返回列表 发新帖
EMX问题
发表于 2005-11-21 19:43:59 | 只看该作者
只要你是按以下设置一下就可以了,不知各位有没有这项设置。
PTC Expert Moldbase Extension v4.0
Note: EMX is compatible with Pro/e 2001 and Wildfire Release. Make
      sure you read the setup notes in proe_loadpoint\emx40\docu\
      usascii\user\index.htm. Also, if you are using the ROR release
      of Wildfire then use our license since it has the missing options
      #210 in it.
1. Copy the folder "emx40" on the CD to you Pro/e loadpoint.
   E.g. C:\ptc\proe2001\emx40.
2. Open proe_loadpoint\emx40\text and edit the protk.dat. Set the paths
   to you installed path for following lines in the protk.dat file:
   E.g.   exec_file C:\Ptc\proeWildfire\emx40\i486_nt\emx40.dll
          text_dir  C:\Ptc\proeWildfire\emx40\text
3. Open proe_loadpoint\emx40\text and edit the config.pro. Change the
   config option (last line) "PROTKDAT" to your installed path:
   E.g.   PROTKDAT C:\Ptc\proeWildfire\emx40\text\protk.dat
4. Copy the config.pro and the config.win to you start directory
   or to C:\Ptc\proeWildfire\text directory.
5  Edit the ptc.dat in the crack direcory. Change 00-00-00-00-00-00 to
   your Host ID (Network card number and keep "-"). Run the keygen.bat
   and replace your existing ptc license.dat. You will need to rerun
   setup.bat in the proe_loadpoint\bin and edit and select our
   license file at the start command window.
GMT+8, 2025-4-29 19:00 , Processed in 0.020517 second(s), 13 queries , Gzip On, Redis On.
