返回列表 发新帖
怎样建立各种水口和流道
发表于 2004-8-11 10:55:00 | 只看该作者
Robertshan wrote:
  请教suilee  , 我在 PROE中 建了 水路  ,怎样才能引进 MPI  !
水路必须在MPI里来建。否则MPI不会识别出来的。你可以导入曲线,在MPI里定义好属性和产品一起MESH。
发表于 2004-8-11 11:56:29 | 只看该作者
谢谢版主指教, 可是我用曲线生成了水管,但 冷却入口 (Coolant inlet) ,定义不了,不知为什么?
发表于 2004-8-11 14:31:02 | 只看该作者
是不是你那里有多余的节点导致你选不中水管端部的节点啊?用MESH TOOLS里面的Purge Node命令清理一下多余的节点。再试一下。不可能定义不了的。
发表于 2004-8-11 15:05:45 | 只看该作者
我做起来了,
  谢谢版主,我 感觉你挺有责任心的,永远支持你和你的moldflow!
发表于 2004-8-12 19:00:58 | 只看该作者
Robertshan wrote:
我做起来了,
深有同感!
发表于 2004-8-13 14:20:36 | 只看该作者
虽然冷却液入口形成了,但进行冷却分析时还会出错,我找不到什么地方可以定义冷却液出口的!
错误提示如下:
“** ERROR 701875 ** Cannot find an outlet node for the circuit with inlet node   35011
                   The outlet element could possibly be overlapping an identical
                   element
** ERROR 701870 ** The coolant inlet node   35011  is connected to more than one element
** ERROR 701871 ** The circuit outlet node       1  is connected to more than one element
** ERROR 701875 ** Cannot find an outlet node for the circuit with inlet node   35339
                   element
** ERROR 701870 ** The coolant inlet node   35339  is connected to more than one element
** ERROR 701875 ** Cannot find an outlet node for the circuit with inlet node   35869
                   element
** ERROR 701870 ** The coolant inlet node   35869  is connected to more than one element
** ERROR 701875 ** Cannot find an outlet node for the circuit with inlet node   36106
                   element
** ERROR 701870 ** The coolant inlet node   36106  is connected to more than one element
** ERROR 701875 ** Cannot find an outlet node for the circuit with inlet node   35144
                   element
** ERROR 701870 ** The coolant inlet node   35144  is connected to more than one element
** ERROR 701875 ** Cannot find an outlet node for the circuit with inlet node   35010
                   element
** ERROR 701870 ** The coolant inlet node   35010  is connected to more than one element
** ERROR 701875 ** Cannot find an outlet node for the circuit with inlet node   35449
                   element
** ERROR 701870 ** The coolant inlet node   35449  is connected to more than one element
** ERROR 701875 ** Cannot find an outlet node for the circuit with inlet node   36482
                   element
** ERROR 701870 ** The coolant inlet node   36482  is connected to more than one element
分析检查发现 24 个错误和 0 个警告”
发表于 2004-8-13 16:32:30 | 只看该作者
十有八九是你的单元重叠或是曲线重叠了。
18
发表于 2004-8-14 16:23:30 | 只看该作者
Suni Lee wrote:
十有八九是你的单元重叠或是曲线重叠了。
好像没有重叠,我先把水路曲线拷进来,然后付给它属性和入水点,然后生成网格, 版主,是不是 还需要定义什么来着!
错误提示:
Reading nodal data...
Reading beam element data...
Reading triangular element data...
** ERROR 701875 ** Cannot find an outlet node for the circuit with inlet node   35404
                   element
** ERROR 701870 ** The coolant inlet node   35404  is connected to more than one element
** ERROR 701875 ** Cannot find an outlet node for the circuit with inlet node   35669
                   element
** ERROR 701870 ** The coolant inlet node   35669  is connected to more than one element
** ERROR 701875 ** Cannot find an outlet node for the circuit with inlet node   35074
                   element
等等
发表于 2004-8-21 10:07:30 | 只看该作者
没人知道吗?
GMT+8, 2025-4-27 16:29 , Processed in 0.023552 second(s), 10 queries , Gzip On, Redis On.
