Mastercam软件的后置处理文件及其设定方法
发表于 2003-8-1 15:10:21 | 只看该作者
你讲的太好了,可是我很笨,不能举一反三,我现在用意大利的FIDIA系统的机床,在用POST时我只修改了一个后处理程序,编出来的程序需要修改,我想请问怎样修改它,使编出来的程序不用修改能直接使用。 主要修改的地方是F值使它不带小数点。还有怎样加上您上述的注解? 还有就是自动样使钻孔程序也编制正确,我的钻孔代码是:
  G82 E X Y Z R P    普通钻孔
  G83 E L X Y Z R P   琢孔钻
  G84 E L X Y Z R P   玫丝
  谢谢!
以下是我的后处理程序, 请多指教。  email: persistcr@sohu.com
# Post Name           : FIDIA
# Product             : MILL
# Machine Name        : DIALOG
# Control Name        : 11
# Description         : DIALOG 11
# Associated Post     : NONE
# Mill/Turn           : NO
# 4-axis/Axis subs.   : NO
# 5-axis              : NO
# Subprograms         : NO
# Executable          : MP 9.0
# WARNING: THIS POST IS GENERIC AND IS INTENDED FOR MODIFICATION TO
# THE MACHINE TOOL REQUIREMENTS AND PERSONAL PREFERENCE.
#| REVISION LOG  |
# Programmers Note:
# CNC 01/12/01  -  Initial post update for V8.1, grt
# CNC 01/09/02  -  Initial post update for V9.0, rjm
#| FEATURES:     |
# MP Post processor customization file for the Dialog 11
# Canned text:
#    Entering cantext on a contour point from within Mastercam allows the
#    following functions to enable/disable.
#    Cantext value:
#    1 = Stop =  output the "M00" stop code
#    2 = Ostop = output the "M01" optional stop code
# Format Statements - i=incr, n=nonmodal, l=leave ldg, t=leave trlg, d=delta
fs  1  1.4
fs  2  1.3ld
fs  3  4 0
fs  4  2 0ln
fs  5  3.1
fs  6  4 0ln
# Format Assignments
fmt  X 1 x          # X axis position
fmt  Y 1 y          # Y axis position
fmt  Z 1 z          # Z axis position
fmt  I 2 i          # Arc center in X axis
fmt  J 2 j          # Arc center in Y axis
fmt  K 2 k          # Arc center in Z axis
fmt  N 6 n          # Sequence number
fmt  T 4 t          # Tool Number
fmt    4 tloffno    # Tool diameter offset number
fmt    4 tlngno     # Tool length offset number
fmt  F 5 fr         # Feedrate
fmt    5 plane      # Modal plane code selector
fmt  M 3 cc         # Cutter Comp.
fmt  S 3 ss         # Spindle Speed
fmt    6 wcs        # make Work Coord. string 'sgwcs' non-modal
fmt    6 drillcyc   # make string 'sgdrlcyc' non-modal
fmt  M 4 ssrange    # Spindle Speed Range (mi2 - M42 = hi, M43 = low)
fmt  M 4 sscode     # Spindle Speed Code  (M59 - M77 from tbl 1)
fmt    3 gcode      # Format linear G-code selector for modality only
fmt  Z 1 depth
fmt  R 1 refht
fmt  Q 1 dwell
fmt  Z 1 initht
fmt  Q 1 peckincr1
fmt    4 dirchg
fmt    4 coolant    # Format coolant M-code selector for modality only
fmt  F 5 frplunge
fmt    3 ccomp       # Modal format for ccomp
fmt  M 4 cantext
# Formulas - Use ':' instead of '=' to initialize variables
plane     : 0      # Initialize plane code to suppress first G17
spaces    : 1      # Number of spaces to add between fields
seqmax    : 10000  # Max. sequence number
omitseq   : no     # Omit sequence numbers?
frrapid   : 300    # Rapid feedrate? 300.0
frmax     : 300    # Maximum feedrate? 300.0
ssmax     : 3000   # Maximum spindle speed? 3000
breakarcs : 1      # Break arcs, 0 = no, 1 = quadrants, 2 = 180deg. max arcs
arctype   : 1      # Arc center 1=abs, 2=inc, 3=st-cen, 4=unsigned inc.
