双11·3D打印优惠活动
返回列表 发新帖
Re: 求助法兰克系统的后处理文件的修改
发表于 2004-10-25 16:56:52 | 只看该作者
 我这里有我改好的,你试试看,# Post Name           : MPFAN
# Product             : MILL
# Machine Name        : GENERIC FANUC
# Control Name        : GENERIC FANUC
# Description         : GENERIC FANUC MILL POST
# Associated Post     : NONE
# Mill/Turn           : NO
# 4-axis/Axis subs.   : YES
# 5-axis              : NO
# Subprograms         : YES
# Executable          : MP v9.0
# WARNING: THIS POST IS GENERIC AND IS INTENDED FOR MODIFICATION TO
# THE MACHINE TOOL REQUIREMENTS AND PERSONAL PREFERENCE.
# Revision log:
# Programmers Note:
# CNC 01/12/01  -  Initial post update for V8.1, grt
# CNC 07/02/01  -  Add cantext to cancel drill and tool retract, jph
# CNC 01/09/02  -  Initial post update for V9.0, rjm
# CNC 01/31/02  -  Set usecandrill, usecanpeck, force_wcs to YES, rjm
# CNC 02/22/02  -  Forces output of I,J,K arc centers (arcoutput:0), rjm
# CNC 04/12/02  -  Use original position for inverse feed and 4 ax paths, jph
# CNC 05/01/02  -  Set "helix_arc:2", support helix arc output in XY plane, rjm
# CNC 05/07/02  -  Do not update sav_rev with axis substitution, jph
# Features:
# This post supports Generic Fanuc code output for 3 and 4 axis milling.
# It is designed to support the features of Mastercam Mill V8.
# Following Misc. Integers are used:
# mi1 - Work coordinate system
#        0 = Reference return is generated and G92 with the
#            X, Y and Z home positions at file head.
#        1 = Reference return is generated and G92 with the
#            X, Y and Z home positions at each tool.
#        2 = WCS of G54, G55.... based on Mastercam settings.
# mi2 - Absolute or Incremental positioning at top level
#        0 = absolute
#        1 = incremental
# mi3 - Select G28 or G30 reference point return.
#        0 = G28, 1 = G30
#Canned text:
#    Entering cantext on a contour point from within Mastercam allows the
#    following functions to enable/disable.
#    Cantext value:
#    1 = Stop = output the "M00" stop code
#    2 = Ostop =  output the "M01" optional stop code
#    3 = Bld on = turn on block delete codes in NC lines
#    4 = bLd off = turn off block delete codes in NC lines
#Milling toolpaths (4 axis)
#Layout:
# The term "Reference View" refers to the coordinate system associated
# with the Top view (Alt-F9, the upper gnomon of the three displayed).
# Create the part drawing with the axis of rotation about the axis
# of the "Reference View" according to the setting you entered for
# 'vmc' (vertical or horizontal) and 'rot_on_x' (machine relative
# axis of rotation).
# vmc = 1 (vertical machine) uses the top toolplane as the base machine
# view.
# vmc = 0 (horizontal machine) uses the front toolplane as the base machine
# view.
# Relative to the machine matrix -
# Rotation zero position is on the Z axis for rotation on X axis.
# Rotation zero position is on the Z axis for rotation on Y axis.
# Rotation zero position is on the X axis for rotation on Z axis.
# The machine view rotated about the selected axis as a "single axis
# rotation" are the only legal views for 4 axis milling.  Rotation
# direction around the part is positive in the CCW direction when
# viewed from the plus direction of the rotating axis.  Set the variable
# 'rot_ccw_pos' to indicate the signed direction.  Always set the work
# origin at the center of rotation.
#Toolplane Positioning:
# Create the Cplane and Tplane as the rotation of the machine view about
# the selected axis of rotation.  The toolplane is used to calculate
# the position of the rotary axis.  This is the default setting.
#3 Axis Rotary (Polar)
# Polar positioning is offered in Mastercam 3 axis toolpaths through the
# rotary axis options dialog.  The selected toolpath is converted to angle
# and radius position.  The axis of rotation is forced to zero.
#Axis substitution:
# Use the Rotary axis substitution by drawing the geometry flattened
# from the cylinder.  The rotary axis button must be active for axis
# substitution information to be output to the NCI file. The radius of
# the rotary diameter is added to all the Z positions at output.
#Simultaneous 4 Axis (11 gcode):
# Full 4 axis toolpaths can be generated from various toolpaths under the
# 'multi-axis' selection (i.e. Rotary 4 axis). All 5 axis paths are
# converted to 4 axis paths where only the angle about the rotation axis
# is resolved.
#Drill:
# All drill methods are supported in the post.  See Simultaneous 4 Axis.
#Additional Notes:
