返回列表 发新帖
如何把野火2.0的英文转化成中文?
发表于 2006-3-15 15:51:50 | 只看该作者
用写字板写一个config.pro:
allow_anatomic_features YES
bell NO
display HIDDENVIS
display_full_object_path YES
default_dec_places 3
default_object_invalid_refs prohibit
default_object_scope_setting all
fix_boundaries_on_import yes
intf3d_in_close_open_boundaries yes
linear_tol 2 0 .15
help_translation yes
menu_translation both
model_tree_start YES
multiple_skeletons_allowed yes
new_relation_ui yes
pro_unit_length UNIT_MM
pro_unit_mass UNIT_KILOGRAM
reserved_menu_space 0
save_objects changed
set_menu_width 5
sketcher_dec_places 2
save_model_display shading_lod
shade_mfg_ref_models yes
save_bitmap NONE
smooth_lines yes
spin_center_display no
spin_with_part_entities yes
tol_display no
tol_mode nominal
tolerance_standard ISO
topobus_enable yes
web_browser_homepage https://ivproe.com
prehighlight yes
mdo_density 7.85e-6
file_open_default_folder working_directory
dialog_translation yes
msg_translation yes
activate_sketch_with_dflt yes
发表于 2006-3-15 16:40:40 | 只看该作者
写好了,放在哪个文件夹里面呀,
要不要覆盖原来的文件?
发表于 2006-3-15 16:48:02 | 只看该作者
打开可以用,还是全英文呢,提示这个东东:
Pro/ENGINEER could not initialize the specified locale "chinese_cn" and has reverted to running in English.
Please check the locale settings before re-launching Pro/ENGINEER.
发表于 2006-3-15 17:04:59 | 只看该作者
还是英文的,提示:
GMT+8, 2025-4-26 08:12 , Processed in 0.023761 second(s), 10 queries , Gzip On, Redis On.
