【推荐】pro/e2001隐藏系统参数探密!
发表于 2003-2-17 13:02:18 | 只看该作者
隐藏的参数,当输入前面的词后,后面不会有提示,value里面也不会有东东,find也找不到,但设置完就会有其它功能的出现,这就需要大家有时间或耐力,当有什么发现时,希望能与大家分享!
设置方法:utilities----option
发表于 2003-2-17 15:26:05 | 只看该作者
果然是哦
23
发表于 2003-2-17 18:22:21 | 只看该作者
zle77 wrote:
weld_edge_prep_visibility            Generic, Instance
  Generic - 边准备特征在普通模型中恢复,而在实例中隐含。
  Instance - 边准备特征在普通模型中隐含,而在实例中恢复。
  仅在weld_edge_prep设置为yes时适用。
::y::y::y
24
发表于 2003-2-17 19:56:20 | 只看该作者
孤独剑 wrote:
All config.pro options for 2001
  18_PLUS (hidden)
  19_PROJ_ANGLE (hidden)
  19_PROJ_BOUNDARY (hidden)
  19_PROJ_CHAMFER (hidden)
  19_PROJ_CSYS (hidden)
  19_PROJ_DEPTH (hidden)
  19_PROJ_DRAFT (hidden)
  19_PROJ_DTMAXIS (hidden)
  19_PROJ_DTMCRV1 (hidden)
  19_PROJ_DTMCRV (hidden)
  19_PROJ_DTMPLANE (hidden)
  19_PROJ_DTMPNT (hidden)
  19_PROJ_PATTERN (hidden)
  19_PROJ_PROTRUSION (hidden)
  19_PROJ_SHELL (hidden)
  19_PROJ_SMT_CONVERSION (hidden)
  19_PROJ_SMT_TWIST (hidden)
  19_PROJ_SRFOFFS (hidden)
  19_PROJ_SWEEP (hidden)
  19_PROJ_SWEPT_BLEND (hidden)
  19_PROJ_THREAD (hidden)
  19_PROJ_USEQLT (hidden)
  21_PROJ_ANL (hidden)
  22_PRJ_HOLE_THRD_CORR (hidden)
  2BUTTON_MOUSE_MMB_SUPPORT
  2_5_LOCAL_MILL (hidden)
  3D_THICKNESS_CHECK (hidden)
  5_AXES_REMAINDER_SURFACE (hidden)
  5_AXIS_SIDE_MILL (hidden)
25
发表于 2003-2-17 21:41:21 | 只看该作者
直接用下面的config.pro都加上了呦!!Pro\engineer config.pro -
::b::b::b::b::b::b::b::b::b::b::b::b::b::b
Release 2001(2001280)
!Copyrigh by XIAO TIAN
!FEB 2001 (SHANGHAI)
! ****** Welcome to read the config.pro ******
nccheck_type NCCHECK
bell no
allow_anatomic_features YES
default_dec_places 4
default_draw_scale 1
delete_after_plotting YES
display HIDDENINVIS
datum_display NO
datum_point_display NO
family_table_editor PROTAB
fix_boundaries_on_import YES
fix_catia_iges_sym_note YES
fix_imported_set_view_orient YES
graphics OPENGL
grid_snap NO
HARDWARE_OPTIONS NO_OPTIONS
highlight_new_dims YES
allow_old_style_round YES
IGES_IN_DWG_VIEW YES
iges_in_group_to_dwg_layer YES
IGES_IN_LAYER_FILTER NO
iges_note_disp AS_IS
iges_out_all_srfs_as 128
iges_out_dwg_color YES
iges_out_jamais_compliant NO
iges_out_mil_d_28000 NO
iges_out_spl_crvs_as_126 NO
iges_out_spl_srfs_as_128 YES
iges_out_trim_curve_deviation DEFAULT
Iges_out_trim_srfs_as_143 NO
iges_out_trim_xyz NO
iges_zero_view_disp AS_IS
info_output_mode SCREEN
intf3d_in_close_open_boundaries YES
INTF3D_OUT_EXTEND SURFACE YES
INTF_CATIA_VERSION 4
intf_in_blanked_entities YES
intf_out_as_bezier NO
intf_out_auto_layer_ids YES
intf_out_blanked_entities YES
kbd_cmd_abbreviation ON
LANDSCAPE_POSTSCRIPT_PRINT NO
lods_enabled Yes
make_parameters_from_fmt_tables YES
max_animation_time 0
MENU_HORIZONTAL_HINT RIGHT
menu_translation both
model_tree_start YES
orientation TRIMETRIC
override_store_back YES
pen_table_file E:\AA\PLOTCONF\TABLE.PNT
plotter_command WINDOWS_PRINT_MANAGER DEFAULT
plotter LASERJET4
pro_dtl_setup_dir E:\AA
pro_editor_command notepad
pro_format_dir E:\AA\LABELS
pro_group_dir E:\AA\UDF
pro_library_dir E:\AA\UDF
pro_material_dir E:\AA\UDF
pro_mf_cl_dir E:\AA\NC
pro_mf_param_dir E:\AA\FEED
pro_mf_tprm_dir E:\AA\TOOL
pro_mf_workcell_dir E:\AA\WORKCELL
pro_plot_config_dir E:\AA\PLOTCONF
pro_unit_length UNIT_MM
provide_pick_message_always YES
query_bin_start YES
relation_file_editor PROTAB
repeat_datum_create YES
mfg_customize_dialog yes
mfg_auto_ref_prt_as_chk_srf yes
save_display yes
save_objects ALL
save_triangles_flag YES
