123
返回列表 发新帖
个人经验-SOLIDWORKS如何转到3DMAX中渲染
发表于 2006-2-26 21:41:40 | 只看该作者
学习
22
发表于 2006-3-3 16:54:22 | 只看该作者
学习
23
发表于 2008-4-22 07:59:06 | 只看该作者
为什么我在另存SOLID WORKS 为STL文档时,存出来的都是很多分散的小零件啊?一个个的导入不是也很麻烦的一件事情吗?有什么改变的方法吗?
24
发表于 2008-4-22 08:44:55 | 只看该作者
又发现一个问题
SW导入到MAX中的物体时本来SW的一个面到MAX时分为许多的小面的了,当我要渲染多种材质的时候怎么分ID号啊,一个个的面选点着分的话,我眼睛和毅力可真的没有那么好哦,有那个大虾能帮忙解决啊?
25
发表于 2008-6-2 08:51:55 | 只看该作者
Does anybody know how to export solidwork files to 3DMax4 in a good quality. I have been trying stl but they don't look good. Other extention don't work neither.
I need to do some part in Max and make the renderings from there too.
Any sugestion?
Thanks
export as an STL from solidworks go in to the options put the settings to fine.
import the stl in to max, mae sure u select quick weld and smoothing when the import options appear. if the smoothing doesn't wokr properly import the STL again but turn off smoothing, then apply a smooth modifer to the stl where u can adjust the values of the modifer.
u can try using IGES but it normal ****s up when brough in t ax, like the surfaces are back to front...etc....i have heard SAT is a good file format to use but i think both SAT and IGES produce very large file sizes...so are to be avoided in max...realy if u can get away with it.
i used solidworks + max to prodcue this image
轉載(工業設計論壇)
https://www.core77.com/ubb/Forum10/HTML/000474.html
詳細的做法
https://www.cadmonkey.com/tut8.htm
[ 本帖最后由 gordianknot 于 2008-6-2 09:07 编辑 ]
26
发表于 2008-6-2 11:48:17 | 只看该作者
可以做流水的动画,效果动画简单。但是逐帧动画很不好做,(我比较菜)。
27
发表于 2008-6-2 19:41:10 | 只看该作者
看了大家发言,学习了不少!
28
发表于 2008-6-3 11:28:05 | 只看该作者
ddddddddddddddddddddddddddddddddddddddd
GMT+8, 2025-4-26 00:39 , Processed in 0.024139 second(s), 12 queries , Gzip On, Redis On.