# 1) Disable 4 axis by setting the numbered question 164. to 'n'.
# 2) G54 calls are generated where the work offset entry of 0 = G54,
#    1 = G55, etc.
# 3) Metric is applied from the NCI met_tool variable.
# 4) Incremental mode calculates motion from home position at toolchanges.
#    The home position is used to define the last position of the tool
#    for all toolchanges.
# 5) The variable 'absinc' is now pre-defined, set mi2 (Misc. Integer) for
#    the 'top level' absolute/incremental program output.  Subprograms are
#    updated through the Mastercam dialog settings for sub-programs.
# 6) Always avoid machining to the center of rotation with rotary axis!
# 7) Transform subprograms are intended for use with G54.. workshifts.
# Debugging and Factory Set Program Switches
m_one       : -1    #Define constant
zero        : 0     #Define constant
one         : 1     #Define constant
two         : 2     #Define constant
three       : 3     #Define constant
four        : 4     #Define constant
five        : 5     #Define constant
c9k         : 9999  #Define constant
fastmode    : yes   #Enable Quick Post Processing, (set to no for debug)
bug1        : 2     #0=No display, 1=Generic list box, 2=Editor
bug2        : 40    #Append postline labels, non-zero is column position?
bug3        : 0     #Append whatline number to each NC line?
bug4        : 1     #Append NCI line number to each NC line?
whatno      : yes   #Do not perform whatline branches? (leave as yes)
get_1004    : 1     #Find gcode 1004 with getnextop?
rpd_typ_v7  : 0     #Use Version 7 style contour flags/processing?
strtool_v7  : 0     #Use Version 7+ toolname?
tlchng_aft  : 2     #Delay call to toolchange until move line
cant_tlchng : 1     #Ignore cantext entry on move with tlchng_aft
newglobal   : 1     #Error checking for global variables
getnextop   : 0     #Build the next variable table
# General Output Settings
sub_level   : 1     #Enable automatic subprogram support
breakarcs   : 2     #Break arcs, 0 = no, 1 = quadrants, 2 = 180deg. max arcs
arcoutput   : 1     #0 = IJK, 1 = R no sign, 2 = R signed neg. over 180
arctype     : 2     #Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc.
do_full_arc : 0     #Allow full circle output? 0=no, 1=yes
helix_arc   : 2     #Support helix arc output, 0=no, 1=all planes, 2=XY plane only
arccheck    : 3     #Check for small arcs, convert to linear
atol        : .01   #Angularity tolerance for arccheck = 2
ltol        : .002  #Length tolerance for arccheck = 1
vtol        : .0001 #System tolerance
maxfeedpm   : 500   #Limit for feed in inch/min
ltol_m      : .05   #Length tolerance for arccheck = 1, metric
vtol_m      : .0025 #System tolerance, metric
maxfeedpm_m : 10000 #Limit for feed in mm/min
force_wcs   : yes   #Force WCS output at every toolchange?
spaces      : 0     #Number of spaces to add between fields
omitseq     : no    #Omit sequence numbers?
seqmax      : 9999  #Max. sequence number
stagetool   : 0     #0 = Do not pre-stage tools, 1 = Stage tools
use_gear    : 0     #Output gear selection code, 0=no, 1=no
max_speed   : 10000 #Maximum spindle speed
min_speed   : 50    #Minimum spindle speed
nobrk       : no    #Omit breakup of x, y & z rapid moves
progname    : 1     #Use uppercase for program name (sprogname)
# Rotary Axis Settings
vmc         : 1     #0 = Horizontal Machine, 1 = Vertical Mill
rot_on_x    : 1     #Default Rotary Axis Orientation, See ques. 164.
                    #0 = Off, 1 = About X, 2 = About Y, 3 = About Z
rot_ccw_pos : 1     #Axis signed dir, 0 = CW positive, 1 = CCW positive
index       : 0     #Use index positioning, 0 = Full Rotary, 1 = Index only
ctable      : 5     #Degrees for each index step with indexing spindle
use_frinv   : 0     #Use Inverse Time Feedrates in 4 Axis, (0 = no, 1 = yes )
