NC中的制定报表
发表于 2006-8-14 22:45:54 | 只看该作者
Parameter  Name                                       Definition
&mfg.oper.name                                           Lists the operation names.
&mfg.oper.description                                  Lists the operation comments.
&mfg.oper.Us er Defined                              Lists the spec ified operation parameters.
&mfg.oper.work cell.name                             Lists the work cell names (mac hine name).
&mfg.oper.workc ell.description        Lists the work cell comments.
&mfg.oper.workcell.User Defined                                                          Lists the specified workcell parameters.
&mfg.oper.workc ell.head.head_number                                                            Lists the work cell head number.
&mfg.oper.work cell.head.tooltbl.tool_id                                                        Lists the tool names.
&mfg.oper.workc ell.head.tooltbl.tool_pock et.tool_comment                        Lists the tool comments.
&mfg.oper.work cell.head.tooltbl.tool_pock et.tool_position                  Lists the tool position locations.
&mfg.oper.work cell.head.tooltbl.tool_pock et.tool_register            Lists the tool offs et values.
&mfg.oper.workc ell.head.tooltbl.User Defined                          Lists the specified tool parameters.
&mfg.oper.work cell.turret.holder_size                                      Lists the holder sizes for the turrets.
&mfg.oper.work cell.turret.index                                               Lists the turret station numbers.
&mfg.oper.workc ell.turret.indexable                                  Lists whether the turret is indexable.
&mfg.oper.work cell.turret.orient                                                       Lists the turret orientation.
&mfg.oper.workc ell.turret.tool_name                                         Lists the tool names for the turret.
&mfg.oper.ncseq.name                                                     Lists the NC sequence names.
&mfg.oper.ncseq.description                                                     Lists the NC sequence comments.
&mfg.oper.ncseq.User Defined                                                    Lists the specified NC sequence parameters.
&mfg.oper.ncseq.cutmtn.name                                      Lists the cut motion names.
&mfg.oper.ncseq.cutmtn.User Defined                  Lists the specified cut motion parameters.
32
发表于 2006-8-23 19:27:41 | 只看该作者
不过楼主的电极拆得真不怎样
33
发表于 2007-3-11 14:27:49 | 只看该作者
顶,好东东!
34
发表于 2007-3-11 21:21:41 | 只看该作者
顶,不过,我们操机的习惯了在程式开头加各个程式的用刀直径,其它的不怎么关心!!不过,这些参数的应用值得关注!!
35
发表于 2007-8-18 21:35:14 | 只看该作者
顶一下,不知道有没有关于SET的参数,因为我做程式时总是一个SET,一个程式,通常一个SET里只有一种刀,换工序时就用另个SET
36
发表于 2007-8-18 21:36:52 | 只看该作者
37
发表于 2008-12-8 16:14:39 | 只看该作者
下来看看,学习学习
38
发表于 2008-12-18 21:10:58 | 只看该作者
太好了,又学了一点,我可以去试试了
39
发表于 2009-8-17 23:06:36 | 只看该作者
学习中。。。。。
40
发表于 2010-9-28 13:22:32 | 只看该作者
不错.顶.
GMT+8, 2025-7-8 14:35 , Processed in 0.037556 second(s), 10 queries , Gzip On, Redis On.
