成君工作室FLOW3D培训资料
发表于 2005-7-13 15:37:19 | 只看该作者
d
72
发表于 2005-7-15 13:59:06 | 只看该作者
Flow3d--对不同方案模拟的结果进行比较    *英文不难理解*
compare results from different simulations
One of the goals of simulation is to compare results obtained when particular parameters are changed. An easy way to compare results of different simulations is to use the plot overlay option available in the FLOW-PLOT and PLTFSI display utilities. Users running on UNIX and LINUX platforms will have to use PLTFSI.
In either case the first step is to open a flsgrf results file from Results, Custom. It is fairly straightforward to compare time history plots, 1D and 2D spatial plots from the same results file, since they can be directly overlaid. To overlay the two plots using PLTFSI, enter D n+m where n and m represent the plot numbers. In FLOW-PLOT you must change the option in the Control Panel from “single” to “overlay,” then click on the plots to be overlaid.
Comparing plots from two or more different flsgrf files requires an extra step. Let’s say you’d like to compare the temperature history at a particular point in the domain. The simplest method is to first open an flsgrf file containing one set of results to be compared. In FLOWPLOT, choose Files, Create, then open another flsgrf results file containing the other set of data using option 8 in PLTFSI or the Files, Open(Add) option in the Control Panel of FLOW-PLOT. This creates a combined plot file from which you can select members to be overlaid.
An alternative that is sometimes useful is to save the plots to be compared from one flsgrf results file to a temporary file. Then open the second results file and add to it the temporary file. This creates a smaller file to deal with. Of course, you could then select the plots to be compared in the combined file and save them to another temporary file.  Continuing in this way it is possible to build up a file containing selected results from many separate flsgrf files.
A useful, but often overlooked feature in PLTFSI is the ability to specify the colors of individual plot lines. For example, you could set the line color for plot number 2 to red and plot number 3 to violet. To set plot attributes, enter option 10 (select plotting options), and then option 7 (select plot line attributes).<--mstheme-->
73
发表于 2005-7-15 18:21:20 | 只看该作者
flow_3d@126.com
74
发表于 2005-7-29 07:37:02 | 只看该作者
flow-3d 案例
75
发表于 2005-7-29 12:48:22 | 只看该作者
flow3d案例动画
76
发表于 2005-7-29 19:55:28 | 只看该作者
flow3d案例
77
发表于 2005-8-7 18:01:47 | 只看该作者
FLOW3D推广信息: 成君工作室----漳州培训分处9/1开始招生!!!
FLOW3D边界条件之Continuative
Use of the Continuative Mesh Boundary Condition
When there is a need to have fluid flow out one or more of the boundaries of a computational domain, the question arises: what is the right boundary condition? Several mesh boundary conditions can serve as outflow boundaries in FLOW-3D, including specified pressure, continuative and outflow.
The simplest and most commonly used outflow condition is the continuative boundary. A continuative boundary condition consists of zero normal derivatives at the boundary for all flow quantities. The zero-derivative condition is intended to represent a smooth continuation of the flow through the boundary. Therefore, using the continuative boundary condition is most suitable when the flow upstream from the boundary exhibits little variation in space (at least in the direction normal to the boundary) and time. This condition usually requires the continuative boundaries to be placed far downstream from any disturbances in the flow like constrictions or submerged bodies.
It must be stressed that the continuative boundary condition has little physical basis. Rather, it is a mathematical statement that may or may not provide the desired flow behavior. In particular, if flow is observed to enter the computational region across such a boundary, then the computations may be wrong because nothing has been specified about flow conditions existing outside the boundary. The entering flow is forced to do so from the condition of rest. This practice helps to reduce inflow and often results in a reasonable approximation of a smooth outflow condition.
Among other things, the zero-derivative condition at continuative boundaries implies that there is no acceleration or deceleration of the flow as it crosses the boundary. Therefore, the continuative boundary condition is not consistent with a significant non-zero force component normal to the boundary (for example, gravity).
The only input variable that can be defined at a continuative mesh boundary is fluid height, which can be used in free-surface type flows. However, its effect on the flow is quite limited since the flow near the boundary is not computed from the conservation equations, but rather set from the zero-derivative condition.
In short, a continuative boundary employs a very simple algorithm, but the results must be viewed with a good degree of suspicion. As a general rule, a more physically meaningful boundary condition, such as a specified pressure condition, should be used at outflow boundaries whenever possible.
78
发表于 2005-8-11 09:42:32 | 只看该作者
顶,我觉得不错哦,想学习学习
79
发表于 2005-8-12 08:26:30 | 只看该作者
实战案例
成君工作室出品13606906674
flow_3d@126.com
80
发表于 2005-8-12 15:32:32 | 只看该作者
谢谢
GMT+8, 2025-7-11 11:26 , Processed in 0.053882 second(s), 11 queries , Gzip On, Redis On.
