返回列表 发新帖
What's New for I-DEAS 10
发表于 2003-3-11 09:27:18 | 只看该作者
New Recover Edge and Recover Corner Commands for Section Meshing
The new Recover Edge (A) and Recover Corner (B) commands on the Sections subpanel let you abstract fillets and blends (locations where multiple fillets intersect) within your model.
1,Recover Edge lets you remove the rail curves (A) that define a fillet and create a new curve (B), known as the "corner" curve, along the fillet's midline. This new curve approximates the edge that was present prior to a fillet operation.
发表于 2003-3-11 09:28:31 | 只看该作者
2, Recover Corner lets you create a hard corner at locations where multiple abstracted fillets that you've created with Recover Edge intersect.
发表于 2003-3-11 09:29:05 | 只看该作者
64-bit Memory Address Space Support for Model Solution on UNIX Platforms
Both the Local Batch and Remote Batch solve options in Model Solution now support a 64-bit memory address space on all supported UNIX platforms except for IBM and Sun. In previous releases, Model Solution only supported a 32-bit address space, which restricted it to using only 2Gb of real memory. Support for 64-bit address space allows you to run Model Solution on machines that are configured with more than 2Gb of memory.
New Frequency Response Analysis Type
Model Solution now includes a new frequency response analysis type. This frequency response analysis allows you to directly calculate the frequency response of a structure subjected to harmonic forces over a range of excitation frequencies.
Note: To support this new analysis type, support for frequency-dependent boundary conditions has been added to the Boundary Conditions task.
发表于 2003-3-11 12:52:46 | 只看该作者
:8)还没用过:I
发表于 2003-3-11 18:15:30 | 只看该作者
wolfzcg wrote:
:8)还没用过:I
你的备份计算机里有:\E\syp 有CD1~CD5
发表于 2003-3-11 18:55:06 | 只看该作者
syp wrote:
  173.196\E\syp 有CD1~CD5
能装上么?
发表于 2003-3-16 09:14:00 | 只看该作者
还没有用过
GMT+8, 2025-2-2 22:54 , Processed in 0.023126 second(s), 9 queries , Gzip On, Redis On.
