返回列表 发新帖
【资料】【灌水】i-deas...............
发表于 2003-1-14 15:25:44 | 只看该作者
Oh ,my god,太多E文了。得仔细看看8D
发表于 2003-1-14 15:26:31 | 只看该作者
看得眼花了,停水!
发表于 2003-1-27 16:25:05 | 只看该作者
Hello there.
After years in discussion I can say that PRO/E and I-DEAS make the same
things.
The only difference is PRO/E has an ugly interface and method to
approach
than I-DEAS.
But everyone has the ways to have complex surfaces modeling done.
I prefere using I-DEAS and take in mind that PRO/E life seems to be
quite
short.
These are my 2cents.
-----Messaggio originale-----
Da: owner-iccon-des@loki.sdrc.com
[mailtowner-iccon-des@loki.sdrc.com]Per
conto di Chris Sonon
Inviato: venerdi 24 gennaio 2003 18.45
A: Stephen_Schoonmaker@groveworldwide.com; meinolf.droste@web.de
Cc: iccon-des; owner-iccon-des@loki.sdrc.com
Oggetto: RE: [iccon-des] I-DEAS vs. UG-NX vs. Pro/E
Finally what I always wanted to see, everyone saying how horrible Pro-E
is.  I have been using I-deas for about 3 years and LOVE it.  I am now
learning Pro-E and I feel like shooting myself sometimes.  It is
horrible you have to go through so much "CRAP" to just extrude a
wireframe.  OOPS.. I mean a sketch.  There are much better cheaper
programs out there then Pro-E that work a lot better.  SolidWorks is
one
for example.
Chris
Christopher Sonon
Senior Drafter/System Administrator
Iron Mountains LLC
(610)913-6883
-----Original Message-----
[mailto:Stephen_Schoonmaker@groveworldwide.com]
Sent: Friday, January 24, 2003 8:53 AM
To: meinolf.droste@web.de
Subject: Re: [iccon-des] I-DEAS vs. UG-NX vs. Pro/E
Meinolf,
I do not have much experience with NX, but my "current" employer has
been
bought by a company that thinks we should use Pro/E.  I was then
"blessed"
with a copy of the latest version of Pro/E.  My experience with this
program is that it is devoid of usefulness in comparison to I-DEAS.
Pro/E is a program for making parts, not designing serious products
(such
as cranes, cars, boats, planes).  With the exception of John Deere and
Caterpillar, I don't know any OEM's (Original Equipment Manufacturers -
not
suppliers) that use Pro/E.
Even though Pro/E is a part making program, it still is of no value to
me.
You do not build sections in Pro/E.  The entities you sketch MUST be
used
in the feature.  You can not make "wireframe" that is helpful for
capturing
design intent, and then chose not to have that geometry used in the
section.  When doing sketching, their "icon panel" has about 6 icons.
You
get the icon panel when you use something called 'Intent Manager'.  The
buffoons who think Pro/E is a great program all say you have to turn
off
'Intent Manager' to get really good control of sketching.  Well, who
wants
a GUI anyway, it is only been 20 years since using DOS commands was
"state
of the art".  With the 'Intent Manager' off, you play this guessing
game
of
"I wonder if this will work", then you hit 'Update' (they call it
'Regenerate') and you find out if your guesses were good ones.  It is
completely useless.
Don't forget that in Pro/E you have to constrain your sketch.  There is
no
wireframe turning Green, Yellow, Blue as you decide how YOU want to
constrain.  There is nothing like 'Show Free'.
I never saw anything like "boolean operations" in Pro/E.  You can't
make
parts and then Join/Cut/Intersect.  You have to make a "linear" history
"tree" (no bushy trees ever).  If you are a part supplier, then fine,
make
parts that way.  But as an OEM, I need to make "dummy" parts that just
help
us design around components.  I could never do this efficiently in
Pro/E.
Oh, by the way, you can't put 2 parts on the "workbench".  If you open
another part, Pro/E starts a new window, and you can't do anything
between
the 2 windows (no measuring or anything).  The only way to get 2 parts
on
the workbench is to make an assembly.  And, of course, you can't put
those
parts in the assembly (just so you can see them) without going through,
you
guessed it - Constraining.  And the assembly constraining in just like
I-DEAS at version 4 where you had 'Line-to-Line' and 'Face-to-Face'.
