标题: 模具英语术语(转) [打印本页]
作者: candeman    时间: 2005-9-24 10:16
标题: 模具英语术语(转)
模具述语
一、入水:gate
进入位: gate location
水口形式:gate type
大水口:edge gate
细水口: pin-point gate
水口大小:gate size
转水口: switching runner/gate
唧嘴口径: sprue diameter
二、流道: runner
热流道: hot runner,hot manifold
热嘴冷流道: hot sprue/cold runner
唧嘴直流: direct sprue gate
圆形流道:round(full/half runner
流道电脑分析:mold flow analysis
流道平衡:runner balance
热嘴: hot sprue
热流道板:hot manifold
发热管:cartridge heater
探针: thermocouples
插头: connector plug
插座: connector socket
密封/封料: seal
三、运水:water line
喉塞:line lpug
喉管:tube
塑胶管:plastic tube
快速接头:jiffy quick connector plug/socker
四、模具零件: mold components
三板模:3-plate mold
二板模:2-plate mold
边钉/导边:leader pin/guide pin
边司/导套:bushing/guide bushing
中托司:shoulder guide bushing
中托边L:guide pin
顶针板:ejector retainner plate
托板: support plate
螺丝: screw
管钉:dowel pin
开模槽:ply bar scot
内模管位:core/cavity inter-lock
顶针: ejector pin
司筒:ejector sleeve
司筒针:ejector pin
推板:stripper plate
缩呵:movable core,return core core puller
扣机(尼龙拉勾):nylon latch lock
斜顶:lifter
模胚(架): mold base
上内模:cavity insert
下内模:core insert
行位(滑块): slide
镶件:insert
压座/斜鸡:wedge
耐磨板/油板:wedge wear plate
压条:plate
撑头: support pillar
唧嘴: sprue bushing
挡板:stop plate
定位圈:locating ring
锁扣:latch
扣鸡:parting lock set
推杆:push bar
栓打螺丝:S.H.S.B
顶板:eracuretun
活动臂:lever arm
分流锥:spure sperader
水口司:bush
垃圾钉:stop pin
隔片:buffle
弹弓柱:spring rod
弹弓:die spring
中托司:ejector guide bush
中托边:ejector guide pin
镶针:pin
销子:dowel pin
波子弹弓:ball catch
喉塞: pipe plug
锁模块:lock plate
斜顶:angle from pin
斜顶杆:angle ejector rod
尼龙拉勾:parting locks
活动臂:lever arm
复位键、提前回杆:early return bar
气阀:valves
斜导边:angle pin
术语:terms
承压平面平衡:parting surface support balance
模排气:parting line venting
回针碰料位:return pin and cavity interference
模总高超出啤机规格:mold base shut hight
顶针碰运水:water line interferes withejector pin
料位出上/下模:part from cavith (core) side
模胚原身出料位:cavity direct cut on A-plate,core direct cut on B-plate.
不准用镶件: Do not use (core/cavity) insert
用铍铜做镶件: use beryllium copper insert
初步(正式)模图设计:preliinary (final) mold design
反呵:reverse core
弹弓压缩量:spring compressed length
稳定性好:good stability,stable
强度不够:insufficient rigidity
均匀冷却:even cooling
扣模:sticking
热膨胀:thero expansion
公差:tolorance
铜公(电极):copper electrode
作者: jmyu    时间: 2005-9-24 14:59
谢谢!
作者: linlaiwei    时间: 2005-9-24 19:46
标题: ding
作者: lping    时间: 2005-9-24 21:15
标题: Could someone-brother tell me how to upload it to compare for all toghter????
Good,but i have complete information(english words) for the mold,but i can't upload its?Could someone-brother tell me how to upload it to compare for all toghter????
作者: 歌君    时间: 2005-9-27 15:22
一、入水:gate
进入位: gate location
水口形式:gate type
大水口:edge gate
细水口: pin-point gate
水口大小:gate size
二、流道: runner
流道平衡:runner balance
热嘴: hot sprue
热流道板:hot manifold
探针: thermocouples
插头: connector plug
密封/封料: seal
三、运水:water line
喉塞:line lpug
喉管:tube
塑胶管:plastic tube
三板模:3-plate mold
二板模:2-plate mold
中托边L:guide pin
托板: support plate
螺丝: screw
管钉:dowel pin
开模槽:ply bar scot
顶针: ejector pin
司筒:ejector sleeve
司筒针:ejector pin
推板:stripper plate
斜顶:lifter
模胚(架): mold base
上内模:cavity insert
下内模:core insert
行位(滑块): slide
镶件:insert
压座/斜鸡:wedge
压条:plate
撑头: support pillar
唧嘴: sprue bushing
挡板:stop plate
定位圈:locating ring
锁扣:latch
扣鸡:parting lock set
推杆:push bar
栓打螺丝:S.H.S.B
顶板:eracuretun
活动臂:lever arm
分流锥:spure sperader
水口司:bush
垃圾钉:stop pin
隔片:buffle
弹弓柱:spring rod
弹弓:die spring
镶针:pin
销子:dowel pin
波子弹弓:ball catch
喉塞: pipe plug
锁模块:lock plate
斜顶:angle from pin
尼龙拉勾:parting locks
活动臂:lever arm
气阀:valves
斜导边:angle pin
术语:terms
反呵:reverse core
均匀冷却:even cooling
扣模:sticking
热膨胀:thero expansion
公差:tolorance
[广告]: 冠天科技 APMS 自动化编程系统!
jmyu (试用期)
UID:  227657 积分: 0
技术: 0 坛币: 0
水位: 96 工龄: 5.7
帖子: 96 精华: 0
注册: 2005-7-8
状态: 离线
2005-9-24 14:59  [信息]  [悄悄话]   [引用]  [报告]  [搜索]    第 2 楼
谢谢!
[广告]: 深圳逆向工程与现场测量演示会,欢迎报名参加!
linlaiwei (试用期)
UID:  262410 积分: 0
技术: 0 坛币: 0
水位: 29 工龄: 5.4
帖子: 28 精华: 0
注册: 2005-9-6
状态: 在线
2005-9-24 19:46  [信息]  [悄悄话]   [引用]  [报告]  [搜索]    第 3 楼
ding
[广告]: FARO产品在逆向工程中的应用演示会!
lping (试用期)
UID:  111129 积分: 0
技术: 0 坛币: 0
水位: 18 工龄: 1.2
帖子: 17 精华: 0
注册: 2004-11-27
状态: 离线
2005-9-24 21:15  [信息]  [悄悄话]   [引用]  [报告]  [搜索]    第 4 楼
作者: wdzqa    时间: 2005-10-5 16:55
多谢了,没看都不知有这么多东东哦
作者: laodai1972    时间: 2005-10-5 17:12
好资料,谢谢!
作者: laodai1972    时间: 2005-10-5 17:13
好资料,谢谢!
作者: szfzsky    时间: 2005-10-6 17:01
作者: hwtzj9645_cn    时间: 2006-8-25 21:28
不错的,先收了,顶一下.
作者: lion_zj    时间: 2006-8-26 00:10
ding
作者: 229894713    时间: 2008-9-25 22:55
不错的,先收了,顶一下.