maxfrdeg    : 2000  #Limit for feed in deg/min
maxfrinv    : 999.99#Limit for feed inverse time
frc_cinit   : 1     #Force C axis reset at toolchange
ctol        : 225   #Tolerance in deg. before rev flag changes
ixtol       : .01   #Tolerance in deg. for index error
frdegstp    : 10    #Step limit for rotary feed in deg/min
# Enable Canned Drill Cycle Switches
usecandrill : yes   #Use canned cycle for drill
usecanpeck  : yes   #Use canned cycle for Peck
usecanchip  : yes   #Use canned cycle for Chip Break
usecantap   : yes   #Use canned cycle for Tap
usecanbore1 : yes   #Use canned cycle for Bore1
usecanbore2 : yes   #Use canned cycle for Bore2
usecanmisc1 : yes   #Use canned cycle for Misc1
usecanmisc2 : yes   #Use canned cycle for Misc2
# Common User-defined Variable Initializations (not switches!)
xia         : 0     #Formated absolute value for X incremental calculations
yia         : 0     #Formated absolute value for Y incremental calculations
zia         : 0     #Formated absolute value for Z incremental calculations
cia         : 0     #Formated absolute value for C incremental calculations
cuttype     : 0     #Cut type flag
                    #0 = Tool Plane, 1 = Axis Subs,  2 = Polar, 3 = 4/5 axis
bld         : 0     #Block delete active
result      : 0     #Return value for functions
sav_spc     : 0     #Save spaces
sav_gcode   : 0     #Gcode saved
sav_absinc  : 0     #Absolute/Incremental Saved Value
sav_coolant : 0     #Coolant saved
sav_frc_wcs : 0     #Force work offset flag saved
toolchng    : 1     #On a toolchange flag
spdir2      : 1     #Copy for safe spindle direction calculation
#Drill variables
drlgsel     : -1    #Drill Select Initialize
drillref    : 0     #Select drill reference
peckacel    : 0     #Fractional percent to reduce peck2 when usecan.. : no
drlgcode    : 0     #Save Gcode in drill
sav_dgcode  : 0     #Drill gcode saved
#Subprogram variables
mr_rt_actv  : 0     #Flag to indicate if G51/G68 is active
                    #0=Off, 1=Toolchange, 2=Subprogram call/start, G68
                    #3=Absolute start, both
rt_csav     : 0     #C saved value
end_sub_mny : 0     #Many tool setting captured at transform sub end
#Rotary/Index variables
prvcabs     : 0     #Saved cabs from pe_inc_calc,
                    #Used for rotary feed and direction calculations
cdelta      : 0     #Calculation for angle change
rev         : 0     #Calculation for deg/min
sav_rev     : 0     #Saved revolution counter
indx_out    : c9k   #Rotation direction calculation
fmt     16  indx_mc #Rotation direction calculation
#Vector Constants for Rotatary Calculations
aaxisx      : 1     #A axis rotation vector constant
aaxisy      : 0     #A axis rotation vector constant
aaxisz      : 0     #A axis rotation vector constant
baxisx      : 0     #B axis rotation vector constant
baxisy      : 1     #B axis rotation vector constant
baxisz      : 0     #B axis rotation vector constant
caxisx      : 0     #C axis rotation vector constant
caxisy      : 0     #C axis rotation vector constant
caxisz      : 1     #C axis rotation vector constant
#Feedrate calculation variables
frdelta     : 0     #Calculation for deg/min
frinv       : 0     #Feedrate inverse time
frdeg       : 0     #Feedrate deg/min actual
prvfrdeg    : 0     #Feedrate deg/min actual
ldelta      : 0     #Calculation for deg/min, linear
cldelta     : 0     #Calculation for deg/min, linear and rotary
circum      : 0     #Calculation for deg/min
ipr_type    : 0     #Feedrate for Rotary, 0 = UPM, 1 = DPM, 2 = Inverse
# Format statements - n=nonmodal, l=leading, t=trailing, i=inc, d=delta
#Default english/metric position format statements
fs2 1   0.7 0.6     #Decimal, absolute, 7 place, default for initialize (
fs2 2   0.4 0.3     #Decimal, absolute, 4/3 place
fs2 3   0.4 0.3d    #Decimal, delta, 4/3 place
#Common format statements
fs2 4   1 0 1 0     #Integer, not leading
fs2 5   2 0 2 0l    #Integer, force two leading
fs2 6   3 0 3 0l    #Integer, force three leading
fs2 7   4 0 4 0l    #Integer, force four leading
fs2 9   0.1 0.1     #Decimal, absolute, 1 place
fs2 10  0.2 0.2     #Decimal, absolute, 2 place
fs2 11  0.3 0.3     #Decimal, absolute, 3 place
fs2 12  0.4 0.4     #Decimal, absolute, 4 place
fs2 13  0.5 0.5     #Decimal, absolute, 5 place
