查看: 1200|回复: 0
[转贴] Zero——可穿戴式烟雾过滤器
发表于 2018-3-8 15:51:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
欣赏更多产品设计关注微信公众号:千策良品工业设计
Globally,more than a third ofall people are regularly exposed to the second hand smoke.This exposure is responsible for about 600,000 deaths per year.The U.S.Surgeon General estimates that living with a smoker increases a nonsmoker's chances of developing lung cancer by 20 to 30 percent.However,despite that there is a lot of information which show the risk of death is caused by exposing to the second hand smoke,only few of tobacco addictive people really take action and treat it serious about this issue.
From the research,there are 92% people who smoke believe that they were concerned about the people around them when they were smoking,but only half of them tried to avoid others.Moreover,nearly 70% of smokers confirm that they have smoke indoor.
在全球范围内,超过三分之一的人经常接触二手烟。每年约有60万人死于这种接触。美国卫生局局长估计,与吸烟者生活在一起会使不吸烟者患肺癌的几率增加20%到30%。然而,尽管有大量的信息显示死亡的风险是由二手烟暴露造成的,但只有少数的烟草成瘾者真正采取行动并认真对待这个问题。
研究表明,92%的吸烟者认为自己在吸烟时关心周围的人,但只有一半的人试图避开他人。此外,近70%的吸烟者证实他们在室内吸烟。
Zero is a wearable smoke filter which can filter out the harmful element from smoking in order to reduce the harm from second-hand smoke to the other people.The main feature of this product is it will automatically suck the smoke in and it adjusts most of smoking posture.
Zero是一种可穿戴式烟雾过滤器,它可以过滤掉吸烟有害的元素,从而减少二手烟对其他人的危害。该产品的主要特点是它会自动吸进烟雾,并调整大部分的吸烟姿势。
How Does It Work ?
Firstly,the smoke will be sucked in by fans automatically,and then be fltered through by crushing activated carbon pack.Most of harmful smoke particles will be attached and trapped by chemical attraction.Eventually,clean air out.
它是如何工作的?
首先,烟雾会自动被风扇吸进去,然后被压碎的活性炭块压碎。大多数有害的烟雾颗粒将被吸附并被化学吸引所困。最终,清洁空气。
Design for User
The electronic lighter is added in order to let cigarette get closed to Zero all the time whenever cigarette is lighten on.From the previous research,user's hand tends to away from the cigarette when they are going to put the lighter back to their pocket.The electric lighter will only have function when Zero is turned on,in order to guide users to turn on the smoke filter frst before smoking.
为用户设计
电子打火机是为了让香烟在点亮的时候被关闭到Zero。在之前的研究中,当用户把打火机放回口袋时,他们的手往往会远离香烟。电动打火机只有在开启Zero点时才会有功能,以便引导用户在吸烟前打开烟雾滤清器。
Design for User
The process of using Zero smoke filter is user centred.As the story board llustrates,from the start to the end,the cigarette is always close to the product in order to absorb the smoke from not only mainstream smoke which is directly inhale and exhale through the mouth but also sidestream which comes from the burning tip of the cigarettes and is 4 time more toxic than the mainstream.The electronic lighter is added in order to let cigarette get closed to Zero all the time whenever cigarette is lighten on.From the previous research,user's hand tends to away from the cigarette when they are going to put the cigarette back to their pocket.
为用户设计
使用无烟滤清器的过程是以用户为中心的。阐明了故事板,从一开始到最后,烟总是接近产品为了吸收烟雾不仅主流烟直接通过口腔吸入和呼出但也侧流烟来自燃烧的香烟和4次比主流有毒。电子打火机是为了让香烟在点亮的时候被关闭到Zero。在之前的研究中,用户的手倾向于远离香烟。
Design for User
Zero is deign for install on the ittle finger,so it will not affect most of actives which need to use fingers.Thumb,index finger and middle finger are mostly used for most of activities.
为用户设计
Zero是安装在ittle手指上的,所以它不会影响大多数需要使用手指的活动。拇指、食指和中指大部分用于活动。
GMT+8, 2025-9-18 12:23 , Processed in 0.029417 second(s), 11 queries , Gzip On, Redis On.