do_full_arc : 0    # Allow full circle output? 0=no, 1=yes
helix_arc   : 0    # Support helix arc output, 0=no, 1=all planes, 2=XY plane only
arccheck  : 1      # Check for small arcs, convert to linear
ltol      : .002   # Length tolerance for arccheck
ncldr     : 20     # Number of leader characters
ldrcode   : 65     # Leader character dec. equiv.
tooltable : no     # Build next tool table
g         : -1     # g code initialize
# Global Formulas
wcs       = mi1    # Work coord. system
ssrange   = mi2
sscode    = frange(1,ss)  # Spindle speed code
#  USE CANNED CYCLES?
usecandrill : yes      # Use canned cycle for drill?
usecanpeck  : yes      # Use canned cycle for Peck?
usecanchip  : yes      # Use canned cycle for Chip Break?
usecantap   : yes      # Use canned cycle for Tap?
usecanbore1 : yes      # Use canned cycle for Bore1?
usecanbore2 : yes      # Use canned cycle for Bore2?
usecanmisc1 : no       # Use canned cycle for Misc1?
usecanmisc2 : no       # Use canned cycle for Misc2?
# DEBUG - Switches for debugging purposes
fastmode : yes   # Enable Quick Post Processing, (set to no for debug)
bug1 : 1         # 0=No display, 1=Generic list box, 2=Editor
bug2 : 0         # Add postline label to each line at column 'bug2'
bug3 : 0         # Add whatline to each line? yes/no
bug4 : 0         # Add -.nci line no. to each line? yes/no
whatno : yes     # Ignore whatline branches to plin1 etc.?
get_1004   : 1   #Find gcode 1004 with getnextop?
rpd_typ_v7 : 1   #Use Version 7 style contour flags?
strtool_v7 : 2   # Use Version 7 toolname?
cant_tlchng : 1  #Ignore cantext entry on move with tlchng_aft
# Lookup table definitions - for Math Functions FLOOK and FRANGE
flktbl    1     12     # Lookup table no.     No. of entry pairs
         58     63     # Code 1 (output)      Match 1
         59     90     # Code 2               Match 2
         63    112     #   .                    .
         64    180     #   .                    .
         65    224     #   .                    .
         66    355
         67    450
         73    710
         74    900
         75   1400
         76   1800
         77   2800
# Strings - String labels must start with 's' - they are not pre-assigned
sg00    G00  # Linear movement at rapid feedrate G code
sg01    G01  # Linear movement at feedrate G code
sg02    G02  # Circular interpolation CW G code
sg03    G03  # Circular interpolation CCW G code
sgcode       # Target string for linear/circular motion G code
fstrsel  sg00 gcode sgcode    # Select motion G code string
sm09    M09  # Coolant off  no coolant
sm08f   M08  # Coolant on   flood
sm08m   M09  # Coolant on   mist    (off if not supported)
sm08t   M09  # Coolant on   tool    (off if not supported)
smcool       # Coolant code target string
fstrsel  sm09 coolant smcool   # coolant = 0 - coolant off
                               # coolant = 1, 2, 3 - coolant on
sm04    M04  # Spindle reverse - no coolant
sm05    M05  # Spindle off     - no coolant
sm03    M03  # Spindle forward - no coolant
sm04f   M04  # Spindle reverse - flood
sm05f   M05  # Spindle off     - flood
sm03f   M03  # Spindle forward - flood
sm04m   M04  # Spindle reverse - mist
sm05m   M05  # Spindle off     - mist
sm03m   M03  # Spindle forward - mist
sm04t   M04  # Spindle reverse - tool
sm05t   M05  # Spindle off     - tool
sm03t   M03  # Spindle forward - tool
spdlon       # Target Spindle-on M-string
spdlsel = fsg2(coolant) * 3 + fsg3(ss) #Spindle on selector based on coolant
