查看: 18655|回复: 6
【求助】idesign请看!
发表于 2002-2-27 07:21:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
你总能搞到se的最新update,我们也能,但附带的介绍改进的readme文件很少见到,你能在这里经常贴出么?
发表于 2002-2-27 10:29:44 | 只看该作者
可以,不过只是介绍。。。
这个是最新的。。。
Legal Notices
Copyright 2002, Unigraphics Solutions Inc.
All rights reserved.
Including software, file formats, and audio-visual displays;
may be used pursuant to applicable software license agreement;
contains confidential and proprietary information of
Unigraphics Solutions Inc. and/or third parties which is protected
by copyright and trade secret law and may not be provided or
otherwise made available without proper authorization.
Restricted Rights Legend
Use duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) (1) (ii) of the
Rights in Technical Data and Computer Software clause at DFARS
252.227-7013 or subparagraphs (c) (1) and (2) of Commercial
Computer Software -- Restricted Rights at 48 CFR 52.227-19, as
applicable.
Unpublished -- rights reserved under the copyright laws of the
United States.
End of Legal Notices
Release Notes:
Product:        Solid Edge
Version:        11.00.01.05
Date:           12-feb-2002
This Update has been verified to operate properly on Windows NT?
/Windows 98?/Windows 2000?/WindowsME?/WindowsXP?operating
systems on both Intel and AMD machines.
Solid Edge V11 Update 1 addresses issues reported by Solid Edge
customers. We appreciate your participation in the software
support process -- your reporting helps us make Solid Edge a more
productive CAD system for the way you do business. Thanks for your
interest in Solid Edge, and for continuing feedback on this Update.
Update 1 should be installed on top of Solid Edge Version 11.00.00.50.
End of Release Notes:
What's New in Version 11.00.01.05 of Solid Edge
Update 1 addresses the following issues:
PR1113274: Fixed a problem with chaining parts list balloons.
PR1122842: Fixed a problem that caused a profile flip in feature copy process.
PR1123101: Fixed a problem updating a part copy of an assembly from V10.
PR1123399: Fixed a problem replacing a subassembly with another subassembly.
PR1124921: Fixed a problem calling methods for thread feature's.
PR1146258: Fixed a problem of missing parts in a drawing view of a weldment.
PR1146338: Fixed a problem where a weldment was not updating correctly
PR1148331: Fixed a problem of filled terminators not exporting to AutoCAD
PR1148891: Fixed a problem with Failed Inter-part copy links after Save As IGES or STEP
PR1149300: Fixed a problem where recalculate causes features to fail
PR1152158: Fixed a crash caused by hatching.
PR2002923: Fixed a problem where changes made to parts in subassemblies are not saved.
PR2002954: Fixed a problem that resulted in several dependent round features to fail.
PR2003100: Fixed a crash using left mouse button at the same time as the right
PR2003831: Fixed a problem in Profile environment after undoing an Included Element.
PR2003896: Fixed a crash deleting a relationship while placing an empty part.
PR2003924: Fixed a problem of not being able to change reference plane names through automation.
PR4338356: Fixed a problem updating drawing views of an assembly.
PR4342625: Fixed a problem with MDS to SE translator converting weld symbols
PR4342630: Fixed a problem with MDS to SE translator not sizing arrow heads properly
PR4347783: Fixed a problem displaying the name of the part being edited.
PR4359467: Fixed a problem placing a drawing view with a configuration file.
PR4361492: Fixed a problem with drawing view update status.
PR4361612: Fixed a problem saving files with extremely long file names.
PR4363628: Fixed a problem with thread information after copy and paste.
PR4364321: Fixed a problem retrieving bend angle of a tube from the BendTable.
PR4364646: Fixed a problem undoing the deletion of a hole within a multi-hole profile
PR4364911: Fixed a problem where RevMan fails with dependant documents
PR4365266: Fixed a reproducable crash using Revise Action in Where Used
PR4365404: Fixed a problem opening a .sat file.
