查看: 27441|回复: 6
[求助] 计算时提示“Exception 11 detected”
发表于 2006-2-27 23:41:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
求教各位大虾,我用的是Adams 2005,最近几次总是在建好模型,开始进行仿真计算时弹出Text Output提示说
关闭提示窗口后,如果再次计算程序就会被Windows关闭
哪位大虾可以提示一下这是那方面的原因呢~~~
发表于 2006-3-7 13:32:23 | 只看该作者
哪位大虾可以解释一下吗 ~~
aview.log
! ADAMS/View 2005.0.0 (built Jul 22 2004)
! Graphics:  Hoops/null
! Enter a command, '?', or 'help'.
var set var = .mdi.errno int=0
if cond=0
   variable set variable=.gui.moag.c_simulate.run.tmpScriptName &
     string = (eval( db_default( .system_defaults, "model" )//"."//unique_name("SIM_SCRIPT") ))
   simulation script create  &
     type             = auto_select   &
     end_time        = 5.0         &
     number_of_steps = 50  &
      sim_script_name =  (eval(.gui.moag.c_simulate.run.tmpScriptName))
   simulation single scripted &
      sim_script_name = (eval(.gui.moag.c_simulate.run.tmpScriptName)) &
      reset_before_and_after = yes
   simulation script delete sim_script_name = (eval(.gui.moag.c_simulate.run.tmpScriptName))
   variable delete variable=.gui.moag.c_simulate.run.tmpScriptName
else
  simulation single trans &
     end_time        = 5.0         &
! EXCEPTION: signal number 11
end
mdi gui_utl_check_sim alert_done=no alert_stop=no
var set var = .mdi.errno int=0   ! in case a simulation is running
quit conf=no
aview.loq
!  SELECT OBJECT
undo begin
group modify group=SELECT_LIST object=.model_1.PART_2
undo end
!  SELECT OBJECT
undo begin
group empty group=SELECT_LIST
undo end
!  SELECT OBJECT
undo begin
group modify group=SELECT_LIST object=.model_1.PART_2.MARKER_4
undo end
!  SELECT OBJECT
undo begin
undo end
!  SELECT OBJECT
undo begin
group modify group=SELECT_LIST object=.model_1.gravity
undo end
!  SELECT OBJECT
undo begin
undo end
int field set field=.gui.sim_int_panel.end_time strings="5.0"
int field set field=.gui.sim_int_panel.number_of_steps strings="50"
int opt set opt=.gui.sim_int_panel.stepsize_steps_option choice="Steps" exec = yes
if cond=( "" == "step size" )
   interface field    display field_name=.gui.sim_int_panel.c_interactive.step_size
   interface field undisplay field_name=.gui.sim_int_panel.c_interactive.number_of_steps
else
   if cond=("" == "Forever")
      mdi gui_utl_alert_box_1 type=error text="You cannot specify number of steps when running forever."
      interface option set option = .gui.sim_int_panel.c_interactive.stepsize_steps_option choice = "Step Size"
   else
      interface field    display field_name=.gui.sim_int_panel.c_interactive.number_of_steps
      interface field undisplay field_name=.gui.sim_int_panel.c_interactive.step_size
   end
end
int opt set opt=.gui.sim_int_panel.end_time_duration_option choice="End Time" exec = yes
if cond=( "" == "End Time" )
   interface field    display field_name=.gui.sim_int_panel.c_interactive.end_time
   interface field undisplay field_name=.gui.sim_int_panel.c_interactive.duration
elseif cond=( "" == "Duration" )
   interface field    display field_name=.gui.sim_int_panel.c_interactive.duration
   interface field undisplay field_name=.gui.sim_int_panel.c_interactive.end_time
elseif cond=( "" == "Forever" )
   interface field undisplay field_name=.gui.sim_int_panel.c_interactive.end_time, .gui.sim_int_panel.c_interactive.duration
   interface option set option = .gui.sim_int_panel.c_interactive.stepsize_steps_option choice="Step Size" exec=yes
end
int opt set opt=.gui.sim_int_panel.simulation_type value="auto_select" exec = yes
int dialog_box dis dialog_box=.gui.sim_int_panel
executive set numerical model = .model_1  &
   integrator  = gstiff    &
   formulation = i3        &
   corrector   = original  &
   error       = 1E-3      &
   hmax        = (none)    &
   hmin        = (none)    &
   hinit       = (none)    &
   adaptivity  = 0         &
   interpolate = no        &
   kmax        = 6         &
   maxit       = 10        &
   scale       = 1.0, 1.0, 1.0E-003
interface dialog undisplay dialog=.gui.sim_set_panel
abort stop_all_commands=no
mod ver
interface dialog undisplay dialog=.gui.info_window
发表于 2009-3-28 10:12:48 | 只看该作者
我也遇上同样的问题了,网上到处搜,也没找到解决的方法,重装了ADAMS都不行,看来只能重装系统了!郁闷啊……原来一直正常的,不知道怎么回事儿就突然出现这个问题了
发表于 2009-5-13 02:22:58 | 只看该作者
這是一個有趣的討論。感謝您分享..
simulation rachat de credit
发表于 2010-3-20 16:57:48 | 只看该作者
晕死,内存不足
重装什么系统啊
发表于 2010-3-20 16:57:58 | 只看该作者
晕死,内存不足
重装什么系统啊
发表于 2014-12-22 15:28:53 | 只看该作者
我也遇见这个问题,之前一起做的好几个模型,一直计算好好的,但是今天有的可以正常计算,有两个模型载入adams2013环境中后,每一次只要是首次点击计算就会出现“exception 11 detected”窗口提示,忽略该窗口即关闭该窗口,继续点击计算按钮,就会出现“已有一个仿真正在运行,请在运行新的仿真之前,终止第一个仿真,或等该其运行结束”的提示,即使我手动终止仿真或复位仿真,只要点击运行仿真按钮,就出现第二种提示?
GMT+8, 2025-10-19 22:50 , Processed in 0.095435 second(s), 13 queries , Gzip On, Redis On.
