标题: 简要介绍 Creat corner rip功能用法 [打印本页] 作者: caohanping 时间: 2005-11-14 19:34 标题: 简要介绍 Creat corner rip功能用法 看到一个求助的帖子,找不到位置了,但该命令确实很少用,我把我的实践写下来,虽然简单,帮我顶顶!
先看英文资料:
About Corner Relief
Corner relief helps control the sheet metal material behavior and prevents unwanted deformation. To utilize the corner relief option you must have at least one ripped edge and the 3D notes turned on (Utilities > Environment).
You can create four types of corner relief:
No Relief
None
Circular
Obround
No relief is added. The corner retains the default V-notch characteristic.
Generate a square corner. The default V-notch characteristic is removed.
Add a circular relief. The corner has a circular section removed.
Add an obround relief. The corner has an obround section removed.
There are four possible ways to apply corner relief to bends or converted parts:
Create the corner relief as a feature ( Feature > Create > Corner Relief)
Create default relief automatically while unbending (Set Up > Corner Relief)
Create default relief for all corners in the model or part templates (Set Up > Parameters)
Define the corner relief in the conversion feature dialog box (Feature > Create > Conversion)
You can use and dimension corner relief that is smaller than the deformation area bordered by the tangent lines of the intersecting bends.
To Create Corner Relief (Feature)
Click or click Insert > Corner Relief. The GET SELECT menu appears.
Select the 3D Note(s) needing similar corner relief. Click Done Sets.
Define the corner relief to apply:
No Relief—No relief is added. The corner retains the rip characteristic.
None—Generates a square corner. The default V-notch characteristic is removed.
Circular—Adds a circular relief. The corner has a circlular section removed.
Obround—Adds an obround relief. The corner has an obround section removed.
Define the dimensions for the relief:
Thickness—Uses a default radius that is equal to the thickness of the sheet metal wall.
Thickness * 2—Uses a default radius that is twice the thickness of the sheet metal wall.
Enter Value—Uses the absolute value that you type in the Enter dimension value box.
To relieve another corner, click Add. Click Done Sets after selecting all desired corners.
Click OK on the CORNER RELIEF dialog box. The corner relief is created.