PR4365850: Fixed a problem updating property text when changes are made through Explorer.
PR4394519: Fixed a problem undoing a failed Bead command.
PR4396138: Fixed a crash after inplace active part is saved to another name.
PR4396396: Fixed a crash on application exit after updating snapshot views.
PR4400791: Fixed a problem that prevented drawing views from updating.
PR4401116: Fixed a problem with normal cutout not removing the desired part of the model.
PR4402102: Fixed a problem with Intellisketch when perpendicular option is on.
PR4403611: Fixed a problem where the weld symbol is not holding tail note after edit.
PR4403629: Fixed a problem with insert part copy failing to create a flat pattern.
PR4404357: Fixed a Floating license problem for Insight functionality.
PR4404556: Fixed a problem with Body.GetFaceByFaceID when tolerance value passed in is <>0.
PR4405389: Fixed a problem with hole table tolerance
PR4406323: Fixed a problem with variable table that resulted in Part recomputing several times.
PR4406929: Fixed a problem that prevented some draft files from being saved.
PR4407176: Fixed a problem with fence select in Draft
PR4408212: Fixed a problem displaying Addin menus.
PR4408734: Fixed a problem where assembly pattern does not update correctly
PR4408778: Fixed a problem where parts in section views appear after view update.
PR4409181: Fixed a problem that Find File Dialog does not retain last used settings.
PR4409524: Fixed a crash when deleting holes.
PR4410781: Fixed a problem with text box borders not displaying in TIFF images.
PR4410800: Fixed a problem with drawing view geometry disappearing on view update.
PR4411163: Fixed a problem that resulted in an abort when editing a reference plane
PR4411375: Fixed a crash after trying to open Revision Manager
PR4411677: Fixed a problem where SE aborts when editing Save Settings for a weld symbol.
PR4411712: Fixed a problem that the cannot edit a Weld Symbol once it is placed.
PR4412931: Fixed a problem with a Draft file aborting on open in V11.
PR4414004: Fixed a problem with select using left handed mouse button settings.
PR4415883: Fixed a problem with MDS Import- Dimension Arrowheads are mirrored
PR4416330: Fixed a problem where parts in section views appear after update
PR4417147: Fixed a problem with Incorect Text size on import of MDS Data
PR4417589: Fixed a problem where protrusion failed.
PR4416387: Fixed a problem where Solid edge disappears when trying to open an Assembly
Note: PR4416387 tracks a problem with a corrupted assembly configuration file.
The problem manifested itself in a crash when opening the assembly via File Open or when
selecting Tools=>Options=>Display Configurations. A fix was provided in 11.0.1.5 that
corrects the crash via File Open. Unfortunately, the fix for correcting the crash via
Tools=>Options=>Display Configurations is incomplete in 11.0.1.5 so it will still crash.
That fix will be in 11.0.2.x. The key to this whole problem is that the crash only occurs
if a corrupted configuration file is attached to the assembly. In 11.0.1.5, the user will
know if the attached cfg file is corrupt by the cfg display ribbon bar being greyed out.
A workflow has been identified that could corrupt configurations that only occurs when
multiple cfgs exist. A fix is in 11.0.1.5 to prevent this workflow from creating corrupted
cfgs.
None of the above addresses correcting any corrupted configurations. The user must delete
any corrupted configurations and re-create them with 11.0.1.5. In the case reported by
Pella, only one or two assemblies have corrupted config files. They can open one of the
assemblies that does not have a corrupted cfg file, go to Tools=>Options=>Display
Configurations and show all cfg files and delete the offending ones from there.
End of What's New in Version 11.00.01.05 of Solid Edge
发表于 2002-2-27 10:31:57 | 只看该作者
README for Solid Edge V11 Handbook Update 1.
Prerequisites: Solid Edge V11 Update 1
This update supports using SE Handbook with Solid Edge files managed by Insight.
