返回列表 发新帖
【求助】AutoCAD2000 中是否可以在打印时,将所有图形的线宽加宽.
发表于 2003-2-14 13:10:01 | 只看该作者
Procedure to change line weight of individual object
  1. Command : LW, then choose [display lineweight]
  2. Turn on [LWT] botton which located on the status row (bottom of    the screen)
  3. Select objects (line , polyline or spline ... etc.) which you prefer to change lineweight
  4. It is suitable to use in drawing outter or inner  circle of 2D screw
  5. Pull down the [lineweight list] , and choose the proper lineweight
       ps :  a. [Lineweight pull down list] is located at the right side next to [Linetype pull down list] of STANDARD TOOLBAR
               b. lineweight also work on .SHX text
               c. Before changing Dimsion text , you must explode the dimensin first to separate text from dimension line
发表于 2003-2-14 13:45:49 | 只看该作者
你这主要是为了DISPLAY  打印的话层已经包含了这一步
发表于 2003-2-15 21:06:13 | 只看该作者
Don't set lineweight when setting layer, use the method I suppose
and then print it, may be you will know what I mean.
发表于 2003-2-18 15:06:06 | 只看该作者
用过滤器根据颜色,图层等进行筛选,
然后通过对象属性对话框进行修改。
autocad中图形对象最好依据图层进行管理,
否则,比较麻烦。
GMT+8, 2025-4-20 23:08 , Processed in 0.021659 second(s), 11 queries , Gzip On, Redis On.