search_path_file E:\AA\SEARCH.PRO
set_trail_single_step NO
shade_mfg_ref_models yes
sketcher_dec_places 4
sketcher_intent_manager YES
sketcher_old_default_grid no
SKETCHER_README_ALERT NO
sketcher_readme_button NO
sketcher_starts_in_2d NO
spin_center_display NO
spin_control DRAG
symbol_palette_input YES
system_colors_file E:\AA\SYSCOL.SCL
TEXT_ORIENTATION PARALLEL
todays_date_note_format %yy/%mm/%dd
tol_mode NOMINAL
trail_dir E:\AA\TRAIL
USE_DIMENSIONED_EDGES YES
USERGUIDE_HELP YES
windows_scale 0.99
! ***** FUNCTION KEYS ******
mapkey $F1 ~ Activate `main_dlg_cur` `ProCmdViewZoomIn.utils`;
mapkey $F2 ~ Activate `main_dlg_cur` `ProCmdViewZoomOut.utils`;
mapkey $F3 ~ Activate `main_dlg_cur` `ProCmdViewRefit.utils`;
mapkey $F4 ~ Select `main_dlg_cur` `MenuBar1`1 `Analysis`;\
mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\
mapkey(continued) ~ Activate `main_dlg_cur` `Analysis.psh_analysis_measure`;\
mapkey(continued) ~ Open `measure` `MsrTypeOptions`;~ Close `measure` `MsrTypeOptions`;\
mapkey(continued) ~ Select `measure` `MsrTypeOptions`1 `Distance`;
mapkey $F5 ~ Select `main_dlg_cur` `MenuBar1`1 `Analysis`;\
mapkey(continued) ~ Select `measure` `MsrTypeOptions`1 `Angle`;\
mapkey(continued) ~ Open `measure` `Angle1stEntOptions`;~ Close `measure` `Angle1stEntOptions`;\
mapkey(continued) ~ Select `measure` `Angle1stEntOptions`1 `Plane`;\
mapkey(continued) ~ Open `measure` `Angle2ndEntOptions`;~ Close `measure` `Angle2ndEntOptions`;\
mapkey(continued) ~ Select `measure` `Angle2ndEntOptions`1 `Plane`;\
mapkey(continued) ~ Activate `measure` `Angle1stEntSelect`;
mapkey $F6 ~ Select `main_dlg_cur` `MenuBar1`1 `Analysis`;\
mapkey(continued) ~ Activate `main_dlg_cur` `Analysis.psh_analysis_surfanl`;\
mapkey(continued) ~ FocusIn `srfanal` `srfanal`;~ FocusIn `srfanal` `srfanal`;\
mapkey(continued) ~ Open `srfanal` `TypeOptionMenu`;~ FocusIn `srfanal` `srfanal`;\
mapkey(continued) ~ Close `srfanal` `TypeOptionMenu`;\
mapkey(continued) ~ Select `srfanal` `TypeOptionMenu`1 `Radius`;
mapkey $F7 ~ Select `main_dlg_cur` `MenuBar1`1 `Analysis`;\
mapkey(continued) ~ Activate `main_dlg_cur` `Analysis.psh_analysis_curvanl`;\
mapkey(continued) ~ FocusIn `curvanl` `curvanl`;~ Open `curvanl` `TypeOptionMenu`;\
mapkey(continued) ~ FocusIn `curvanl` `curvanl`;~ Close `curvanl` `TypeOptionMenu`;\
mapkey(continued) ~ Select `curvanl` `TypeOptionMenu`1 `Radius`;
mapkey $F8 ~ Select `main_dlg_cur` `MenuBar1`1 `View`;\
mapkey(continued) ~ Select `main_dlg_cur` `View.cb_view_mdlsetup`;\
mapkey(continued) ~ Close `main_dlg_cur` `View.cb_view_mdlsetup`;\
mapkey(continued) ~ Activate `main_dlg_cur` `psh_view_appearances`;
mapkey $F9 #VIEWS;#ADD VIEW;#SECTION;#DONE;#DONE;
mapkey $F10 #VIEWS;#ADD VIEW;#AUXILIARY;#SECTION;#DONE;#DONE;
mapkey $F11 ~ Select `main_dlg_cur` `MenuBar1`1 `File`;\
mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;~ Activate `main_dlg_cur` `File.psh_print`;\
mapkey(continued) ~ Select `print` `CascadeButton1`;~ Close `print` `CascadeButton1`;\
mapkey(continued) ~ Activate `print` `MS Printer Manager`;~ Activate `print` `Configure`;\
mapkey(continued) ~ Open `print_config` `o_size`;~ Close `print_config` `o_size`;\
mapkey(continued) ~ Select `print_config` `o_size`1 `A4`;~ Activate `print_config` `OK`;\
mapkey(continued) ~ Activate `print` `OK`;
mapkey $F12 ~ Select `main_dlg_cur` `MenuBar1`1 `Utilities`;\
