Hi, experts
I am developing a postprocessor for FANUC 18M ....and got the following problems:
for moom_circular_move, I want to output the "R" instead of "I J", I am using R[$mom_arc_radius], and the output in correct format. but the problem is:
When I am doing a cicular movement whose sweep angle (A) is greater than 180, then the machine will just go along the small arc (360 -A), which will cause serious problem, and hurt the part.
so, in this case, it is better to use R = -$R, using the negative R value.
Then the problem comes: How can i decide the sweep angle is greater or smaller than 180? I can not find a parameter available, and how can I do the calculation?
In CLSF file of IDEAS, we can see the Sweep angle for a circular move, is there a similar one in UG ?
Here is BLOCK:
BLOCK_TEMPLATE circular_move
G_cutcom[$mom_sys_cutcom_code($mom_cutcom_status)]\opt
G_motion[$mom_sys_circle_code($mom_arc_direction)]\opt
G_mode[$mom_sys_output_code($mom_output_mode)]
X[$mom_pos(0)]
Y[$mom_pos(1)]
Z[$mom_pos(2)]
R[$mom_arc_radius]
# I[$mom_pos_arc_center(0) - $mom_prev_pos(0)]
# J[$mom_pos_arc_center(1) - $mom_prev_pos(1)]
# K[$mom_pos_arc_center(2) - $mom_prev_pos(2)]
F[$feed]
# S[$mom_spindle_speed]
I am so worrying about this problem, Please advise as soon as possible!
Thanks and have a nice day!
Best regards |