fs2 14  0.3 0.3d    #Decimal, delta, 3 place
fs2 15  0.2 0.1     #Decimal, absolute, 2/1 place
fs2 16  1 0 1 0n    #Integer, forced output
#String and string selector definitions for NC output
#Numbered question 164. string to detect Rotary axis y/n
sq164
#Address string definitions
strm        "M"
strn        "N"
stro        "O"
strp        ""
srad        "R"
srminus     "R-"
sblank
#Cantext string definitions (spaces must be padded here)
sm00        "M00"
sm01        "M01"
strtextno
strcantext
#Transform mirror and rotate codes
strns_mir_on     "G51.1" #Programmable mirror image code
strns_mir_off    "G50.1" #Programmable mirror image cancel code
strns_rot_on     "G68"   #Coordinate System Rotation
strns_rot_off    "G69"   #Coordinate System Rotation Cancel
# Error messages
saxiswarn   "WARNING-POST ROTARY AXIS ASSIGNMENT ('rot_on_x') OVERWRITTEN BY OPERATION"
saxisoff    "ERROR-POST ROTARY AXIS ASSIGNMENT ('rot_on_x') IS DISABLED"
saxiserror  "ERROR-INVALID ROTARY AXIS ASSIGNMENT ('rot_on_x') FOR CURRENT OPERATION"
sindxerror  "WARNING-INDEX ANGLE DOES NOT MATCH POST SETTING ('ctable')"
stlorgerr   "ERROR-TOOL ORIGIN DOES NOT MATCH CENTER OF ROTATION IN POLAR MILLING"
shomeserror "ERROR-G92 WORK OFFSET ('mi1') DOES NOT SUPPORT TRANSFORM SUBPROGRAM"
sprgnerror  "ERROR-SUBPROGRAM NUMBER MATCHES THE MAIN PROGRAM NUMBER"
# General G and M Code String select tables
# Motion G code selection
sg00    G0      #Rapid
sg01    G1      #Linear feed
sg02    G2      #Circular interpolation CW
sg03    G3      #Circular interpolation CCW
sg04    G4      #Dwell
sgcode          #Target for string
fstrsel sg00 gcode sgcode
# Select work plane G code
sg17    G17     #XY plane code
sg19    G19     #YZ plane code
sg18    G18     #XZ plane code
sgplane         #Target string
fstrsel sg17 plane sgplane
#Select english/metric code
sg20    G20     #Inch code
sg21    G21     #Metric code
smetric         #Target string
fstrsel sg20 met_tool smetric
#Select reference return code
sg28    G28     #First reference point return
sg30    G30     #Second reference point return
sg28ref         #Target string
fstrsel sg28 mi3 sg28ref
# Cutter compensation G code selection
scc0    G40     #Cancel cutter compensation
scc1    G41     #Cutter compensation left
scc2    G42     #Cutter compensation right
sccomp          #Target for string
fstrsel scc0 cc_pos sccomp
# Canned drill cycle string select
sg81    G81     #drill      - no dwell
sg81d   G82     #drill      - with dwell
sg83    G83     #peck drill - no dwell
sg83d   G83     #peck drill - with dwell
sg73    G73     #chip break - no dwell
sg73d   G73     #chip break - with dwell
sg84    G84     #tap        - right hand
sg84d   G74     #tap        - left hand
sg85    G85     #bore #1    - no dwell
sg85d   G89     #bore #1    - with dwell
sg86    G86     #bore #2    - no dwell
sg86d   G86     #bore #2    - with dwell
sgm1    G76     #misc #1    - no dwell
sgm1d   G76     #misc #1    - with dwell
sgm2    G81     #misc #2    - no dwell
sgm2d   G82     #misc #2    - with dwell
sgdrill         #Target for string
fstrsel sg81 drlgsel sgdrill
# Select incremental or absolute G code
sg90    G90     #Absolute code
sg91    G91     #Incremental code
sgabsinc        #Target string
fstrsel sg90 absinc sgabsinc
# Feed mode G code selection
sg94    G94     #UPM
sg94d   G94     #DPM, See pfcalc_deg if you use another gcode
sg93    G93     #Inverse
sgfeed          #Target for string
fstrsel sg94 ipr_type sgfeed
#Canned drill cycle reference height
sg98    G98     #Reference at initht
sg99    G99     #Reference at refht
sgdrlref        #Target for string
fstrsel sg98 drillref sgdrlref        # Drill cycle G string select
# Generate string for spindle
sm04    M4      #Spindle reverse
sm05    M5      #Spindle off
sm03    M3      #Spindle forward
spindle         #Target for string
fstrsel sm04 spdir2 spindle
# Coolant M code selection
sm09    M9      #Coolant Off
sm08    M8      #Coolant Flood
sm08_1  M8      #Coolant Mist
sm08_2  M8      #Coolant Tool
scoolant        #Target for string
fstrsel sm09 coolant scoolant
# Table rotation direction
# Table rotation direction, index
sindx_cw   M22   #Rotate CW code
sindx_ccw  M21   #Rotate CCW code
sindx_mc        #Target for string
