123
返回列表 发新帖
【求助】ugnx:GATEWAY—>信息—>其它—>图形驱动卡
发表于 2002-12-6 09:11:45 | 只看该作者
ykcam1 wrote:
目前,UG软件:WINDOWS平台系统,还不能支持Stereo viewing
22
发表于 2002-12-7 14:43:06 | 只看该作者
Stereo viewing is a common technique to increase visual realism or enhance user interaction with 3D scenes. Two views of a scene are created, one for the left eye, one for the right. Some sort of viewing hardware is used with the display, so each eye only sees the view created for it. The apparent depth of objects is a function of the difference in their positions from the left and right eye views. When done properly, objects appear to have actual depth, especially with respect to each other. When animating, the left and right back buffers are used, and must be updated each frame.
大概就和咱们看的立体画差不多吧
23
发表于 2003-1-5 14:42:49 | 只看该作者
flash_star wrote:
  怎样解决的??我的显示也有问题了!我的显卡是:ELSA  550 XGL
  Graphics device:  Quadro4 5000 XGL/AGP/3DNOW!
  Translucency method:  Alpha-blend translucency
  Maximum texture size:  2048
  Stereo viewing:  Unavailable
  Full-scene antialiasing:  Unavailable
:~)这位大侠能否告知解决方法?
24
发表于 2003-1-5 14:44:25 | 只看该作者
  :~)这位大侠能否告知解决方法?
GMT+8, 2025-4-12 22:52 , Processed in 0.021718 second(s), 13 queries , Gzip On, Redis On.