mapkey(continued) ~ Activate `main_dlg_cur` `Utilities.psh_util_env`;\
mapkey(continued) ~ Open `env_dlg` `ModDsply_OptMenu_Style`;\
mapkey(continued) ~ Close `env_dlg` `ModDsply_OptMenu_Style`;\
mapkey(continued) ~ Select `env_dlg` `ModDsply_OptMenu_Style`1 `nohiddenline`;\
mapkey(continued) ~ Activate `env_dlg` `OK_`;~ Select `main_dlg_cur` `MenuBar1`1 `File`;\
mapkey ` ~ Select `main_dlg_cur` `MenuBar1`1 `Windows`;\
mapkey(continued) ~ Activate `main_dlg_cur` `Windows.psh_win_activate`;
mapkey f ~ Activate `main_dlg_cur` `ProCmdViewRepaint.utils`;
mapkey rm ~ Select `main_dlg_cur` `MenuBar1`1 `File`;\
mapkey(continued) ~ Activate `main_dlg_cur` `File.psh_rename`;~ Select `rename` `ph_model.cb`;\
mapkey(continued) ~ Close `rename` `ph_model.cb`;~ Activate `rename` `Select`;#SEL BY MENU;
mapkey ch ~ Select `main_dlg_cur` `MenuBar1`1 `Analysis`;\
mapkey(continued) ~ FocusIn `srfanal` `srfanal`;~ Open `srfanal` `TypeOptionMenu`;\
mapkey(continued) ~ FocusIn `srfanal` `srfanal`;~ Close `srfanal` `TypeOptionMenu`;\
mapkey(continued) ~ Select `srfanal` `TypeOptionMenu`1 `DraftCheck`;\
mapkey(continued) ~ Open `srfanal` `DraftSelSrf_menu`;~ FocusIn `srfanal` `srfanal`;\
mapkey(continued) ~ Close `srfanal` `DraftSelSrf_menu`;\
mapkey(continued) ~ Select `srfanal` `DraftSelSrf_menu`1 `PART`;\
mapkey(continued) ~ Select `srfanal` `DraftOpt_rad`1 `2`;\
mapkey(continued) ~ Update `srfanal` `DraftAngle_pan` `0.250000`;\
mapkey(continued) ~ Activate `srfanal` `SetDisp_btn`;~ Activate `dasetup` `ok`;\
mapkey dl #FEATURE;#DELETE;#SEL BY MENU;#LAST FEATURE;#DONE;#DONE;
mapkey sh ~ Select `main_dlg_cur` `MenuBar1`1 `Windows`;\
mapkey(continued) ~ Activate `main_dlg_cur` `Windows.psh_win_open_system`;
! ***** SKETCH & GEOM TOOLS KEYS ******
mapkey td #SKETCH;Yes;#RECTANGLE;
mapkey te #GEOM TOOLS;#USE EDGE;
! ******* To make views ********
mapkey im ~ Select `main_dlg_cur` `MenuBar1`1 `View`;\
mapkey(continued) ~ Activate `main_dlg_cur` `View.psh_view_panzoom`;\
mapkey(continued) ~ Activate `orient` `NmViewCheckBtn`1 ;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V`;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-`;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-F`;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-FR`;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-FRO`;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-FRON`;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-FRONT`;\
mapkey(continued) ~ Update `orient` `namedviewPH.NameVw_IP` `V-FRONT`;\
mapkey(continued) ~ Activate `orient` `namedviewPH.NameVw_PB_Save`;\
mapkey(continued) ~ Activate `orient` `spinPH.YSpinBox`90.000000 ;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-L`;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-LE`;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-LEF`;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-LEFT`;\
mapkey(continued) ~ Update `orient` `namedviewPH.NameVw_IP` `V-LEFT`;\
mapkey(continued) ~ Activate `orient` `spinPH.YSpinBox`-90.000000 ;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-R`;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-RI`;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-RIG`;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-RIGH`;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-RIGHT`;\
mapkey(continued) ~ Update `orient` `namedviewPH.NameVw_IP` `V-RIGHT`;\