fstrsel sindx_cw indx_mc sindx_mc
# Define the gear selection code
flktbl  1       3       #Lookup table definition - table no. - no. entries
        40      0       #Low gear range
        41      400     #Med gear range
        42      2250    #Hi gear range
# Toolchange / NC output Variable Formats
fmt  T  4   t           #Tool Number
fmt  T  4   first_tool  #First Tool Used
fmt  T  4   next_tool   #Next Tool Used
fmt  D  4   tloffno     #Diameter Offset Number
fmt  H  4   tlngno      #Length Offset Number
fmt  G  4   g_wcs       #WCS G address
fmt  P  4   p_wcs       #WCS P address
fmt  S  4   speed       #Spindle Speed
fmt  M  4   gear        #Gear range
fmt  N  4   n           #Sequence number
fmt  X  2   xabs        #X position output
fmt  Y  2   yabs        #Y position output
fmt  Z  2   zabs        #Z position output
fmt  X  3   xinc        #X position output
fmt  Y  3   yinc        #Y position output
fmt  Z  3   zinc        #Z position output
fmt  A  11  cabs        #C axis position
fmt  A  14  cinc        #C axis position
fmt  A  4   indx_out    #Index position
fmt  R  14  rt_cinc     #C axis position, G68
fmt  I  3   i           #Arc center description in X
fmt  J  3   j           #Arc center description in Y
fmt  K  3   k           #Arc center description in Z
fmt  R  2   arcrad      #Arc Radius
fmt  F  15  feed        #Feedrate
fmt  P  11  dwell       #Dwell
fmt  M  5   cantext     #Canned text
#Move comment (pound) to output colon with program numbers
fmt  O  7   progno      #Program number
#fmt ":" 7   progno      #Program number
fmt  O  7   main_prg_no #Program number
#fmt ":" 7   main_prg_no #Program number
fmt  O  7   sub_prg_no  #Program number
#fmt ":" 7   sub_prg_no  #Program number
fmt  X  2   sub_trnsx   #Rotation point
fmt  Y  2   sub_trnsy   #Rotation point
fmt  Z  2   sub_trnsz   #Rotation point
fmt  Q  2   peck1       #First peck increment (positive)
fmt  Q  2   shftdrl     #Fine bore tool shift
fmt  R  2   refht_a     #Reference height
fmt  R  2   refht_i     #Reference height
fmt " OFFSET= " 4   toffnote    # Note format
fmt " L= "      4   tlngnote    # Note format
fmt " D= "      1   tldia       # Note format
# Tool Comment / Manual Entry Section
ptoolcomment    #Comment for tool
      toffnote = tloffno
      tlngnote = tlngno
      "(", pstrtool,*tldia,*toffnote, *tlngnote,  ")", e
pstrtool        #Comment for tool
      if strtool <> sblank,
        strtool = ucase(strtool)
        *strtool, " "
pcomment        #Comment from manual entry (must call pcomment2 if booleans)
      pcomment2
pcomment2       #Comment from manual entry
      scomm = ucase (scomm)
      if gcode = 1007, "(", scomm, ")"
      else, "(", scomm, ")", e
# Start of File and Toolchange Setup
psof0           #Start of file for tool zero
      psof
psof            #Start of file for non-zero tool number
      pcuttype
      toolchng = one
      if ntools = one,
        #skip single tool outputs, stagetool must be on
        stagetool = m_one
        !next_tool
      "%", e
      *progno, e
      "(PROGRAM NAME - ", sprogname, ")", e
      "(BIANCHENGREN:chenyilin c_yl7912@163.com)",e
      "(jisuanji:CNC1)",e
      "(DATE=DD-MM-YY - ", date, " TIME=HH:MM - ", time, ")", e
      pbld, n, *smetric, e
      pbld, n, *sgcode, *sgplane, "G40", "G49", "G80", *sgabsinc, e
      sav_absinc = absinc
      if mi1 <= one, #Work coordinate system
        absinc = one
        pfbld, n, sgabsinc, *sg28ref, "Z0.", e
        pfbld, n, *sg28ref, "X0.", "Y0.", e
        pfbld, n, "G92", *xh, *yh, *zh, e
        absinc = sav_absinc
      pcom_moveb
      c_mmlt #Multiple tool subprogram call
      ptoolcomment
      comment
      pcan
      if stagetool < zero, pbld, n, *t, "M6", e
      pindex
      if mi1 > one, absinc = zero
      pcan1, pbld, n, *sgcode, *sgabsinc, pwcs, pfxout, pfyout,
        pfcout, *speed, *spindle, pgear, strcantext, e
      pbld, n, "G43", *tlngno, pfzout, scoolant, next_tool, e
      absinc = sav_absinc
      pcom_movea
      toolchng = zero
      c_msng #Single tool subprogram call
ptlchg0         #Call from NCI null tool change (tool number repeats)
      pcuttype
      pcom_moveb
      comment
      pcan
      pbld, n, sgplane, e
      pspindchng
      pbld, n, scoolant, e
