icebreaker_1981 wrote:
按重键还是motion做的
是重建的吧
重建宏:
Option Explicit
Dim swApp As Object
Dim doc As Object
Dim boolstatus As Boolean
Dim longstatus As Long
Dim Annotation As Object
Dim Gtol As Object
Dim DatumTag As Object
Dim FeatureData As Object
Dim Feature As Object
Dim Component As Object
Dim start As Variant
Dim rebuilds As Variant
Dim finish As Variant
Dim totaltime As Variant
Sub Main()
Set swApp = Application.SldWorks
Set doc = swApp.ActiveDoc
Dim Message, Title, Default, Rebuild
Message = "请输入重建的次数"
Title = "重建宏"
Default = "50"
Rebuild = InputBox(Message, Title, Default)
If Rebuild = "" Then
End
Else
start = Timer
For rebuilds = 1 To Rebuild
doc.EditRebuild3
doc.GraphicsRedraw2
Next rebuilds
finish = Timer
totaltime = finish - start
MsgBox "总时间" & totaltime & "秒", vbDefaultButton1, "Rebuild Macro"
End If
End Sub |