What
fun that was!  I didn't see anything like Assembly Dimensions, where
YOU
decide how you want to constrain the part, and to what degree.  And, of
course, nothing like Green, Yellow, Blue for constraining, and nothing
like
the 'Assembly Browser' or 'Show Free'.  I didn't see animations
anywhere.
I didn't see configs anywhere.
Forget using Right Mouse Button for anything like 'Measure', 'Focus',
etc.
in any sort of manner.  Forget using a color wheel for making features
(everything was one color).
Drafting was really fun.  There is about 10 icons (total).  There is no
view projection capability.  After bringing in an assembly from 3-D, I
got
all the hidden lines as a grey color and all visible lines as white.  I
wanted to make the hidden lines dashed (you know something amazing like
an
industry standard going back 100 years), but even the Pro/E Hotline
said
you can't do it.  But, they offered to help me set up PEN MAPPING so
that
the hardcopy is good!  Woo hoo (pump your arm or spin your finger in
the
air with that).  Pen mapping was "out" and WYSIWYG was "in" about 10
years
ago (maybe in Massachusetts or Bangalore they're in a time warp).
If you don't like data management (as in you want to get the parts NOW
and
screw the rest of the team), then Pro/E is for you.  It doesn't come
with a
data management scheme.  There is stuff like Intralink, Commonspace,
and
Windchilli, but it is all an "add on" of some kind.  I haven't played
with
Intralink yet, but current Pro/E users in our parent company says that
in
order to work as a team, you have to MANUALLY place locks on items that
may
affect other members of the team, and as such (surprise!) it does not
get
done.  They decided to make each of the 3-D models they made
independent
(no reusing parts).  That sounds good!
How about Pro/E FEA?  I don't know anyone that uses it (even our parent
company users use Nastran).  I-DEAS is the ONE AND ONLY package that
has
"real" CAD and "real" FEA.  Period.
How about legacy data?  Forget it.  We have 100,000's of drawings in
CADAM
format archives.  Practically every day we use an I-DEAS translator to
get
at these old drawings.  Pro/E Hotline said that is not available in
Pro/E.
Every Pro/E site I am aware of (and there are many I am aware of) uses
CAD programs - one for legacy and one for the new stuff.  If you want
to
make sure your engineering department is chaos, use 2 CAD programs with
data bases.
It is my fervent hope that my rantings will "innoculate" any I-DEAS
users
from thinking Pro/E is probably just like I-DEAS once you really use
it.
It is an old program, and it is easy to see why PTC (the company that
made
it) is a company in big trouble (stock is about $2 and Nasdaq has
de-listed
their PTC symbol for not meeting SEC requirements for reporting
finances).
Later,
发表于 2003-1-27 16:29:48 | 只看该作者
Wow, I guess I am one of the buffoons mentioned earlier.  I switched
jobsand software about three years ago going from Pro-e to Ideas.  I admit
I ammostly a part modeler, leaning towards more complex parts and fairly
simpleassemblies.  Five years of Pro-e vs three of Ideas doesn't leave me to
biased, I don't think.  If given the choice I would switch back to Pro-e in
a heartbeat.  Although I will add that they could of screwed it up in the
last few releases and I wouldn't know it.
Kevin
Sent: Friday, January 24, 2003 12:45 PM
To: Stephen_Schoonmaker@groveworldwide.com; meinolf.droste@web.de
Subject: RE: [iccon-des] I-DEAS vs. UG-NX vs. Pro/E
one
for example.
