双11·3D打印优惠活动
进口造型教程(入关审批耽误了好久)
发表于 2005-5-30 01:35:59 | 只看该作者
Extrude the mouse wheel and in the Direction1 and Direction 2 options set them to offset from surface. Create the extrude .5 mm offset from the inner walls of the opening. Uncheck the box that says merge result. SWX by default tries to chunk features together into one solid mass whenever Solid features are used. Most times this is preferred but sometimes you might might to makuse of multi- body features (as in the case of the scroll wheel.
发表于 2005-5-30 01:36:22 | 只看该作者
This fillet is a full round fillet. Pick the three consecutive faces of the cylinder to create the fillet
发表于 2005-5-30 01:37:02 | 只看该作者
此楼无语
发表于 2005-5-30 01:37:35 | 只看该作者
I figured out how I wanted the ribs to look like in the sketch in the folder "Rib sketches" Extrude a surface that goes past the outer surface of overmold
发表于 2005-5-30 01:38:37 | 只看该作者
This creates a rib that you can lay onto the surface of the overmold
发表于 2005-5-30 01:39:04 | 只看该作者
Create a 3D sketch and create intersection curves between the surface extrude and the outer surface of the overmold.
(Hit Esc after you create the curves to back out of the intersection command)
发表于 2005-5-30 01:39:44 | 只看该作者
The curves in green are the curves on the surface of the overmold that you want to map your gripping ribs to. as you can see there are four ribs to be mapped by means of the deform tool.
So we will have to make copies of the revolve.
原站图片错误
38
发表于 2005-5-30 01:40:03 | 只看该作者
Use the Copy/move Body Feature to make 3 copies of the revolve. Do not specify a displacement (all the copies will overlap and look like one revolve even though there are 4 bodies). This is so that we can use the centerline of the Revolve sketch as an initial curve
(Ignore the surface extrude . You can hide it)
发表于 2005-5-30 01:40:29 | 只看该作者
The Deform tool uses curves to map your geometry to curves. The initial curves map to your geometry, and then Solidworks interpolates the change in geometry from the change between the Initial and Target Curves
又出错
40
发表于 2005-5-30 01:40:53 | 只看该作者
When you are performing the deform command, hide all the revolved bodies except for one. This makes it easy to select the body you want to work on.
As you can see in the tree, there are 4 deforms performed t omodel each rib
GMT+8, 2025-10-22 02:30 , Processed in 0.024309 second(s), 9 queries , Gzip On, Redis On.
