野火2.0新功能探索集锦(在此集中)
发表于 2004-7-19 18:26:28 | 只看该作者
2001中tweak的offset在野火中怎样使用
482
发表于 2004-7-21 08:31:24 | 只看该作者
帮助中心左下角有个OTHER LANGAGUE,你只要选者中文,就能看到中文帮助拉,
483
发表于 2004-7-21 08:40:09 | 只看该作者
野火2.0可以直接打开CATIA的文件,可是和打开IGES没有什么区别啊,刚开始我还以为能保留CATIA的特征啊信息呢
484
发表于 2004-7-22 21:12:45 | 只看该作者
请问如何修改安装?
#PTC Pro/Engineer Widefire 2 License File, Generated by ROR Team.
#For EVALUATION only. If you like this software, BUY it!
INCREMENT PROE_200 ptc_d 25.0 01-jan-0 uncounted FDD077D50B7B4D4C58B7 \
  VENDOR_STRING="VSVER=2.0 LO=(0,3,6,7,9,10,14,16,17,19,21,22, \
  23,24,25,26,29,30,31,32,34,35,36,37,40,41,45,47,48,51,52,53, \
  54,55,56,57,59,60,61,62,63,65,66,67,69,71,72,73,74,77,91,92,93,94,97,100,104,106,108,115,116,117,118,119,120,121,122,123,125,126,127,128,131,133,134,135,137,139,140,141,148,155,156,157,158,159,160,161,163,164,167,168,187,188,189,190,191,192,193,194,195,196,197,198,199,200,201,202,203,204,205,206,207,208,209,210,213,214,218,219,220,221)" \
  HOSTID=PTC_HOSTID=00-E0-4C-99-05-82 SUPERSEDE \
  vendor_info="VIVER=2.0 EXTERNAL_NAME=" ISSUER=RORiSO \
  ISSUED=10-APR-2003 NOTICE=ROR SN=88888888 \
  SIGN=AF9EC4188A54B468
INCREMENT NCPOST_200 ptc_d 25.0 01-jan-0 uncounted \
  ED10C79599992E1264D8 VENDOR_STRING="VSVER=2.0 \
  LO=(16,19,21,22,23,30)" HOSTID=PTC_HOSTID=00-E0-4C-99-05-82 \
  SUPERSEDE vendor_info="VIVER=2.0 EXTERNAL_NAME=" ISSUER=RORiSO \
  ISSUED=13-nov-2002 NOTICE=ROR SN=88888888 \
  SIGN=B076E0D2EC6CD5E2
INCREMENT MECINTERFCE_200 ptc_d 25.0 01-jan-0 uncounted \
  AD70F745C63518847428 VENDOR_STRING="VSVER=2.0 LO=(19)" \
  SIGN=13447958E338A6CE
INCREMENT MECSTRUCUI_200 ptc_d 25.0 01-jan-0 uncounted \
  6D0057F5583662414612 VENDOR_STRING="VSVER=2.0 \
  LO=(19,157,159,161)" HOSTID=PTC_HOSTID=00-E0-4C-99-05-82 \
  SIGN=D3825F3CE1FAD0A6
INCREMENT MECSTRUCENG_200 ptc_d 25.0 01-jan-0 uncounted \
  0DB0F70518246CA7CF63 VENDOR_STRING="VSVER=2.0 \
  LO=(19,85,157,161)" HOSTID=PTC_HOSTID=00-E0-4C-99-05-82 \
  SIGN=CB88B2AA074A7336
INCREMENT MECTHERMUI_200 ptc_d 25.0 01-jan-0 uncounted \
  3DB0F7655D484B431298 VENDOR_STRING="VSVER=2.0 LO=(19,159)" \
  SIGN=1A96FF46E0967070
INCREMENT MECTHERMENG_200 ptc_d 25.0 01-jan-0 uncounted \
  B017354ED00F758C70 VENDOR_STRING="VSVER=2.0 LO=(19)" \
