! ** Copyright 1992 UGS Corp. All Rights Reserved. **
! ** Welcome to the Unigraphics Customer Defaults File **
! ** This defaults file is no longer used in NX3.0. The customer defaults **
! ** mechanism has changed to use an interactive dialog to record up to **
! ** three hierarchical levels of customizations to the customer defaults. **
! ** The new dialog is found at File -> Utilities -> Customer Defaults **
! ** The following files are no longer user to record changes to the **
! ** customer defaults **
! ** ug_english.def **
! ** ug_metric.def **
! ** ug_modeling.def **
! ** ug_cam.def **
! ** ug_smd.def **
! ** ug_bodydes.def **
! ** ug_die.def **
! ** ug_cae_motion.def **
! ** The following environment variables are no longer used to control **
! ** UGII_DEFAULTS_FILE **
! ** UGII_MODELING_DEFAULTS_FILE **
! ** UGII_CAM_DEFAULTS_FILE **
! ** UGII_SMD_DEFAULTS_FILE **
! ** UGII_BODYDES_DEFAULTS_FILE **
! ** UGII_DIE_DEFAULTS_FILE **
! ** UGII_CAEMOTION_DEFAULTS_FILE **
! ** See the NX3 What's New guide and the Gateway -> Customer Defaults **
! ** section of the on-line documentation for additional details, **
! ** and for instructions on setting up the customization files. **
