查看: 16140|回复: 3
大家都来说说UG配置
发表于 2005-10-31 16:41:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我先来一点,错误请指出:)谢谢1
! **                 S K E T C H    P R E F E R E N C E S                   **
! **                                    草绘参数选择                                    **
Sketch_snapAngle:                 3.000           ! degrees 捕捉角
Sketch_decimalPlaces:             3               ! 小数点位数
Sketch_textHeight_EU:             0.15            ! inches 文本高度
Sketch_textHeight_MU:             2.00            ! mm 文本高度
Sketch_dimensionLabel:            Expression      ! [Expression,Name,Value]尺寸标记
Sketch_viewOrientation:           On              ! 试图定向
Sketch_layerStatus:               On              ! 保持层状态
Sketch_displayDOF:                On              ! 显示自由度箭头
Sketch_delayEvaluation:           Off             ! 延迟更新
! Prefixes used for sketch entities
! 图素前缀
Sketch_sketchNamePrefix:          SKETCH_!草图
Sketch_vertexNamePrefix:          Vertex ! V18 was V 顶点
Sketch_lineNamePrefix:            Line   ! V18 was L 线
Sketch_arcNamePrefix:             Arc    ! V18 was A 弧
Sketch_conicNamePrefix:           Conic  ! V18 was C 二次曲线
Sketch_splineNamePrefix:          Spline ! V18 was S 样条
! Sketch color preferences 绘图颜色参数
!       Valid options are     : [1-216]
!       Some color values are : blue (1), green (2), cyan (3), red (4),
!                               magenta (5), yellow (6), white (7), olive (8),
!                               pink (9), brown (10), orange (11), purple (12),
!                               dark-red (13), aquamarine (14), gray (15) )
Sketch_curveColor:                31              ! Pure Cyan, V18 was 3 - Cyan 曲线
Sketch_inactiveSketchColor:       3               ! Cyan, new to V19 非活动的
Sketch_dimensionColor:            37              ! Pure White, V18 was 2 - Green 尺寸
Sketch_overdefinedColor:          42              ! Pure Yellow, V18 was 6 - Yellow 过定义
Sketch_conflictingColor:          9               ! Pink 相冲突的
Sketch_refDimensionColor:         15              ! Gray, V18 was 7 - White 参考尺寸
Sketch_refCurveColor:             15              ! Gray 参考线
Sketch_outdatedCurveColor:        1               ! Blue
Sketch_dofColor:                  42              ! Pure Yellow, V18 was 6 - Yellow 自由度
Sketch_pdatumColour:              17              ! Light Hard Spring 基准
发表于 2005-10-31 16:53:56 | 只看该作者
初学那会儿最想这个了,但一直没有找到,谢了哟!
发表于 2005-11-1 11:42:22 | 只看该作者
ding qi la
发表于 2008-12-16 10:25:18 | 只看该作者
ug配置
ug的配置文件是那个呢?
GMT+8, 2025-4-26 13:33 , Processed in 0.024754 second(s), 14 queries , Gzip On, Redis On.