Chris
Christopher Sonon
Iron Mountains LLC
(610)913-6883
Meinolf,
beenbought by a company that thinks we should use Pro/E.  I was then
"blessed"with a copy of the latest version of Pro/E.  My experience with this
(suchas cranes, cars, boats, planes).  With the exception of John Deere and
not suppliers) that use Pro/E.
me.You do not build sections in Pro/E.  The entities you sketch MUST be
usedin the feature.  You can not make "wireframe" that is helpful for
capturing design intent, and then chose not to have that geometry used in the
You get the icon panel when you use something called 'Intent Manager'.  The
off 'Intent Manager' to get really good control of sketching.  Well, who
wants a GUI anyway, it is only been 20 years since using DOS commands was
"state of the art".  With the 'Intent Manager' off, you play this guessing
game of "I wonder if this will work", then you hit 'Update' (they call it
completely useless.
no wireframe turning Green, Yellow, Blue as you decide how YOU want to
make 2 parts and then Join/Cut/Intersect.  You have to make a "linear" history
make parts that way.  But as an OEM, I need to make "dummy" parts that just
help us design around components.  I could never do this efficiently in
Pro/E.
between the 2 windows (no measuring or anything).  The only way to get 2 parts
on the workbench is to make an assembly.  And, of course, you can't put
those parts in the assembly (just so you can see them) without going through,
you guessed it - Constraining.  And the assembly constraining in just like
What fun that was!  I didn't see anything like Assembly Dimensions, where
YOU decide how you want to constrain the part, and to what degree.  And, of
like the 'Assembly Browser' or 'Show Free'.  I didn't see animations
anywhere.
etc. in any sort of manner.  Forget using a color wheel for making features
got all the hidden lines as a grey color and all visible lines as white.  I
an industry standard going back 100 years), but even the Pro/E Hotline
said you can't do it.  But, they offered to help me set up PEN MAPPING so
that the hardcopy is good!  Woo hoo (pump your arm or spin your finger in
the air with that).  Pen mapping was "out" and WYSIWYG was "in" about 10
years ago (maybe in Massachusetts or Bangalore they're in a time warp).
and screw the rest of the team), then Pro/E is for you.  It doesn't come
with a data management scheme.  There is stuff like Intralink, Commonspace,
and Windchilli, but it is all an "add on" of some kind.  I haven't played
with Intralink yet, but current Pro/E users in our parent company says that
in order to work as a team, you have to MANUALLY place locks on items that
may affect other members of the team, and as such (surprise!) it does not
get done.  They decided to make each of the 3-D models they made
independent (no reusing parts).  That sounds good!
has "real" CAD and "real" FEA.  Period.
CADAM format archives.  Practically every day we use an I-DEAS translator to
get at these old drawings.  Pro/E Hotline said that is not available in
Pro/E.
2 CAD programs - one for legacy and one for the new stuff.  If you want
to make sure your engineering department is chaos, use 2 CAD programs with
2 data bases.
users from thinking Pro/E is probably just like I-DEAS once you really use
it.
made it) is a company in big trouble (stock is about $2 and Nasdaq has
de-listed their PTC symbol for not meeting SEC requirements for reporting
finances).
Later,
Steve
Hi Folks,
are there any expierences with the latest releases of UG and Pro/E ?
At this moment we at Giersch use I-DEAS 9, starting working with I-DEAS
in 1995. Two other companies from our group, one in UK and one in
sweden, works with ACAD / Mechanical Desktop, and one of this divisions
wants to switch to Pro/E.
Our roadmap had been to use the EDS NX if there will be a stable
release wich allows us to save our work from the last 8 years. Now it's getting
a little more difficult because we don't want to make new invest of for
I-DEAS software and training at the other locations and in about two or
three years switch to NX, too.
So my idea was to use NX in UK and sweden, and also use NX for new
projects at Giersch.
Our problem is that the swedish guys wants Pro/E, but then we will
loose lots of invest for software and training, and most of the work from the
past. What I need is information about pro's and contra's about Pro/E and NX.
I have some basic knowledge about older Pro/E releases, but not the
newer one, and next week we will have presentations of UG-NX and Pro/E
Wildfire.
thanks a lot
Meinolf
发表于 2003-2-9 12:19:30 | 只看该作者
zlz1976兄的E文似乎很好,这些个“羊”水从哪里引来的?有时间我们也去游上一番。
发表于 2003-2-9 14:38:38 | 只看该作者
好想学哦!!!
可惜我的E文太浪。。。。
GMT+8, 2024-12-27 00:09 , Processed in 0.025224 second(s), 9 queries , Gzip On, Redis On.
© 2002-2024 www.iCAx.org
