返回列表 发新帖
Loft真的有问题耶~
发表于 2002-3-16 22:06:33 | 只看该作者
alexis wrote:
><不过搞了半天还是没答案说
是不是因为有甚幺限制的条件所以我无法做LOFT这个动作呢?
你不丟圖檔上來
我想解決的機會不大
发表于 2002-3-17 15:59:49 | 只看该作者
Ok~
我把档案丢上来给你们玩玩^_^
发表于 2002-3-17 18:46:56 | 只看该作者
是这样吗?
发表于 2002-3-17 19:19:02 | 只看该作者
Several coupling types are available in the Coupling tab:
  Ratio: the curves are coupled according to the curvilinear abscissa ratio.
  Tangency: the curves are coupled according to their tangency discontinuity points. If they do not have the same
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;number  of points, they cannot be coupled using this option.
  Tangency then curvature: the curves are coupled according to their curvature discontinuity points. If they do not have
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;the same number of points, they cannot be coupled using this option.
  Vertices: the curves are coupled according to their vertices. If they do not have the same number of vertices,
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;they cannot be coupled using this option.
发表于 2002-3-18 00:07:32 | 只看该作者
應該沒有問題
发表于 2002-3-18 01:12:27 | 只看该作者
Thank dude^_^
I think I made a careless mistake~
I disregard the coupling option. Because I use  "Tangency then curvature" this tab, thus I can't do it work out.
Anyway thank you again!
发表于 2010-7-24 09:40:25 | 只看该作者
呵呵   学习中  本人刚学
GMT+8, 2025-4-29 01:43 , Processed in 0.067139 second(s), 12 queries , Gzip On, Redis On.