mapkey(continued) ~ Activate `orient` `spinPH.YSpinBox`180.000000 ;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-B`;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-BA`;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-BAC`;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-BACK`;\
mapkey(continued) ~ Update `orient` `namedviewPH.NameVw_IP` `V-BACK`;\
mapkey(continued) ~ Activate `orient` `spinPH.YSpinBox`0.000000 ;\
mapkey(continued) ~ Activate `orient` `spinPH.XSpinBox`90.000000 ;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-T`;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-TO`;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-TOP`;\
mapkey(continued) ~ Update `orient` `namedviewPH.NameVw_IP` `V-TOP`;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-BO`;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-BOT`;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-BOTT`;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-BOTTO`;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `V-BOTTOM`;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` ``;\
mapkey(continued) ~ Update `orient` `namedviewPH.NameVw_IP` ``;\
mapkey(continued) ~ Activate `orient` `spinPH.XSpinBox`-90.000000 ;\
mapkey(continued) ~ Update `orient` `namedviewPH.NameVw_IP` `V-BOTTOM`;\
mapkey(continued) ~ Activate `orient` `spinPH.XSpinBox`0.000000 ;\
mapkey(continued) ~ Select `orient` `namedviewPH.NameVw_List`1 `Default`;\
mapkey(continued) ~ Activate `orient` `namedviewPH.NameVw_PB_SetCur`;\
mapkey(continued) ~ Activate `orient` `OkPB`;@MANUAL_PAUSESet view for A1SO;\
mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1 `View`;~ Close `main_dlg_cur` `MenuBar1`;\
mapkey(continued) ~ Activate `main_dlg_cur` `View.psh_view_named`;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v`;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-`;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-a`;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-a1`;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-a1s`;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-a1so`;\
mapkey(continued) ~ Update `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-a1so`;\
mapkey(continued) ~ Activate `vwsavretr` `VwSavRetr_PH.NameVw_PB_Save`;\
mapkey(continued) ~ Activate `vwsavretr` `Close`;@MANUAL_PAUSESet view for A2SO;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-a2`;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-a2s`;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-a2so`;\
mapkey(continued) ~ Update `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-a2so`;\
mapkey(continued) ~ Activate `vwsavretr` `Close`;@MANUAL_PAUSESet view for Z3SO;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-z`;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-z3`;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-z3s`;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-z3so`;\
mapkey(continued) ~ Update `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-z3so`;\
mapkey(continued) ~ Activate `vwsavretr` `Close`;@MANUAL_PAUSESet view for Z4SO;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-z4`;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-z4s`;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-z4so`;\
mapkey(continued) ~ Update `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-z4so`;\
