返回列表 发新帖
【求助】如何把EMX调入PRO-E里面
发表于 2006-4-17 13:12:30 | 只看该作者
谢谢楼上的个位大哥,小弟又学习了!
发表于 2006-4-17 14:19:10 | 只看该作者
好家伙,
发表于 2006-4-17 18:45:25 | 只看该作者
偶在wildfire2.0上裝上了emx4.0,且圖標也有了,可每次啟動proe時emx都要進行一次注冊,而且emx圖標不能應用,請各位大俠指點一下......
謝謝!
发表于 2006-4-17 19:08:37 | 只看该作者
GOOD!
发表于 2006-5-27 12:21:07 | 只看该作者
顶下 用2楼的方法试了下4.1的也可以
发表于 2006-8-10 10:31:53 | 只看该作者
Installation:
As an extension pack of Pro/E, You should install Pro/ENGINEER WILFRE2.0 or WILDFIRE 3.0 before you install the EMX5.0  F000 extension pack of pro/E and ensure your pro/e license includes the #192 feature< Feature Expert_Moldbase(192)> of pro/e. Of course, prior to rlz lic gen of Pro/e for WILDFIRE2.0 and 3.0 by ZWT includes the feature.
Attention:
   The EMX 5.0 no longer supports lower version of pro/E, the Pro/ENGINEER 2001 and WILFIRE can't run it enven if you have the right lic!
OK, if the above reday, let's go now:
run setup, choose all installation options and the right language which you need and choose an installing location, e.g. c:\ptc\emx5.0 , then Press Next button till finish.
Copy the following file under the installed emx5.0.F000 directory, e.g.:
c:\ptc\emx5.0\text\config.pro
  and paste it into the following installed directory of pro/e:
  e.g. for wildfire 2.0, please paste it into here:
       \proeWildfire 2.0\text
e.g. for wildfire 3.0, please paste it into here:
       \proeWildfire 3.0\text
发表于 2006-8-10 15:48:37 | 只看该作者
18
发表于 2006-8-11 21:09:28 | 只看该作者
是什么东东呀。真想学习一下
19
发表于 2006-8-11 21:12:14 | 只看该作者
是什么东东呀。真想学习一下
GMT+8, 2025-3-11 08:11 , Processed in 0.021006 second(s), 9 queries , Gzip On, Redis On.
