有鬼啊.
发表于 2003-2-14 19:27:06 | 只看该作者
转成别的文件格式在转进来,试一下。
发表于 2003-2-14 22:18:05 | 只看该作者
看看这个。
大家遇到问题可以heal一把,很多时候就ok了。
斑竹,不好意思加分吧。(嘿嘿,我分太少)
发表于 2003-2-15 00:15:03 | 只看该作者
chuck wrote:
看看这个。
::y::y::y::y
说明一下heal
发表于 2003-2-15 00:55:25 | 只看该作者
The application exports the work part to another Unigraphics NX part to perform any required healing operations on the selected solid and sheet bodies. As a result, after healing completes the work part is the same as before the application starts.
In addition, healing does not retain associativity (with the healed bodies) that the original bodies had with drawing data, assembly reference sets, or any other type of associativity links.
For face spikes and slivers, the heal tolerance is an upper limit on the face width, below which healing occurs. Faces whose maximum width is less than the heal tolerance, viz., sliver faces, always undergo complete removal.
Heal Geometry removes surface self-intersections when the problem area is outside of the owning face's boundary. Self-intersections inside the face boundary are not healed.
Heal Geometry can also simplify a B-spline to an analytic surface whenever the B-spline is within the input tolerance of an analytic surface. For example, a B-surface that is planar except for one pole that is off the plane that contains the other poles, will simplify to a plane.
Heal Geometry repairs various topology corruption type problems, and reduces edge tolerances (whenever possible) even though the edges may not be connected to a tiny object.
Annotational (non-body) Changes to the Exported Part
Any healed bodies acquire the attribute name GEOHEAL_HEALED_BODY in order to easily distinguish bodies requiring healing from those that do not. Unigraphics NX features do not carry forward to the healed bodies.
发表于 2003-2-15 08:31:11 | 只看该作者
请问怎么使用啊
发表于 2003-2-15 10:05:43 | 只看该作者
export
发表于 2003-2-15 10:12:12 | 只看该作者
多谢!
18
发表于 2003-2-15 10:12:06 | 只看该作者
一般进入NC的第一步是:检查几何数据
该PART几何数据有些问题
发表于 2003-2-15 10:12:45 | 只看该作者
放大其中一个点
发表于 2003-2-15 10:14:15 | 只看该作者
EXPORT IGES,也可以修复很多这种问题
HEAL的结果
GMT+8, 2025-4-20 00:24 , Processed in 0.024285 second(s), 12 queries , Gzip On, Redis On.