      if mi1 > one & workofs <> prv_workofs,
        sav_absinc = absinc
        absinc = zero
        pbld, n, sgabsinc, pwcs, pfxout, pfyout, pfzout, pfcout, e
        pe_inc_calc
        ps_inc_calc
        absinc = sav_absinc
      if cuttype = zero, ppos_cax_lin
      if gcode = one, plinout
      else, prapidout
      pcom_movea
ptlchg          #Tool change
      pcuttype
      toolchng = one
      if mi1 = one, #Work coordinate system
      pbld, n, "M01", e
      pcom_moveb
      ptoolcomment
      comment
      pcan
      pindex
      sav_absinc = absinc
      absinc = sav_absinc
      pcom_movea
      toolchng = zero
pretract        #End of tool path, toolchange
      sav_absinc = absinc
      absinc = one
      sav_coolant = coolant
      coolant = zero
      #cc_pos is reset in the toolchange here
      cc_pos = zero
      gcode = zero
      pcan
      pbld, n, sccomp, *sm05, psub_end_mny, e
      pcan1, pbld, n, sgabsinc, sgcode, *sg28ref, "Z0.", scoolant, strcantext, e
      pcan2
      absinc = sav_absinc
      coolant = sav_coolant
protretinc      #Reset the C axis revolution counter
      if frc_cinit & rot_on_x,
        rev = zero
        sav_rev = zero
        cabs = zero
        csav = zero
        indx_out = zero
        if index, e, pindxcalc, pindex
        else, *cabs
        prvcabs = zero
        !csav, !cabs
peof0           #End of file for tool zero
      peof
peof            #End of file for non-zero tool
      pretract
      comment
      #Remove pound character to output first tool with staged tools
      #if stagetool = one, pbld, n, *first_tool, e
      n, "M30", e
      mergesub
      clearsub
      mergeaux
      clearaux
      "%", e
pwcs            #G54+ coordinate setting at toolchange
      if mi1 > one,
        sav_frc_wcs = force_wcs
        if sub_level, force_wcs = zero
        if workofs <> prv_workofs | (force_wcs & toolchng),
          if workofs < 6,
            g_wcs = workofs + 54
            *g_wcs
          else,
            p_wcs = workofs - five
            "G54.1", *p_wcs
        force_wcs = sav_frc_wcs
        !workofs
pgear           #Find spindle gear from lookup table
      if use_gear = one,
        gear = frange (one, speed)
        *gear
#Toolchange setup
pspindchng      #Spindle speed change
      if prv_spdir2 <> spdir2 & prv_speed <> zero, pbld, n, *sm05, e
      if prv_speed <> speed | prv_spdir2 <> spdir2,
        if speed, pbld, n, *speed, *spindle, pgear, e
      !speed, !spdir2
pspindle        #Spindle speed calculations for RPM
      speed = abs(ss)
      if maxss = zero | maxss > max_speed, maxss = max_speed
      #zero indicates spindle off (not a mistake)
      if speed,
        if speed > max_speed, speed = maxss
        if speed < min_speed, speed = min_speed
      spdir2 = fsg3(spdir)
pq              #Setup post based on switch settings
      if stagetool = one, bldnxtool = one
      #Rotaxtyp = 1 sets initial matrix to top
      #Rotaxtyp = -2 sets initial matrix to front
      if vmc, rotaxtyp = one
      else, rotaxtyp = -2
      #Shut off rotary axis if, Q164. Enable Rotary Axis button? n
      if ucase(sq164) = strn, rot_on_x = zero
      if arctype = one | arctype = four,
        result = newfs(two, i)
        result = newfs(two, j)
        result = newfs(two, k)
      else,
        result = newfs(three, i)
        result = newfs(three, j)
        result = newfs(three, k)
pheader         #Call before start of file
      if met_tool = one, #Metric constants and variable adjustments
        ltol = ltol_m
        vtol = vtol_m
        maxfeedpm = maxfeedpm_m
ptoolend        #End of tool path, before reading new tool data
      !speed, !spdir2
ptlchg1002      #Call at actual toolchange, end last path here
      if cuttype <> one, sav_rev = rev #Axis Sub does not update to rev
      pspindle
      whatline = four #Required for vector toolpaths
      if gcode = 1000,
        #Null toolchange
      else,
        #Toolchange and Start of file
        if gcode = 1002,
          #Actual toolchange
          pretract
        if stagetool = one, prv_next_tool = m_one
        prv_xia = vequ(xh)
        prv_feed = c9k
# Motion NC output
#The variables for absolute output are xabs, yabs, zabs.
#The variables for incremental output are xinc, yinc, zinc.