The use of SE Handbook with Insight requires that the following:
1.  Under Engineering Handbook Options, the "Local parts" option must be
set to Folder and a folder defined; i.e. "C:\Temp.
2.  The Foldermap.txt file in the Solid Edge Program directory must map the
directory defined in Engineering Handbook to to an Insight server path.
For e.g. Source:C:\Temp Destination:https://hsvnt261/SolidEdge
This Update also includes:
Fix beam deflection calculation with fixed supports
Previews for features are changed (Smartview option must by unchecked)
发表于 2002-3-3 00:09:16 | 只看该作者
Legal Notices
applicable.
United States.
Release Notes:
Product:        Solid Edge
Version:        11.00.02.01
Date:           22-Feb-2002
Solid Edge V11 Update 2 addresses issues reported by Solid Edge
V11 Update 2 should be installed on top of Solid Edge Version
11.00.00.50 or 11.00.01.05.
This Update includes all previous fixes addressed in Update 1.
What's New in Version 11.00.02.01 of Solid Edge
Update 2 addresses the following issues:
PR1127348: Fixed a problem where chamfer dimension has incorrect value when placed on a broken view.
PR1153558: Fixed an abort while using automation mouse control.&nbsp;&nbsp;
PR1153574: Fixed an abort when opening an assembly.&nbsp;&nbsp;
PR1153934: Fixed a problem where datum targets are becoming invisible.&nbsp;&nbsp;
PR1154492: Fixed a problem where EXTMIN/EXTMAX and LIMMIN/LIMMAX is not getting set correctly.&nbsp;&nbsp;
PR1155988: Fixed a problem where a Draft file cannot be saved after clearing the dimension tracker.
PR2004245: Fixed an abort when in profile.&nbsp;&nbsp;
PR2004707: Fixed a ghost display problem when creating freeform geometry&nbsp;&nbsp;
PR2004801: Fixed a problem where Undo caused file to close in the middle of the Draft command.&nbsp;&nbsp;
PR2004922: Fixed an abort when autoballooning a detail view.&nbsp;&nbsp;
PR2005234: Fixed an abort using Peer Variables w/filter "Graphics In" set to "Select set".&nbsp;&nbsp;
PR4366803: Fixed a problem where Place Part ignores a part with predefined relationships.&nbsp;&nbsp;
PR4401401: Fixed a problem handling construction surfaces during drawing view update.&nbsp;&nbsp;
PR4407176: Changed fence select behavior, SHIFT fence appends and CTRL fence removes from the select set.
PR4414628: Fixed a problem that causes abort revision manager while viewing properties&nbsp;&nbsp;
PR4414862: Fixed a problem where custom date properties were not able to be altered.&nbsp;&nbsp;
PR4414885: Fixed an abort when offseting a bspcurve.&nbsp;&nbsp;
PR4418061: Fixed a problem where editing a feature in a GoTo state would go to the last item in&nbsp;&nbsp;the list.
PR4418871: Fixed a problem where Dimension Tracker takes a long time to place balloons.&nbsp;&nbsp;
PR4420246: Fixed a problem in mds layer translation&nbsp;&nbsp;
PR4422022: Fixed a problem converting mds data&nbsp;&nbsp;
PR4424763: Fixed an abort opening the Display Config dialog for an assembly&nbsp;&nbsp;
PR4425524: Fixed a problem where Set Path in Revision Manager does not work on Windows NT.&nbsp;&nbsp;
End of What's New in Version 11.00.02.01 of Solid Edge
发表于 2008-9-19 19:30:35 | 只看该作者
感謝LS解答
发表于 2008-9-19 19:32:15 | 只看该作者
好长的英文
发表于 2008-9-19 19:51:02 | 只看该作者
这贴你们都翻的出来,强人。
GMT+8, 2025-9-18 17:11 , Processed in 0.055290 second(s), 11 queries , Gzip On, Redis On.
