查看: 15623|回复: 1
问一个关于animation的问题!望高手赐教
发表于 2005-6-24 16:59:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
初学ADAMS所以有许多不懂,我做一个模型的仿真是遇到message window说
JOINT JEEP.JOINT_25 is not specified correctly.
   The angle between the x-axis of the I marker and the y-axis of
   the J marker is 8.53774E-07 degrees.
   The angle between the y-axis of the I marker and the x-axis of
   the J marker is 98.411 degrees.
   These angles should be of equal magnitude and opposite sign.
不知试什么原因,望高手赐教
万分感谢
发表于 2005-6-25 16:51:11 | 只看该作者
可能是你运动副的方向不对!你再看看你的运动副!
GMT+8, 2025-9-19 01:20 , Processed in 0.027582 second(s), 12 queries , Gzip On, Redis On.