prapidout       #Output to NC of linear movement - rapid
      pcan1, pbld, n, sgplane, `sgcode, sgabsinc, pccdia,
        pxout, pyout, pzout, pcout, strcantext, scoolant, e
plinout         #Output to NC of linear movement - feed
      pcan1, pbld, n, sgfeed, sgplane, `sgcode, sgabsinc, pccdia,
        pxout, pyout, pzout, pcout, feed, strcantext, scoolant, e
pcirout         #Output to NC of circular interpolation
      pcan1, pbld, n, `sgfeed, sgplane, sgcode, sgabsinc, pccdia,
        pxout, pyout, pzout, pcout, parc, feed, strcantext, scoolant, e
pcom_moveb      #Common motion preparation routines, before
      pxyzcout
      ps_inc_calc
pncoutput       #Movement output
      pcom_moveb
      comment
      pcan
      if cuttype = zero, ppos_cax_lin #Toolplane rotary positioning
      if gcode = zero, prapidout
      if gcode > one & gcode < four, pcirout
      if mr_rt_actv, #Restore absolute/incremental for G51/G68
        absinc = sav_absinc
        mr_rt_actv = zero
      pcom_movea
pcom_movea      #Common motion preparation routines, after
      pcan2
      pe_inc_calc
pdwl_spd        #Call from NCI gcode 4
      pspindle
      comment
      pspindchng
      pcan
      if fmtrnd(dwell), pcan1, pbld, n, *sgcode, *dwell, strcantext, e
      else, pcan1, pbld, n, strcantext, e
      pcan2
prapid          #Output to NC of linear movement - rapid
      pncoutput
pzrapid         #Output to NC of linear movement - rapid Z only
      pncoutput
plin            #Output to NC of linear movement - feed
      pncoutput
pz              #Output to NC of linear movement - feed Z only
      pncoutput
pmx             #Output to NC of vector NCI
      pncoutput
pcir            #Output to NC of circular interpolation
      pncoutput
#Pre-process rotary motion control flags
pmx0            #5 axis gcode setup
      if drillcur = zero,
        if fr = -2, gcode = zero
        else, gcode = one
plin0           #Linear movement, mill motion test
      pmotion_su
pcir0           #Circular interpolation, mill arc motion test
      pmotion_su
# Motion output components
pbld            #Canned text - block delete
      if bld, '/'
pfbld           #Force - block delete
pccdia          #Cutter Compensation
      #Force Dxx#
      if prv_cc_pos <> cc_pos & cc_pos, prv_tloffno = c9k
      sccomp
      if cc_pos, tloffno
pfxout          #Force X axis output
      if absinc = zero, *xabs, !xinc
      else, *xinc, !xabs
pxout           #X output
      if absinc = zero, xabs, !xinc
      else, xinc, !xabs
pfyout          #Force Y axis output
      if absinc = zero, *yabs, !yinc
      else, *yinc, !yabs
pyout           #Y output
      if absinc = zero, yabs, !yinc
      else, yinc, !yabs
pfzout          #Force Z axis output
      if absinc = zero, *zabs, !zinc
      else, *zinc, !zabs
pzout           #Z output
      if absinc = zero, zabs, !zinc
      else, zinc, !zabs
pfcout          #Force C axis output
      if index = zero & rot_on_x,
        if absinc = zero, *cabs, !cinc
        else, *cinc, !cabs
pcout           #C axis output
        if absinc = zero, cabs, !cinc
        else, cinc, !cabs
pindex          #Index output
      if index & rot_on_x,
        pbld, n, `sindx_mc, indx_out, e
        !cabs, !cinc
parc            #Select the arc output
      if arcoutput = zero | full_arc_flg | arc_pitch,
        #Arc output for IJK
        # If you do NOT want to force out the I,J,K values,
        # remove the "*" asterisks on the *i, *j, *k 's below...
        if plane = zero, *i, *j,  k  #XY plane code - G17
        if plane = one ,  i, *j, *k  #YZ plane code - G19
        if plane = two , *i,  j, *k  #XZ plane code - G18
      else,
        #Arc output for R
        if abs(sweep)<=180 | arcoutput=one, result = nwadrs(srad, arcrad)
        else, result = nwadrs(srminus, arcrad)
        *arcrad
ppos_cax_lin    #Position the rotary axis before move - rapid
      if index, pindex
      else,
        if fmtrnd(prv_cabs) <> fmtrnd(cabs) & rot_on_x,
          sav_gcode = gcode
          gcode = zero
          pbld, n, sgcode, pcout, e
          !cia
          ps_cinc_calc
          gcode = sav_gcode
# Drilling
pdrill0         #Pre-process before drill call
      sav_dgcode = gcode #Capture gcode for 5 axis drill
pdrlcommonb     #Canned Drill Cycle common call, before
      if sav_dgcode = 81,
        result = newfs (two, zinc)
        if drillcyc = three, drlgsel = fsg1(-ss) + drillcyc * two
        else, drlgsel = fsg2(dwell) + drillcyc * two
        if initht <> refht, drillref = zero
        else, drillref = one
        prv_refht_a = c9k
        prv_refht_i = c9k
        prv_dwell = zero
      if cuttype = three, sav_dgcode = gcode
      else, z = depth
