优化设计的练习题
发表于 2002-12-26 23:09:33 | 只看该作者
保存的数据文件*.xls,是excel文件,里面是每步的数据,
要获得精确的数值,在algorithm中选择slow,
以下来之online:
To perform an optimization, you can use one of the algorithms below:
Gradient based algorithm
This algorithm should be used first to perform a local search. Based on the calculation of a local slope of the objective function this algorithm will use a parabolic approximation and jump to its minimum or use an iterated exponential step descent in the direction of the minimum.
If the properties of the objective function are known (continuous, differentiable at all point), then the gradient can be used straight on. It is usually faster than the Simulated Annealing algorithm.
Simulated Annealing based algorithm
This algorithm is a global stochastic search algorithm hence two successive runs of this method might not lead to the same result. It performs a global search that evolves towards local searches as the time goes on.
It is usually used to explore non-linear, multi-modal functions. These functions can also be discontinuous.
If the shape of the objective function is unknown, it is recommended to start with a Simulated Annealing then refine the results with a gradient descent. This approach is slow but works for a larger amount of functions.
  A good way to quickly reach a solution when using the Simulated Annealing consists in specifying a low number of consecutive iterations without improvements (15 or 20).
发表于 2002-12-26 23:10:20 | 只看该作者
catiaV5R10文件
发表于 2002-12-26 23:14:45 | 只看该作者
用个问题,excel文件里的best value是5711.99,
而计算是显示的best value是5711.989
还有用不通的算法,获得的best value也有微小的区别,
另外还有其它参数,大家可以看online,有助于加快分析速度,减少时间.
累死我了,还是做做快,说明慢!!!!!!!!!!!!!!!!!!!!!!!!!!1111
24
发表于 2002-12-27 08:50:25 | 只看该作者
很好!
25
发表于 2002-12-27 08:52:07 | 只看该作者
做的很好哦!
值有微小差異,很正常,因為是用不同的迫近方式計算的!
26
发表于 2002-12-27 11:28:50 | 只看该作者
我做了一个,但无法优化出结果。劳烦各位看看。
发表于 2002-12-27 11:47:37 | 只看该作者
有没有加分呀?
加了2分啊
28
发表于 2002-12-27 15:07:36 | 只看该作者
研究很久,还是找不出原因,?????
今天没空看了,下次来时看看
29
发表于 2002-12-27 19:34:35 | 只看该作者
junejune wrote:
研究很久,还是找不出原因,?????
  今天没空看了,下次来时看看
你把要被优化的参数搞错了,Area.1已经是1/22的球面,还要求它干吗?
应该选MeasureSurface4\Area
30
发表于 2002-12-29 14:43:47 | 只看该作者
我的V5R7可以打开V5R10的文件吗?如不能,请大哥发个R7的文件研究,谢谢!
GMT+8, 2025-10-17 16:55 , Processed in 0.115082 second(s), 10 queries , Gzip On, Redis On.