  SIGN=7070B36295666956
INCREMENT MECMOTUI_200 ptc_d 25.0 01-jan-0 uncounted \
  3D00770561E4810FC831 VENDOR_STRING="VSVER=2.0 LO=(19,89,159)" \
  SIGN=021EE54A60C06404
INCREMENT MECMOTENG_200 ptc_d 25.0 01-jan-0 uncounted \
  CD609765096077F5544D VENDOR_STRING="VSVER=2.0 LO=(19,79,89)" \
  SIGN=658C31F636DA9414
INCREMENT MECEQRUN_200 ptc_d 25.0 01-jan-0 uncounted \
  AD105735249707944BA5 VENDOR_STRING="VSVER=2.0 LO=(19)" \
  SIGN=E4C27C5C12B82B52
INCREMENT MECTIREMOD_200 ptc_d 25.0 01-jan-0 uncounted \
  4DC0D715DA40F0875042 VENDOR_STRING="VSVER=2.0 LO=(19)" \
  SIGN=0412131E33E869B6
INCREMENT MECUG_200 ptc_d 25.0 01-jan-0 uncounted \
  4D6067F5339E7C1BDF9E VENDOR_STRING="VSVER=2.0 LO=(19)" \
485
发表于 2004-7-24 15:18:28 | 只看该作者
https://www.verycd.com/3.html
大伙一起快快推
486
发表于 2004-7-24 15:19:25 | 只看该作者
PTC.PRO.ENGINEER.WILDFIRE.V2.0
大伙一起快快推
487
发表于 2004-7-24 15:20:46 | 只看该作者
价值数十万元的大型软件,全球最先进、国内最流行的工业模具软件。
新增功能:
通过支持web技术提供前所未有的连通性
windows界面风格加快用户熟悉系统
统一的优化工作流菜单
图标板上有常用的功能并放在易于选择的位置
单击一下馍滑出高级功能菜单
方便易用
大大提高个人效率
在认真听取了代表产品开发周期中不同角色的数百名Pro/ENGINEER资深用户的意见后,我们竭尽全力提高了Pro/ENGINEER WILDFIRE的功能,以简化您们的工作。对功能所做的所有更改都紧紧围绕着两个目标:让新用户通过图标板(Dashboard)来了解工具,让资深用户通过直接建模(Direct Modeling)来加快建模速度。总之,只要您愿意,随时可以在图标板和直接建模之间进行选择。
新!用户界面 - 彻底优化的工作流,能让您迅速熟练操作系统
新!直接建模 - 新的易用的“抓柄”支持实时操作
直接建模
致力于模型,而不是菜单 您希望提高速度吗?直接建模就是最能满足您需求的方法。顾名思义,直接建模的优点就是直接处理模型。没有太多的对话框。因为所有的交互都直接在模型本身上进行,所以使鼠标移动达到最少。
新!图标板 - “智能菜单”让您随手可得最重要的工具
图标板
指导您完成每一步
刚刚接触Pro/ENGINEER吗?或者在尝试一个复杂的新特徵吗?您的选择完全正确。图标板专门用来指导您该去哪里,并告诉您该做什么。您需要的最常用的功能可以随时获得。只要您需要,这些先进功能可以随时通过游动面板获得,否则,它们会隐而不现。
新!即时模型预览 - 即时浏览设计修改
功能特徵
Pro/ENGINEER WILDFIRE提供了最强大的建模功能集...但是,以前它们从来没有如此快捷或者易用。首先,系统对功能进行了改进,使显示几何图形之前的引用达到最少。其次,根据相似性和相继性,把功能合并在一起。最后,特徵之间相容的选项一起实施,以方便识别。
长期保持有源```希望大家支持``!开机时间大约为18:00——08:00
不用学习时也开```!第一次发布资源,请多多关照``!
大伙一起快快推
你们的支持就是我发帖的动力``!谢谢大家```
488
发表于 2004-7-27 16:45:11 | 只看该作者
在config 里加入这么一句,然后重启proe,你会发现在修改模型时,数值字体就不会那么小了。
text_height_factor      35
489
发表于 2004-7-27 16:57:16 | 只看该作者
sz-hx wrote:
为什么在WF2的工程图中,我每次把层隐藏了,但我后来再打开时、层又显示了,请问应该怎样设置才能保存层的状态
  我已经把ignore_model_layer_status设为no了,但在工程图中好像保存不了层的状态,只有在操做层时选PART才能保存层的状态
我也是这样啊!
490
发表于 2004-7-27 19:06:16 | 只看该作者
我頂!
GMT+8, 2025-4-23 15:37 , Processed in 0.027074 second(s), 14 queries , Gzip On, Redis On.