      if cuttype = one, prv_zia = initht + (rotdia/two)
      else, prv_zia = initht
      feed = fr_pos
      pcom_moveb
      comment
      pcan
      #5 axis must map the true Z, correct Z calculation here
      if cuttype = three,
        prv_zia = zabs + (-depth) + initht
        zia = fmtrnd(zabs)
        zinc = zia - prv_zia
prdrlout        #R drill position
      if cuttype = one, refht_a = refht + (rotdia / two))
      else, refht_a = refht
      refht_i = refht - initht
      if cuttype = three, refht_a = w
      if absinc = zero, refht_a, !refht_i
      else, refht_i, !refht_a
pdrill          #Canned Drill Cycle
      pdrlcommonb
      pcan1, pbld, n, *sgdrlref, *sgdrill, pxout, pyout, pfzout, pcout,
        prdrlout, dwell, *feed, strcantext, e
      pcom_movea
ppeck           #Canned Peck Drill Cycle
      pdrlcommonb
        prdrlout, *peck1, *feed, strcantext, e
      pcom_movea
pchpbrk         #Canned Chip Break Cycle
      pdrlcommonb
      pcom_movea
ptap            #Canned Tap Cycle
      pdrlcommonb
        prdrlout, *feed, strcantext, e
      pcom_movea
pbore1          #Canned Bore #1 Cycle
      pdrlcommonb
      pcom_movea
pbore2          #Canned Bore #2 Cycle
      pdrlcommonb
      pcom_movea
pmisc1          #Canned Misc #1 Cycle
      pdrlcommonb
        prdrlout, shftdrl, dwell, *feed, strcantext, e
      pcom_movea
pmisc2          #Canned Misc #2 Cycle (User Option)
      pdrill
pdrill_2        #Canned Drill Cycle, additional points
      pdrlcommonb
      pcan1, pbld, n, pxout, pyout, pzout, pcout, prdrlout, dwell,
        feed, strcantext, e
      pcom_movea
ppeck_2         #Canned Peck Drill Cycle
      pdrill_2
pchpbrk_2       #Canned Chip Break Cycle
      pdrill_2
ptap_2          #Canned Tap Cycle
      pdrill_2
pbore1_2        #Canned Bore #1 Cycle
      pdrill_2
pbore2_2        #Canned Bore #2 Cycle
      pdrill_2
pmisc1_2        #Canned Misc #1 Cycle
      pdrill_2
pmisc2_2        #Canned Misc #2 Cycle
      pdrill_2
pdrlcst         #Custom drill cycles 8 - 19 (user option)
      #Use this postblock to customize drilling cycles 8 - 19
      pdrlcommonb
      "CUSTOMIZABLE DRILL CYCLE ", pfxout, pfyout, pfzout, pfcout, e
      pcom_movea
pdrlcst_2       #Custom drill cycles 8 - 19, additional points (user option)
      pdrlcommonb
      pcom_movea
pcanceldc       #Cancel canned drill cycle
      result = newfs (three, zinc)
      z = initht
      pxyzcout
      !zabs, !zinc
      prv_gcode = zero
      pcan
      pcan1, pbld, n, "G80", strcantext, e
      pcan2
#Subprogram postblocks
#sub_trnstyp - 0=mirror, 1=rotate, 2=scale, 3=translate
#sub_trnmthd (mirror) - 0=X axis, 1=Y axis, 2=line
#sub_trnmthd (rotate) - 0=tplane, 1=tplane origin only, 2=coordinates
psub_call_m     #Call to main level, single tool
      psub_call_trans
psub_call_mm    #Call to main level, multiple tools
      psub_call_trans
psub_call_trans #Translate level calls from toolchange, user
      if mi1 <= one, result = mprint(shomeserror)
      sav_absinc = absinc
      pindex
      #Mirror or Rotate Coord's
      if sub_trnstyp = zero | (sub_trnstyp = one & mr_rt_actv),
        #The original pattern is not mirrored or rotated
        if sub_sec_no,
          absinc = zero
          if sub_trnstyp, psub_rotate
          else, psub_mirror
        mr_rt_actv = three
      else, #Translate
        if sub_mny_t,
          pbld, n, *sgcode, *sgabsinc, pwcs, pfxout, pfyout, pfzout,
            pfcout, e
          pe_inc_calc
          ps_inc_calc
      absinc = sav_absinc
      result = nwadrs(strp, main_prg_no)
      if progno = main_prg_no, result = mprint(sprgnerror)
      pbld, n, "M98", *main_prg_no, e
      prv_feed = c9k #Force feed in sub
psub_mirror     #Mirror start code, user
      #Mirror Y axis
      if sub_trnmthd, pbld, n, *sgabsinc, strns_mir_on, *sub_trnsx, e
      #Mirror X axis
      else, pbld, n, *sgabsinc, strns_mir_on, *sub_trnsy, e
psub_rotate     #Rotate start code, user
      pbld, n, *sgcode, *sgabsinc, strns_rot_on, *sub_trnsx, *sub_trnsy,
        [absinc = one], *sgabsinc, *rt_cinc, e
psub_st_m       #Header in main level
      result = nwadrs(stro, main_prg_no)
      " ", e
      *main_prg_no, e
      #G51/G68 requires absolute position on first move
      if mr_rt_actv & absinc = one,
        sav_absinc = absinc
        absinc =
发表于 2004-10-25 18:46:04 | 只看该作者
楼上的后处理钻孔有问题哦。
发表于 2004-10-25 21:21:38 | 只看该作者
lxing00000 哥哥,小弟晚谢了
发表于 2004-10-26 09:24:56 | 只看该作者
“lxing00000 哥哥,小弟晚谢了”
有礼了!
发表于 2004-11-2 23:48:25 | 只看该作者
谢谢拉 正是我需要的,狂顶
发表于 2004-11-3 03:01:54 | 只看该作者
thks
发表于 2019-7-17 15:32:30 | 只看该作者
多谢,辛苦了
GMT+8, 2025-10-21 14:27 , Processed in 0.035478 second(s), 11 queries , Gzip On, Redis On.