                                     #      0 = off, 1 = flood, 2 = mist,
                                     #      3 = thru tool
fstrsel  sm04 spdlsel spdlon
scc0          # cutter compensation state not changed
sg40    G40   # cancel cutter compensation
sg41    G41   # cutter compensation left
sg42    G42   # cutter compensation right
sg140   G40   # last linear move --> cancel cutter comp
sccomp
fstrsel  scc0 ccomp sccomp
sg17     G17   # XY plane code
sg19     G19   # XZ plane code
sg18     G18   # YZ plane code
sgplane        # Workplane G code
fstrsel  sg17 plane sgplane      # Select work plane G code
sg53    G53   # Work coordinate system G code #1
sg54    G54   # Work coordinate system G code #2
sg55    G55   # Work coordinate system G code #3
sg56    G56   # Work coordinate system G code #4
sg57    G57   # Work coordinate system G code #5
sg58    G58   # Work coordinate system G code #6
sg59    G59   # Work coordinate system G code #7
sgwcs         # Work coordinate system G code
fstrsel  sg53 wcs sgwcs
sg81     G81G99   #  drill      - no dwell
sg82     G82G99   #  drill      - with dwell
sg83     G83G99   #  peck drill - no dwell
sg83d    G83G99   #  peck drill - with dwell
sg73     G73G99   #  chip break - no dwell
sg73d    G73G99   #  chip break - with dwell
sg84     G84G99   #  tap
sg84d    G84G99   #  tap     # must be here for selector to work
sg85     G85G99   #  bore #1    - no dwell
sg89     G89G99   #  bore #1    - with dwell
sg86     G86G99   #  bore #2    - no dwell
sg86d    G86G99   #  bore #2    - with dwell
sgm1     GGGG99   #  misc #1    - no dwell
sgm1d    GGGG99   #  misc #1    - with dwell
sgm2     GGGG99   #  misc #2    - no dwell
sgm2d    GGGG99   #  misc #2    - with dwell
sgdrill           #  Target drill cycle G code
drlgsel  = drillcyc*2 + fsg2(dwell)  # 16 possible combinations:
                                     #   drillcyc = 0..7
                                     #   dwell    = 0 or non-zero (2 states)
fstrsel  sg81 drlgsel sgdrill        # Drill cycle G string select
sgaccel     G8    # Axis acceleration code
sgdecel     G9    # Axis deceleration code
sgacc
fstrsel  sgaccel dirchg sgacc  # Select accel/decel code with dir. chg. flag
#Cantext string definitions (spaces must be padded here)
sm00        "M00"
sm01        "M01"
strtextno
strcantext
strm          M
sblank
# USER DEFINED POSTLINES
ptllncomp   # Tool length compensation
              "G43", *tlngno
pcool       # Coolant on/off - init. off (coolant = 0)
               if coolant <> prv_coolant, n, smcool
psg00       # Output "G00" via String Select Function to maintain modality
               gcode = 0
               *sgcode
pfr         # Don't output neg. feedrate
               if fr > 0, fr
# PREDEFINED POSTLINES
pheader     # File header
psof0       # Start of file for tool zero
              pcan
            # pcan1, n, sg00, *xh, *yh, *zh, spdlon, strcantext
              pcan1, n,"M03"
              pcan2
psof        # Start of file for non-zero tool number
              pcan
            # pcan1, n, sg00, *xh, *yh, *zh, t, spdlon, strcantext
              pcan1,n,"M03"
              pcan2
ptlchg0     # Null tool change
ptlchg      # Tool change
              n, sg00, zh
              pcan
              pcan1, n, sg00,xh ,yh, strcantext
              pcan2
              n, t
peof0       # End of file for tool zero
            # n, sg00, zh,
              n, "M30"
peof        # End of file for non-zero tool
            # n, sg00, zh,
              n, "M30"
