catiaV5R14对电脑硬件的要求怎样?
发表于 2005-3-10 14:15:05 | 只看该作者
笔记本:
迅驰M1.8
64M显卡
512内存
学习用
应该没问题把??
32
发表于 2005-3-10 23:28:58 | 只看该作者
我是初学者
机子是:duron750
384ram
9550改的fireGLt2
hdd:40g
启动挺快,也就1分钟,不过看了楼上各位的帖子,
我该升级电脑了:)
33
发表于 2005-3-10 23:33:29 | 只看该作者
我是个初学者
机子是:amd毒龙750
384内存,
9550改的FireGLt2
40g硬盘。
启动挺快的,也就一分钟左右,
不过看了楼上各位大哥的留言,
我觉得我该升级电脑了:)
34
发表于 2005-3-11 08:05:49 | 只看该作者
P4 3.0G
DDR400 512M*2
Geforce6800标准版128M
8000块值不值?
35
发表于 2005-3-12 13:32:45 | 只看该作者
跑UG很顺的机子,用CATIA差不多吧?
我的是:
CD2.53(超2.8)   512M DDR400   FX5200  双128   金钻80G
36
发表于 2005-3-12 16:44:58 | 只看该作者
barton2500+
1G dual ddr400
nforce2 ultra
9550 64/128bit
用起来还好.
37
发表于 2005-3-12 19:27:55 | 只看该作者
配置p4 2.8 GHz
     512MB  133HZ SDRAM
     80G  7200RPM 硬盘
    128MB ATI 9200SE
能跑得动吗?
38
发表于 2005-3-15 12:42:23 | 只看该作者
请看——
Common Hardware Requirements
The following requirements are common to all operating systems supported by Version 5. System unit and graphic requirements are platform specific and are detailed in the topics that follow:
Disk drive: an internal or external disk drive (minimum recommended size : 4 GB) is required to store program executables, program data, usage environment and paging space.
Installation of all CATIA Version 5 Products require 2.0 GB on Windows, 2.4 GB on AIX, 2.7 GB on HP-UX, 2.5 GB on IRIX and 2.3 GB on Solaris.
Memory: 256 MB of RAM is the minimum recommended amount of memory for all applications. 512 MB of RAM is recommended for DMU applications on large assemblies  and for the CATIA - Digitized Shape Editor 2 (DSE) product. Requirements may be greater when large amounts of data are used.
Internal/external drives: a CD-ROM drive is required for program installation and access to the online documentation, which can optionally be downloaded to disk.
Display: A graphic color display, compatible with the selected platform-specific graphic adapter. The  minimum recommended size for usability reasons is 17 inches. The minimum resolution required for Windows workstations is 1024 x 768, and 1280 x 1024 on UNIX workstations. Changing the resolution during a session is not supported. You first have to exit the current session, change the resolution then restart the session, otherwise the result is unpredictable.
When selecting a graphic adapter, hardware texturing capability is strongly recommended when using Version 5 products that use texture mapping, in which case the amount of RAM has to be adequate for the number and complexity of textures to be used.
Keyboard: a specific keyboard compatible with selected installation locale may be required for national language support.
Pointing device: 3-button mouse. On Windows workstations, a 2-button mouse may alternatively be used (the third button is emulated with a keyboard sequence). The 3-button mouse is recommended for usability reasons. The IntelliMouse (two buttons plus wheel) is an alternative to the three-button mouse on Windows workstations, the wheel acting as the middle button and allowing additional manipulations such as panning and scrolling.
Optional components and features
SpaceBall and SpaceMouse can be used, in addition to the mouse, to perform graphic manipulations (zoom, pan, rotate, etc.). The necessary drivers are delivered with the device.
These devices can be used with CATIA - DMU NAVIGATOR 1 (DN1), CATIA - DMU SPACE ANALYSIS (SP1) and all CATIA P2 Products.
The robustness of the overall solution is dependant on the robustness of the operating system and the hardware environment used. Windows and UNIX hardware configurations certified by Dassault Systemes for running products are published at:
https://www.ibm.com/solutions/plm
Although products might run on other configurations or other graphic adapters, incidents specific to these configurations or adapters would not be accepted for support.
Support for Computers Running Multiple Processors
The Version 5 infrastructure detects if your computer is equipped with multiple processors, and provides multi-threaded graphics support on the AIX, SGI and Solaris platforms to enhance visualization performance. The Version 5 infrastructure supports in multithread mode up to 16 graphics adapters and 32 CPUs.
System Unit
Intel Pentium III or Pentium 4-based workstations running Windows2000 Professional Edition, or Windows XP Professional Edition.
Network Adapter
An active LAN adapter (Ethernet or Token Ring, installed and configured) is required for licensing purposes.
Graphic Adapter
An OpenGL-capable graphic adapter is required. Note that graphic performance on local transformations (panning, zooming, rotating model) will depend on the selected graphic adapter. This graphic adapter should have the following capabilities:
16 bits, high color, double buffered visual
16 bits Z-buffer (when hardware accelerated)
stencil buffer (1 bit)
minimum supported resolution is 1024 x 768; a resolution of 1280 x 1024 is recommended for usability reasons.
Windows 2000 and Windows XP
System Unit
Pentium III or Pentium 4-based workstations running Microsoft Windows 2000, Windows XP Home Edition or Windows XP Professional.
Graphic Adapter
A graphic adapter with a 3D OpenGL accelerator is required. Note that graphic performance on viewing functions (panning, zooming, rotating) will depend on the selected graphic adapter. The graphic adapter should have the following capabilities:
24 bits, true color, double buffered visual
24 bits Z-buffer
stencil buffer
minimum supported resolution: 1024 x 768; a resolution of 1280 x 1024 is recommended for usability reasons.
Network Adapter
Supported Configurations on Windows 2000 and Windows XP
An updated list of hardware configurations, certified at Dassault Systemes for running Version 5 products, is published on the V5 Web site at URL:
39
发表于 2005-3-20 19:40:01 | 只看该作者
经常推出,是因为你少了一个补丁啊,装上就可以了,我的以前也是啊
40
发表于 2005-3-20 22:28:41 | 只看该作者
cpu: 赛扬1.0G
显卡: ATI 8M
内存:128M
硬盘:40G
现用CATIA V5R13 没问题啊。跑起来还挺顺。跟公司的P4 2.4G;128M显存; 256内存的电脑感 觉差不多啊
GMT+8, 2025-3-14 14:05 , Processed in 0.023981 second(s), 10 queries , Gzip On, Redis On.