mapkey(continued) ~ Activate `vwsavretr` `Close`;@MANUAL_PAUSESet view for Z5SO;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-z5`;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-z5s`;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-z5so`;\
mapkey(continued) ~ Update `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-z5so`;\
mapkey(continued) ~ Activate `vwsavretr` `Close`;@MANUAL_PAUSESet view for Z6SO;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-z6`;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-z6s`;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-z6so`;\
mapkey(continued) ~ Update `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-z6so`;\
mapkey(continued) ~ Activate `vwsavretr` `Close`;@MANUAL_PAUSESet view for Z7SO;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-z7`;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-z7s`;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-z7so`;\
mapkey(continued) ~ Update `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-z7so`;\
mapkey(continued) ~ Activate `vwsavretr` `Close`;@MANUAL_PAUSESet view for Z8SO;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-z8`;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-z8s`;\
mapkey(continued) ~ Input `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-z8so`;\
mapkey(continued) ~ Update `vwsavretr` `VwSavRetr_PH.NameVw_IP` `v-z8so`;\
mapkey(continued) ~ Select `vwsavretr` `VwSavRetr_PH.NameVw_List`1 `V-FRONT`;\
mapkey(continued) ~ Select `vwsavretr` `VwSavRetr_PH.NameVw_List`1 `V-A1SO`;\
mapkey(continued) ~ Activate `vwsavretr` `VwSavRetr_PH.NameVw_PB_SetCur`;\
mapkey ib ~ Activate `main_dlg_cur` `ProCmdViewNamePick.view`1 ;\
mapkey(continued) ~ Select `nameviewlist` `nv_list`1 `V-BACK`;
mapkey io ~ Activate `main_dlg_cur` `ProCmdViewNamePick.view`1 ;\
mapkey(continued) ~ Select `nameviewlist` `nv_list`1 `V-BOTTOM`;
mapkey if ~ Activate `main_dlg_cur` `ProCmdViewNamePick.view`1 ;\
mapkey(continued) ~ Select `nameviewlist` `nv_list`1 `V-FRONT`;
mapkey il ~ Activate `main_dlg_cur` `ProCmdViewNamePick.view`1 ;\
mapkey(continued) ~ Select `nameviewlist` `nv_list`1 `V-LEFT`;
mapkey ir ~ Activate `main_dlg_cur` `ProCmdViewNamePick.view`1 ;\
mapkey(continued) ~ Select `nameviewlist` `nv_list`1 `V-RIGHT`;
mapkey it ~ Activate `main_dlg_cur` `ProCmdViewNamePick.view`1 ;\
mapkey(continued) ~ Select `nameviewlist` `nv_list`1 `V-TOP`;
mapkey id ~ Activate `main_dlg_cur` `ProCmdViewNamePick.view`1 ;\
mapkey(continued) ~ Select `nameviewlist` `nv_list`1 `Default`;
mapkey i1 ~ Activate `main_dlg_cur` `ProCmdViewNamePick.view`1 ;\
mapkey(continued) ~ Select `nameviewlist` `nv_list`1 `V-A1SO`;
mapkey i2 ~ Activate `main_dlg_cur` `ProCmdViewNamePick.view`1 ;\
mapkey(continued) ~ Select `nameviewlist` `nv_list`1 `V-A2SO`;
mapkey i3 ~ Activate `main_dlg_cur` `ProCmdViewNamePick.view`1 ;\
mapkey(continued) ~ Select `nameviewlist` `nv_list`1 `V-Z3SO`;
mapkey i4 ~ Activate `main_dlg_cur` `ProCmdViewNamePick.view`1 ;\
mapkey(continued) ~ Select `nameviewlist` `nv_list`1 `V-Z4SO`;
mapkey i5 ~ Activate `main_dlg_cur` `ProCmdViewNamePick.view`1 ;\
mapkey(continued) ~ Select `nameviewlist` `nv_list`1 `V-Z5SO`;
mapkey i6 ~ Activate `main_dlg_cur` `ProCmdViewNamePick.view`1 ;\
mapkey(continued) ~ Select `nameviewlist` `nv_list`1 `V-Z6SO`;
mapkey i7 ~ Activate `main_dlg_cur` `ProCmdViewNamePick.view`1 ;\
mapkey(continued) ~ Select `nameviewlist` `nv_list`1 `V-Z7SO`;
