superlightcar 結構圖
发表于 2005-3-1 11:30:50 | 只看该作者
发表于 2005-3-1 11:32:20 | 只看该作者
11
发表于 2005-3-1 11:33:04 | 只看该作者
发表于 2005-3-1 11:34:08 | 只看该作者
发表于 2005-3-1 11:35:08 | 只看该作者
发表于 2005-3-1 11:42:11 | 只看该作者
发表于 2005-3-1 11:43:40 | 只看该作者
发表于 2005-3-1 11:44:45 | 只看该作者
发表于 2005-3-1 15:12:43 | 只看该作者
很不错呀
是概念车把……
20
发表于 2005-3-1 16:04:18 | 只看该作者
GENERAL FEATURES
- DIMENSIONS
Max length  :  2507 mm
Max width : 1400 mm
Max height : 1180 mm
Wheelbase : 1700 mm
Front track : 1210 mm
Rear track : 1200 mm
Height from ground : 150 mm
Unladen weight : 200 Kg
Seating capacity : 2
- CHASSIS
Chassis
  Carbon fibre monococque
- SUSPENSIONS/BREAKS
  Front suspension : Articulated quadrilateral system in light metal alloy with shock absorber in the lower triangle and torsion bar
Back suspension : Independent monoarm system  with shock absorber and torsion bar
Front brakes : Disk-brake (diameter 220mm)
Back brakes : Disk-brake
Wheels : Aluminium alloy rim with single nut lock system
- STEERING
Steering : Rack steering-wheel
  - ENGINE TECHNICAL DATA
Engine : Two-cylinder  four times
Timing system : Two valve every cilinder,
camshaft with toothed belt
Cubic capacityt : 350 cc
Bore : 70 x 45,5 mm
Compression ratio : 12 : 1
Rating : 15 kw (20,4 hp)
Max couple : 2,8 dNm a 5.000 r.p.m.
Max revs speed : 7500 revs per minute
Firing : Electronic injection
Cooling : Water-cooling with aluminium radiator
- DRIVE
Gearbox : Four-speed sequential gearbox electronically controlled by the commands close to the steering wheel
Clutch : Automatic
Final drive  : Mechanic differential unit
GMT+8, 2025-4-22 13:24 , Processed in 0.027775 second(s), 10 queries , Gzip On, Redis On.
