查看: 18593|回复: 13
working with program files,二次开发的资料
发表于 2004-4-10 10:16:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
英文版的,我看了,但看的不是很明白,如果有此经验的人,希望能上来交流一下。
发表于 2004-4-12 09:09:00 | 只看该作者
各位不要只下载,不回贴,把心得拿出来交流一下吗?
这样才会共同进步呀!
发表于 2004-4-12 10:48:46 | 只看该作者
还没看,先顶
发表于 2004-4-14 09:22:04 | 只看该作者
先看看,IDEAS结构庞大,要自己学习真的困难,希望多交流。
发表于 2004-4-18 17:38:26 | 只看该作者
不懂啊
发表于 2004-4-21 13:14:06 | 只看该作者
yes I have the same ideas , the software is easy to learn but it is too big ,so we need spend  much time only with the itself 's  help and tutorial file  ,I am a new user  too ,I cann't find any good book anyhow in shenzheng or baoan bookshop and mark ,so I suggest if some older  people have used for some years and  some experience about the software ,would  share it to our ? we all looking  toward for you .at the same time i think the chairman need get more information and date about this software , we can see  and get  very very more dates in the other areas of the icax.org ,so we have some responsibility to construct the areas better than others .if we try we should success ! Do you think so ?
发表于 2004-4-25 11:31:45 | 只看该作者
它实际上相当与autocad中的scr文件,可以记录你的绘图过程,当然更有用的是
你自己制作它来用于完成你的绘图工作.
发表于 2004-4-30 16:20:12 | 只看该作者
好象帮助文档有,有关宏程序部分
发表于 2004-5-1 21:10:42 | 只看该作者
先下了,要是能看懂,就上传一点心得.
发表于 2006-3-5 22:30:09 | 只看该作者
下了,很感谢楼主的
我留下了QQ号码楼主可以和我联系,我基本上都看懂了
GMT+8, 2025-4-6 17:35 , Processed in 0.043559 second(s), 12 queries , Gzip On, Redis On.