prapid      # Linear line movement - at rapid feedrate
               pcan
               pcan1, n, sccomp, *sgcode, x, y, z, pfr, strcantext
               pcan2
pzrapid     # Linear movement in Z axis only - at rapid feedrate
               pcan
               pcan1, n, sccomp, *sgcode, z, pfr, strcantext
               pcan2
plin        # Linear line movement - at feedrate
               pcan
               pcan2
pz          # Linear movement in Z axis only - at feedrate
               pcan
               pcan1, n, ptllncomp, *sgcode, z, pfr, strcantext
               pcan2
pijk       # Force Plane Change "I, J, K" Values
              if plane = 0, *i, *j,  k
              if plane = 1,  i, *j, *k
              if plane = 2, *i,  j, *k
pcir        # Circular interpolation
               pcan
               pcan1, n, sgplane, sccomp, *sgcode, x, y, z, pijk, pfr, strcantext
               pcan2
pdrill      # Canned Drill Cycle
               n, psg00, *x, *y
               n, *tlgth, *initht
               n, sgdrill, *x, *y, *depth, *refht, *dwell, *frplunge
ppeck       # Canned Peck Drill Cycle
               n, psg00, *x, *y
               n, *tlgth, *initht
               n, sgdrill, *x, *y, *z, *refht, *peckincr1, *dwell, *frplunge
pchpbrk     # Canned Chip Break Cycle
               n, psg00, *x, *y
               n, *tlgth, *initht
ptap        # Canned Tap Cycle
               n, psg00, *x, *y
               n, *tlgth, *initht
               n, sgdrill, *x, *y, *z, *refht, *dwell, *frplunge
pbore1      # Canned Bore #1 Cycle
               ptap
pbore2      # Canned Bore #2 Cycle
               ptap
pmisc1      # Canned Misc #1 Cycle
pmisc2      # Canned Misc #2 Cycle
pdrill_2    # Canned Drill Cycle
               n, x, y
ppeck_2     # Canned Peck Drill Cycle
               pdrill_2
pchpbrk_2   # Canned Chip Break Cycle
               pdrill_2
ptap_2      # Canned Tap Cycle
               pdrill_2
pbore1_2    # Canned Bore #1 Cycle
               pdrill_2
pbore2_2    # Canned Bore #2 Cycle
               pdrill_2
pmisc1_2    # Canned Misc #1 Cycle
               pdrill_2
pmisc2_2    # Canned Misc #2 Cycle
               pdrill_2
pcanceldc   # Cancel canned drill cycle
               n, "G80"
pcancelcc   # Cancel cutter comp.
              #n, "G40"
pwrtt       # Tool table line format
# Canned Text
pcan            #Canned text - before output call
      strcantext = sblank
      if cant_no > 0,
        if cant_pos1 = 0, pcant_1
        if cant_pos2 = 0, pcant_2
        if cant_pos3 = 0, pcant_3
        if cant_pos4 = 0, pcant_4
        if cant_pos5 = 0, pcant_5
        if cant_pos6 = 0, pcant_6
        if cant_pos7 = 0, pcant_7
        if cant_pos8 = 0, pcant_8
        if cant_pos9 = 0, pcant_9
        if cant_pos10 = 0, pcant_10
        n, strcantext, e
        strcantext = sblank
pcan1           #Canned text - with move
      strcantext = sblank
      if cant_no > 0,
        if cant_pos1 = 1, pcant_1
        if cant_pos2 = 1, pcant_2
        if cant_pos3 = 1, pcant_3
        if cant_pos4 = 1, pcant_4
        if cant_pos5 = 1, pcant_5
        if cant_pos6 = 1, pcant_6
        if cant_pos7 = 1, pcant_7
        if cant_pos8 = 1, pcant_8
        if cant_pos9 = 1, pcant_9
        if cant_pos10 = 1, pcant_10
      if cstop, strcantext = strcantext + sm00
      if cgstop, strcantext = strcantext + sm01
      #Output of strcantext occurs at the end of the output line
pcan2           #Canned text - after output call
      strcantext = sblank
      if cant_no > 0,
