返回列表 发新帖
【分享】在装配中使用Mechanism Design
发表于 2002-2-16 11:07:58 | 只看该作者
以下内容需要积分高于 0 才可浏览
Although the model is fully assembled now, it is still incomplete.  The Piston Head has a pin connection to the Connecting Rod.  However, as it is assembled the Piston Head is free to flop around rotating about its pin connection with the Connecting Rod. The model needs to be finished by adding another connection such that the Piston Head would move up and down as if it were inside a cylinder.  To do this, a cylinder joint needs to be defined between the Piston Head and Ground which is the Engine Block Bottom in this model.
If you still have the "Component Placement" dialogue box open, you may simply select Add and change the connection type to "cylinder".   Otherwise select Component, Redefine, and pick the Piston Head. Select the Add button and change the type of the new connection to "cylinder".  As shown in Table 1, a cylinder connection only needs an axis alignment constraint. Select the appropriate axes on the Engine Block Bottom and the Piston Head. Select Ok to complete the definition of the cylinder connection.
A "slider" connection would also work in this model.  Figure 9 and 10 show this model with a "slider" connection.  If you use a "cylinder" connection your model will have a "cylinder" connection icon instead.
发表于 2002-2-16 11:09:18 | 只看该作者
以下内容需要积分高于 0 才可浏览
Now the model is fully defined and may be used in Mechanism Design for Kinematic analyses or transferred to Pro/MECHANICA Motion for Dynamic analyses.  However, the assembly may be tested in Mechanism Design much the same way in Pro/MECHANICA an assembly analysis is used to check and see if the model can be put together as defined.  To do this, select Mechanism, Connect,Run.  Mechanism Design will report the results of the run once it is done and will ask you if you would like to accept the assembled configuration.  Select Yes if the assembled configuration looks correct.  Finally, the model will look like Figure 10.
发表于 2002-2-16 11:18:05 | 只看该作者
以下内容需要积分高于 0 才可浏览
完了
发表于 2002-2-16 14:49:24 | 只看该作者
唉,虽然还没有看明白,但知道是个好东东,现收起来!!!
谢谢boby水手!!!
发表于 2002-2-17 10:04:17 | 只看该作者
以下内容需要积分高于 0 才可浏览
If anyone need the exercise parts, please let me know.
reply your email here(Before 23 Feb,2002)
The file is about 1.5M, i can't attach it herexx(
发表于 2002-2-17 23:01:41 | 只看该作者
boby:请给我一份吧! siae@263.net
发表于 2010-6-9 17:32:37 | 只看该作者
sdfda 1# boby asdfasdfa
GMT+8, 2025-7-8 15:17 , Processed in 0.028042 second(s), 10 queries , Gzip On, Redis On.