mapkey i8 ~ Activate `main_dlg_cur` `ProCmdViewNamePick.view`1 ;\
mapkey(continued) ~ Select `nameviewlist` `nv_list`1 `V-Z8SO`;
! ****** standard key macros ******
mapkey EA #feature;#create;#datum;#axis
mapkey EC #feature;#create;#datum;#curve
mapkey EO #feature;#create;#datum;#coord sys
mapkey EP #feature;#create;#datum;#plane
mapkey ET #feature;#create;#datum;#point
mapkey oe #FEATURE;#CREATE;#PROTRUSION;#DONE;
mapkey o1 #FEATURE;#CREATE;#PROTRUSION;#DONE;#DONE;
mapkey or #FEATURE;#CREATE;#PROTRUSION;#REVOLVE;#DONE;
mapkey os #FEATURE;#CREATE;#PROTRUSION;#SWEEP;#DONE;
mapkey ob #FEATURE;#CREATE;#PROTRUSION;#BLEND;#DONE;
mapkey ou #FEATURE;#CREATE;#PROTRUSION;#USE QUILT;#DONE;
mapkey ot #FEATURE;#CREATE;#PROTRUSION;#THIN;#DONE;
mapkey ce #FEATURE;#CREATE;#CUT;#DONE;
mapkey cr #FEATURE;#CREATE;#CUT;#REVOLVE;#DONE;
mapkey cs #FEATURE;#CREATE;#CUT;#SWEEP;#DONE;
mapkey cb #FEATURE;#CREATE;#CUT;#BLEND;#DONE;
mapkey cu #FEATURE;#CREATE;#CUT;#USE QUILT;#DONE;
mapkey cc #FEATURE;#CREATE;#CHAMFER;#EDGE;
mapkey sd #SET UP;#GEOM TOL;#SET DATUM;
mapkey df #FEATURE;#CREATE;#TWEAK;#DRAFT;#DONE;#DONE;
mapkey dc #FEATURE;#CREATE;#TWEAK;#DRAFT;#NEUTRAL CRV;#DONE;
mapkey db #FEATURE;#CREATE;#TWEAK;#DRAFT;#DONE;#SPLIT AT PLN;#DONE;
mapkey ds #FEATURE;#CREATE;#TWEAK;#DRAFT;#DONE;#SPLIT AT SKT;#DONE;
mapkey ro #FEATURE;#CREATE;#ROUND;#DONE;#DONE;#DONE;
mapkey rf #FEATURE;#CREATE;#ROUND;#DONE;#DONE;#FULL ROUND;#DONE;
mapkey rd #FEATURE;#CREATE;#ROUND;#EDGE;#DONE;
mapkey rv #FEATURE;#CREATE;#ROUND;#DONE;#DONE;#VARIABLE;#DONE;
mapkey rc #FEATURE;#CREATE;#ROUND;#DONE;#ADVANCED;#DONE;#ADD;
mapkey re #FEATURE;#CREATE;#ROUND;#EDGE;#DONE;
mapkey rs #FEATURE;#CREATE;#ROUND;#EDGE-SURF;#DONE;
mapkey rp #FEATURE;#CREATE;#TWEAK;#REPLACE;
mapkey rh #FEATURE;#CREATE;#TWEAK;#OFFSET;#WHOLE SURF;#DONE;
mapkey ph #CREATE;#TWEAK;#PATCH;
mapkey qe #FEATURE;#CREATE;#SURFACE;#NEW;#DONE;
mapkey qr #FEATURE;#CREATE;#SURFACE;#NEW;#REVOLVE;#DONE;
mapkey qs #FEATURE;#CREATE;#SURFACE;#NEW;#SWEEP;#DONE;
mapkey qf #FEATURE;#CREATE;#SURFACE;#NEW;#FLAT;#DONE;
mapkey qc #FEATURE;#CREATE;#SURFACE;#NEW;#COPY;#DONE;
mapkey cq #DONE SEL;#DONE;~ Activate `Odui_Dlg_01` `okay`;#DONE/RETURN;\
mapkey(continued) #CREATE;#TWEAK;#REPLACE;
mapkey qo #FEATURE;#CREATE;#SURFACE;#NEW;#OFFSET;#DONE;
mapkey qt #FEATURE;#CREATE;#SURFACE;#NEW;#FILLET;#DONE;
mapkey qa #FEATURE;#CREATE;#SURFACE;#NEW;#ADVANCED;#DONE;
mapkey qb #FEATURE;#CREATE;#SURFACE;#NEW;#ADVANCED;#DONE;#BOUNDARIES;#DONE;\
mapkey(continued) #DONE;#CHAIN;
mapkey se #FEATURE;#CREATE;#SURFACE;#EXTEND;#SINGLE DST;#DONE;#BNDRY CHAIN;
mapkey sg #FEATURE;#CREATE;#SURFACE;#EXTEND;#ALONG DIR;#DONE;#BNDRY CHAIN;
mapkey st #FEATURE;#CREATE;#SURFACE;#TRIM;
mapkey sc #FEATURE;#CREATE;#SURFACE;#TRIM;#USE CURVES;#DONE;
mapkey sq #FEATURE;#CREATE;#SURFACE;#TRIM;#USE QUILT;#DONE;
mapkey sm #FEATURE;#CREATE;#SURFACE;#MERGE;
mapkey sr #FEATURE;#CREATE;#SURFACE;#TRANSFORM;
! ****** FOR LAYER COTIUE ******
mapkey ya #LAYER;#SETUP LAYER;#FROM FILE;#RETRIEVE;E:\AA\layer_ya;\
mapkey(continued) #DONE/RETURN;#SET ITEMS;
mapkey yd #LAYER;#SETUP LAYER;#FROM FILE;#RETRIEVE;E:\AA\layer_yb;\
mapkey(continued) #DONE/RETURN;#SET ITEMS;#BASE_PLANE;#DONE SEL;#DATUM PLANE;#SEL BY MENU;\
mapkey(continued) #NAME;~ Select `sellistmul0` `Namelist`1 `DX`;\
mapkey(continued) ~ Select `sellistmul0` `Namelist`2 `DX` `DY`;\
mapkey(continued) ~ Select `sellistmul0` `Namelist`3 `DX` `DY` `DZ`;\