        if cant_pos1 = 2, pcant_1
        if cant_pos2 = 2, pcant_2
        if cant_pos3 = 2, pcant_3
        if cant_pos4 = 2, pcant_4
        if cant_pos5 = 2, pcant_5
        if cant_pos6 = 2, pcant_6
        if cant_pos7 = 2, pcant_7
        if cant_pos8 = 2, pcant_8
        if cant_pos9 = 2, pcant_9
        if cant_pos10 = 2, pcant_10
        n, strcantext, e
        strcantext = sblank
pcant_1         #Canned text - output call
      cantext = cant_val1
      pcant_out
pcant_2         #Canned text - output call
      cantext = cant_val2
      pcant_out
pcant_3         #Canned text - output call
      cantext = cant_val3
      pcant_out
pcant_4         #Canned text - output call
      cantext = cant_val4
      pcant_out
pcant_5         #Canned text - output call
      cantext = cant_val5
      pcant_out
pcant_6         #Canned text - output call
      cantext = cant_val6
      pcant_out
pcant_7         #Canned text - output call
      cantext = cant_val7
      pcant_out
pcant_8         #Canned text - output call
      cantext = cant_val8
      pcant_out
pcant_9         #Canned text - output call
      cantext = cant_val9
      pcant_out
pcant_10        #Canned text - output call
      cantext = cant_val10
      pcant_out
pcant_out       #Canned text - build the string for output
      #Assign string select type outputs
      #Build the cantext string
      if cantext = 1, strcantext = strcantext + sm00
      if cantext = 2, strcantext = strcantext + sm01
      if cantext > 2,
        strtextno = no2str(cantext)
        strcantext = strcantext + strm + strtextno
# Numbered questions for Mastercam Mill
38. Rapid feedrate? 300.0
1538. Rapid feedrate (metric)? 10000.0
80. Communications port number for receive and transmit (1 or 2) ? 1
81. Baud rate (110, 150, 300, 600, 1200, 2400, 4800, 9600)? 1200
82. Parity (E/O/N)? E
83. Data bits (7 or 8)? 7
84. Stop bits (1 or 2)? 2
85. Strip line feeds? N
86. Delay after end of line (seconds)? 0.0
87. Ascii, Eia, or Binary (A/E/? A
88. Echo keyboard to screen in terminal emulation? n
89. Strip carriage returns? N
90. Drive and subdirectory for NC files?
91. Name of executable post processor? MP
92. Name of reverse post processor?
93. Reverse post PST file name?
103. Maximum spindle speed? 5000
107. Average time for tool change (seconds)? 2.0
161. Enable Home Position button? y
162. Enable Reference Point button? n
163. Enable Misc. Values button? y
164. Enable Rotary Axis button? n
165. Enable Tool Plane button? n
166. Enable Construction Plane button? n
167. Enable Tool Display button? y
168. Check tplane during automatic work origin creation? n
# Default Miscellaneous Real Values
201. Default Index start angle? 0.0
202. Default Index incremental angle? 0.0
203. Default miscellaneous real variable 3 (mr3)? 0.0
204. Default miscellaneous real variable 4 (mr4)? 0.0
205. Default miscellaneous real variable 5 (mr5)? 0.0
206. Default miscellaneous real variable 6 (mr6)? 0.0
207. Default miscellaneous real variable 7 (mr7)? 0.0
208. Default miscellaneous real variable 8 (mr8)? 0.0
209. Default miscellaneous real variable 9 (mr9)? 0.0
210. Default miscellaneous real variable 10 (mr10)? 0.0
# Default Miscellaneous Real Values (METRIC)
1601. Default miscellaneous real variable 1 (mr1) (metric)? 0.0
1602. Default miscellaneous real variable 2 (mr2) (metric)? 0.0
1603. Default miscellaneous real variable 3 (mr3) (metric)? 0.0
1604. Default miscellaneous real variable 4 (mr4) (metric)? 0.0
1605. Default miscellaneous real variable 5 (mr5) (metric)? 0.0
