either NX or Teamcenter can run visual reports, coloring components or assemblies, based on attributes and status within Teamcenter. Furthermore, these visual reports offer a ‘drill down’ capability to provide more detailed information about the components or assemblies in the visual report. As a result, a user can browse or navigate the product visually instead of textually. The purpose is to support decision making in the develOPMent process. To be clear, these capabilities do not change how NX design and simulation data is managed by Teamcenter. More details on the capabilities of HD3D can be found in their HD3D Fact Sheet. More on HD-PLM can be found at the HD-PLM microsite.
新功能:简而言之,NX中的HD3D和Teamcenter中的可视化报告提供了一种通过浏览3D模型来获取报告和信息的渠道。使用NX和Teamcenter的相关人员可以基于属性和状态来运行可视化报告,为元件和组件标色。可视化报告提供了一种“挖掘”的功能来抓取元器件和组件的详细信息。这样一来,用户就可以通过图来获取产品信息而不是文本。这个东西的目的就是为了支持产品研发中的决策。更进一步来说,这项功能本身不会改变NX设计和仿真。关于HD3D的更多的功能可以浏览HD3D Fact Sheet。更多关于HD-PLM的信息可以访问HD-PLM microsite。
Commentary for Designers and Analysts, some Engineers (CAD and CAE Users): For those that use CAD and CAE applications frequently, most of your interaction with the PLM system is focused on data management activities such as checkin, checkout and managing versions, revisions and configurations. However, you definitely need access to broader product information to support design decisions along the way. How do you get it? Login and textually navigate the PLM system yourself or track down someone that can. And let’s be honest, either way is painful and/or time consuming. The new capabilities in NX provides a means to look for information in the PLM system through an application with which you are familiar, CAD or CAE, in a medium with which you probably most comfortable, 3D design or simulation models. This means you can access what you need without dealing with everything else in the PLM system. However, be aware that setting up a visual report on your model will require some orientation to understand which attributes represent what in your projects. Most PLM systems house many attributes. Make sure what you think an attribute means actually means it.
对设计者和分析师,一些工程师(CAD和CAE用户)
对经常使用CAD和CAE程序的人员来说,大部分于PLM系统的互动都是基于数据管理。比如说checkin,checkout和版本管理,配置管理。但是,你肯定还是需要得到更加广的信息用来支撑产品设计决策。你是如何得到的呢?登入系统后自己浏览PLM的文本或者追踪其他人。老实说,这两类方法要么太痛苦要么消耗时间。NX里面的新功能提供了一种查看PLM信息的新方法。这种新方法依存于用户本身最熟悉的工具,CAD或是CAE。在3D模型内或仿真模型内查看。这也就意味着你可以迅速获得需要的信息而不需要对PLM做额外的操作。但是可视化报告的阅览需要理解属性配置。大部分PLM系统有很多属性,注意其中的属性和你的认知达到一致。
Commentary for Most Engineers (non-CAD users): More so than most stakeholders, engineers need access to a lot of information from different products and different projects. That frequently means you need information that exists in many enterprise systems like ERP, SCM and PLM. That means you often track down individuals from numerous departments to get the information you need, which unfortunately is often outdated by the time you get back to your desk. What does these new capabilities mean for you? It can provide a way for you to get that information directly from the product model, shortcutting some of the ‘trackdown game’ that wastes so much of your time. But there’s a caveats. Using this new approach will be easier but not brainless. Just like many designers and analysts that infrequently use PLM, you’ll need to familiarize yourself with the attributes in the system. Otherwise you’ll be working off the wrong information, which is worse than the ‘trackdown game.’
对大部分工程师(非CAD用户):
相对其他的相关人员来说,工程师需要从不同产品和不同项目中获得更多的信息。这也就意味着从企业级的多个系统(如ERP,SCM和PLM)中提取信息。传统的方式是我们去追踪各个部门的工作人员获取相应信息,但也许当你把信息带回到你的办公桌的时候。信息已经变得过时了。这项新功能对于你来说,到底意味着什么呢?它提供给你直接从CAD模型中获得信息的方法。简化了费时间的“追踪游戏”。但必须注意的是,使用这种新方法会很简单,但是绝不是“毫不费力”。正如很多设计人员和分析人员假如不是常用PLM的话,他必须努力去熟悉各种属性。否则的话,你将会误解手中的信息。
Commentary for Engineering Managers and Executives: How do you, as a manager or executive, get development project summaries today? If you’re like most, you have someone in your team or organization pull together, either manually or with some automation, a report on a daily or weekly basis. It takes time to do. Its a resources dedicated to administrative work, not new development. The information can be difficult to conclusively verify. These new capabilities provide an alternative to that approach. You could run and navigate a 3D visual report on your own, drilling down into particularly problematic areas and defining corrective action as necessary. It would provide access to status in real time. You could dedicate that resource to real development instead of administrative work. However, you will need to be somewhat technology savvy to run and navigate these 3D visual reports as this isn’t just a document you open. Like other stakeholders that may be unfamiliar with the PLM system, you will also need to familiarize yourself with some attributes in the PLM system.
对工程师经理和执行团队来说:
作为经理和执行团队,你将如何得到一些项目的统计状况?像大多数情况一样的话,你会让团队的某一个人手动或自动的收集每天或每周的报告。做这件事情是需要花费时间的(关注在管理层面,而不是开发),但这些信息很难被验证。而这个新功能提供了一个新方法。你可以自己运行并生产一个可视化报告,可以深度挖掘出问题区并及时提供更正的方法。它可以提供实时的状态,这样一来,你就不需要在收集信息上花费太多的功夫而可以关注于研发本身。但是,你需要一些技术功底来运行和浏览3D可视化报告。这并不像是不熟悉PLM系统人员一样打开一个文档,你还是需要自己熟悉一下PLM系统的属性。
Summary: Siemens PLM’s HD strategy provides stakeholders a way to visually access and navigate information in Teamcenter, Siemens’s PLM offering. For stakeholders that are not heavy PLM users and tend to avoid textual navigation of the system, this new framework provides an easier and faster way to get to information yourself. However, to utilize these capabilities, you will need to familiarize yourself with the attributes used in the PLM system and be somewhat technically savvy.
Take care. Talk soon. And thanks for reading.
总结:Siemens PLM中的HD策略提供给相关人员一些可视化工具用于在Teamcenter提取和浏览信息。对相关的非传统的PLM用户来说,他们可以不用通过文本来浏览系统。这个新框架提供了一种简单而又快速的方法得到信息。但是,为了能够充分利用这个功能。你自己必须先熟悉PLM系统内的各个属性,或者说有点技术的背景。
GMT+8, 2025-9-18 13:43 , Processed in 0.032668 second(s), 9 queries , Gzip On, Redis On.