mapkey(continued) ~ Activate `sellistmul0` `Ok`;#DONE SEL;#DONE/RETURN;#DONE/RETURN;
mapkey yl #LAYER;#SETUP LAYER;#FROM FILE;#RETRIEVE;E:\AA\layer_yb;\
mapkey(continued) #DONE/RETURN;#SET ITEMS;#ADD ITEMS;#OLD_PRODUCT;#DONE SEL;#QUILT;
mapkey yy #VIEW;#LAYER DISP;#BASE_PLANE;#DONE SEL;#REPAINT;
! ****** FOR DRAWING MODE *******
mapkey azz ~ Select `main_dlg_cur` `MenuBar1`1 `Utilities`;\
mapkey(continued) ~ Activate `main_dlg_cur` `Utilities.psh_util_trail_train`;\
mapkey(continued) ~ Open `file_open` `Ph_path.Path`;~ Close `file_open` `Ph_path.Path`;\
mapkey(continued) ~ Select `file_open` `Ph_path.Path`1 `e:\\aa`;\
mapkey(continued) ~ Select `file_open` `Ph_list.Filelist`0 ;\
mapkey(continued) ~ Activate `file_open` `Ph_list.Filelist`1 `azz.txt`;
mapkey DXF #INTERFACE;#EXPORT;#DXF;;
mapkey dwg ~ Select `main_dlg_cur` `MenuBar1`1 `File`;\
mapkey(continued) ~ Select `main_dlg_cur` `File.cb_file_export`;\
mapkey(continued) ~ Close `main_dlg_cur` `File.cb_file_export`;\
mapkey(continued) ~ Activate `main_dlg_cur` `psh_export`;#DWG;;\
mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1 `Windows`;\
mapkey(continued) ~ Activate `main_dlg_cur` `Windows.psh_win_activate`;\
mapkey(continued) ~ FocusOut `newtree` `AssyTree`;
mapkey W1 #SHEETS;#NEXT;
mapkey W2 %DWG;%W1
mapkey DW2 %W2;%W2
mapkey DW3 %DW2;%W2
mapkey DW4 %DW3;%W2
mapkey DW5 %DW4;%W2
mapkey DW6 %DW5;%W2
mapkey DW7 %DW6;%W2
mapkey DW8 %DW7;%W2
mapkey DW9 %DW8;%W2
mapkey DW10 %DW9;%W2
mapkey DW11 %DW10;%W2
mapkey DW12 %DW11;%W2
mapkey DW13 %DW12;%W2
mapkey DW14 %DW13;%W2
mapkey DW15 %DW14;%W2
mapkey DW16 %DW15;%W2
mapkey DW17 %DW16;%W2
mapkey DW18 %DW17;%W2
mapkey DW19 %DW18;%W2
mapkey igs ~ Select `main_dlg_cur` `MenuBar1`1 `File`;\
mapkey(continued) ~ Activate `main_dlg_cur` `psh_export`;#IGES;;\
mapkey(continued) ~ Activate `intf_export` `OkPushBtn`;
mapkey MR #SET UP;#REF DIM;
mapkey MD #MODIFY;#NUM DIGITS;2;#DONE/RETURN;#CREATE;#DIMENSION;
mapkey MV #VIEWS;#MOVE VIEW
mapkey MO #DETAIL;#MOVE
mapkey ME #DETAIL;#MODIFY;#TEXT;
mapkey MH #DETAIL;#MODIFY;#XHATCHING
mapkey HM #DONE SEC;#SPACING;#VALUE;
mapkey MT #DETAIL;#CREATE;#NOTE;#ENTER;#CENTER;#CUR STYLE;#ace_note;\
mapkey(continued) #MAKE NOTE;
mapkey SJ #CREATE;#OFFSET;#DONE
mapkey SF #USE PREV;#OKAY;#LINE
mapkey VD #VIEWS;#MODIFY VIEW;#VIEW TYPE;
mapkey DV #GENERAL;#DONE;#DONE;#MOVE VIEW
! ***** Mold Design *****
mapkey wp #REGENERATE;#AUTOMATIC;
mapkey wg #REGENERATE;#AUTOMATIC;#CURRENT VALS;
mapkey wl #PARTING SURF;#DELETE;#SEL BY MENU;#LAST FEATURE;#DONE SEL;#DONE;\
mapkey wm #REGENERATE;#AUTOMATIC;#ENTER;#SELECT ALL;
mapkey ex ~ Select `main_dlg_cur` `MenuBar1`1 `View`;\
mapkey(continued) ~ Activate `main_dlg_cur` `View.psh_view_explode`;#MODIFY;#MOD EXPLD;\
mapkey(continued) #POSITION;
mapkey ux #VIEW;#UN-EXPLODE;
mapkey gc #ADD;#COPY;#DONE;
mapkey ge #ADD;#DONE;
mapkey go #ADD;#OFFSET;#DONE;
mapkey gf #ADD;#FLAT;#DONE;
mapkey gs #ADD;#SWEEP;#DONE;
mapkey gr #ADD;#REVOLVE;#DONE;
mapkey ga #ADD;#ADVANCED;#DONE;
mapkey gb #ADD;#ADVANCED;#DONE;#BOUNDARIES;#DONE;#DONE;#CHAIN;
mapkey eg #EXTEND;#ALONG DIR;#DONE;#BNDRY CHAIN;
mapkey ux #TRIM;#DONE;
mapkey uq #TRIM;#USE QUILT;#DONE;
mapkey ur #TRIM;#USE CURVES;#DONE;
mapkey us #TRIM;#SILHOUETTE;#DONE;
mapkey ul #FEATURE;#UDF LIBRARY;
mapkey ud #FEATURE;#CREATE;#USER DEFINED;
mapkey um #ADVANCED;#PARAMETERS;#MODIFY;
mapkey up #TABLE;#REPEAT REGION;#UPDATE TABLES;#DONE/RETURN;
! Thanks for reading the above information !