1606. Default miscellaneous real variable 6 (mr6) (metric)? 0.0
1607. Default miscellaneous real variable 7 (mr7) (metric)? 0.0
1608. Default miscellaneous real variable 8 (mr8) (metric)? 0.0
1609. Default miscellaneous real variable 9 (mr9) (metric)? 0.0
1610. Default miscellaneous real variable 10 (mr10) (metric)? 0.0
# Enable/Disable Miscellaneous Real Variable switches
1611. Enable miscellaneous real variable 1? y
1612. Enable miscellaneous real variable 2? y
1613. Enable miscellaneous real variable 3? y
1614. Enable miscellaneous real variable 4? y
1615. Enable miscellaneous real variable 5? y
1616. Enable miscellaneous real variable 6? y
1617. Enable miscellaneous real variable 7? y
1618. Enable miscellaneous real variable 8? y
1619. Enable miscellaneous real variable 9? y
1620. Enable miscellaneous real variable 10? y
# Default Miscellaneous Integer Values
301. Default Work Coordinate System (0=G53,1=G54 to 6=G59)? 0
302. Default Use automatic indexing (1=Yes, 0=No)? 0
303. Default number of index repetitions? 1
304. Default miscellaneous integer variable 4 (mi4)? 0
305. Default miscellaneous integer variable 5 (mi5)? 0
306. Default check for axis change of direction (0=No, 1=Yes)? 0
307. Default miscellaneous integer variable 7 (mi7)? 0
308. Default miscellaneous integer variable 8 (mi8)? 0
309. Default miscellaneous integer variable 9 (mi9)? 0
310. Default miscellaneous integer variable 10 (mi10)? 0
# Enable/Disable Miscellaneous Integer Variable switches
1621. Enable miscellaneous integer variable 1? y
1622. Enable miscellaneous integer variable 2? y
1623. Enable miscellaneous integer variable 3? y
1624. Enable miscellaneous integer variable 4? y
1625. Enable miscellaneous integer variable 5? y
1626. Enable miscellaneous integer variable 6? y
1627. Enable miscellaneous integer variable 7? y
1628. Enable miscellaneous integer variable 8? y
1629. Enable miscellaneous integer variable 9? y
1630. Enable miscellaneous integer variable 10? y
# Configuration File association parameters (default is "y")
#400. Name of associated cfg file?
401. Read SYSTEM COLORS section? y
402. Read ALLOCATIONS section? y
403. Read TOLERANCES section? y
404. Read DATA PATHS section? y
405. Read COMMUNICATIONS section? y
406. Read DRAFT SETTINGS section? y
407. Read MISCELLANEOUS section? y
408. Read NC SETTINGS section? y
409. Read DIALOG SCRIPTS section? y
410. Read DESIGN SETTINGS section? y
411. Read PLOTTER SETTINGS section? y
412. Read ALT-KEY ASSIGNMENTS section? y
413. Read CAD section? y
414. Read START/EXIT section? y
415. Read SCREEN section? y
416. Read FILE NAMES section? y
1500. Chook to execute from 'Misc. values' button?
1501. Insert parameter information in the ascii NCI? n
1502. Write operation information to binary file (.ops)? n
1520. Display a warning when cutter compensation in control simulation finds an error? n
# Do NOT manually change the answer for Q.1999 !
1999. Product major version number that post supports? 9
发表于 2003-8-5 02:19:18 | 只看该作者
这些妹妹不懂
33
发表于 2003-8-18 13:17:16 | 只看该作者
好捧喔!正需要關於後處理相關資料.
謝謝!
34
发表于 2003-8-19 14:31:41 | 只看该作者
我70/100看不懂怎么办呢!
35
发表于 2003-8-19 14:33:25 | 只看该作者
36
发表于 2003-8-19 14:34:48 | 只看该作者
能说明什么?
老大说说呀!!!!!!!!
37
发表于 2003-8-25 09:42:40 | 只看该作者
啊,好
38
发表于 2003-8-25 10:15:19 | 只看该作者
鼓掌
39
发表于 2003-8-28 16:13:12 | 只看该作者
谢谢!
好东西收藏先~~!!
40
发表于 2003-10-16 09:33:45 | 只看该作者
大哥,你真的是大哥.. .
这些问题困扰了我很久了..
谢了....
GMT+8, 2025-9-18 13:06 , Processed in 0.070717 second(s), 11 queries , Gzip On, Redis On.
