查看: 16565|回复: 1
thicken sheet // hollow 等问题
发表于 2005-2-18 12:56:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
初学造型经常会用到增厚或挖空,在下常会碰到出错,不论先做实体再挖空或先做薄体再增厚 。不知道是程序的BUG,还是需要啥窍门,刚看到XYI发的《 我是菜鸟,请问怎样才能将3根线联成一个顺滑的面?》,https://icax.org/cgi-bin/ut/att.cgi?aid=2668811&bid=4
下了他的IGS文件试了下,还是同样结果。UG中错误分析:Error data: ifail = 0 , state = 17002
Surface failed to offset or face could not be deleted
Minimum radius value  =       0.214463041
was found at 1 point  located at coneheads with solid font
Minimum radius value  =       0.421384616
was found at 1 point  located at coneheads with dotted font
拜托各位大虾指点下!!
上面链接为XYI的下栽,在下再贴一下
发表于 2005-2-19 04:02:30 | 只看该作者
这个怎样?
GMT+8, 2025-4-27 23:07 , Processed in 0.060598 second(s), 14 queries , Gzip On, Redis On.