! WELCOME TO PROVIDE YOUR ADVICE !!!
mapkey saa ~ Select `main_dlg_cur` `MenuBar1`1 `Utilities`;\
mapkey(continued) ~ Select `main_dlg_cur` `Utilities.cb_util_pref`;\
mapkey(continued) ~ Close `main_dlg_cur` `Utilities.cb_util_pref`;\
mapkey(continued) ~ Activate `main_dlg_cur` `psh_util_load_config`;\
mapkey(continued) ~ Select `file_open` `Ph_path.Path`1 `E:\\Aa`;\
mapkey(continued) ~ Select `file_open` `Ph_list.Filelist`1 `config.pro`;\
mapkey(continued) ~ Activate `file_open` `Ph_list.Filelist`1 `config.pro`;\
mapkey(continued) ~ FocusOut `newtree` `AssyTree`;~ Select `main_dlg_cur` `MenuBar1`1 `File`;\
mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;~ Activate `main_dlg_cur` `File.psh_save`;;
mapkey qq #VIS LEVEL;#PART;#DONE;#ADD MODEL;#MANUAL SEL;
mapkey sp #SIMPLFD REP;#REDEFINE;~ Select `open_rep` `replist`1 `BOT`;\
mapkey(continued) ~ Activate `open_rep` `OK`;~ FocusOut `newtree` `AssyTree`;#BY RULE;\
mapkey(continued) #MODEL NAME;?????z*;#UPDATESCREEN;#DONE;~ FocusOut `newtree` `AssyTree`;\
mapkey(continued) #REDEFINE;~ Select `open_rep` `replist`1 `TOP`;~ Activate `open_rep` `OK`;\
mapkey(continued) ~ FocusOut `newtree` `AssyTree`;#BY RULE;#MODEL NAME;?????t*;#UPDATESCREEN;\
mapkey(continued) #DONE;~ FocusOut `newtree` `AssyTree`;#DONE/RETURN;
mapkey sp #SIMPLFD REP;#REDEFINE;~ Select `open_rep` `replist`0 ;\
mapkey(continued) ~ Activate `open_rep` `replist`0 ;~ Select `open_rep` `replist`1 `TOP`;\
mapkey(continued) ~ Activate `open_rep` `OK`;~ FocusOut `newtree` `AssyTree`;#DEFAULT;#ALL;\
mapkey(continued) #MASTER REP;#BY RULE;#MODEL NAME;?????t*;#DONE;\
mapkey(continued) ~ FocusOut `newtree` `AssyTree`;#REDEFINE;\
mapkey(continued) ~ Select `open_rep` `replist`1 `BOT`;~ Activate `open_rep` `OK`;\
mapkey(continued) ~ FocusOut `newtree` `AssyTree`;#DEFAULT;#ALL;#MASTER REP;#BY RULE;\
mapkey(continued) #MODEL NAME;?????z*;#DONE;~ FocusOut `newtree` `AssyTree`;#DONE/RETURN;
mapkey $F1 @MAPKEY_LABELrf;#CREATE;#ROUND;#DONE;#FULL ROUND;#DONE;
mapkey $F1 @MAPKEY_LABEL$F1;\
mapkey(continued) ~ Activate `main_dlg_cur` `ProCmdViewZoomIn.utils`;
mapkey rf #FEATURE;#CREATE;#ROUND;#DONE;#FULL ROUND;#DONE;
mapkey sv #SIMPLFD REP;#SET CURRENT;~ Select `open_rep` `replist`1 `TOP`;\
mapkey so #SIMPLFD REP;#SET CURRENT;~ Select `open_rep` `replist`1 `BOT`;\
read_famtab_file_on_retrieve no
menumanager yes
dialog_translation no
display_silhouette_edges no
26
发表于 2003-2-18 12:31:36 | 只看该作者
pro/e2000I2里 有相关的隐藏系统参数吗?
27
发表于 2003-2-18 12:41:40 | 只看该作者
MENU_PLACEMENT left
菜单到左边来了,
重起pro/e之后有效!-----zle77
28
发表于 2003-2-18 12:43:16 | 只看该作者
use_layer_display_dialog no
图层对话框没了,取而代之的是一条菜单
::y::y当时有效!----zle77
29
发表于 2003-2-18 12:54:12 | 只看该作者
是的,有,你研究一下看有什么结果!::b
30
发表于 2003-2-18 12:55:40 | 只看该作者
  图层对话框没了,取而代之的是一条菜单
::y::y
你上面的
菜单到做边来了是指???
GMT+8, 2025-10-19 11:25 , Processed in 0.033136 second(s), 11 queries , Gzip On, Redis On.
