# General Output Settings
sub_level : 1 #Enable automatic subprogram support
breakarcs : 1 #Break arcs, 0 = no, 1 = quadrants, 2 = 180deg. max arcs
arcoutput : 1 #0 = IJK, 1 = R no sign, 2 = R signed neg. over 180
skp_lead_flgs : 1 #Do NOT use v9 style contour flags
arctype : 2 #Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc.
do_full_arc : 0 #Allow full circle output? 0=no, 1=yes
helix_arc : 2 #Support helix arc output, 0=no, 1=all planes, 2=XY plane only
arccheck : 0 #Check for small arcs, convert to linear
atol : .01 #Angularity tolerance for arccheck = 2
ltol : .002 #Length tolerance for arccheck = 1
vtol : .0001 #System tolerance
maxfeedpm : 500 #Limit for feed in inch/min
ltol_m : .05 #Length tolerance for arccheck = 1, metric
vtol_m : .0025 #System tolerance, metric
maxfeedpm_m : 10000 #Limit for feed in mm/min
force_wcs : yes #Force WCS output at every toolchange?
spaces : 0 #No. of spaces to add between fields
omitseq : yes #Omit sequence no.
seqmax : 9999 #Max. sequence no.
stagetool : 0 #0 = Do not pre-stage tools, 1 = Stage tools
use_gear : 0 #Output gear selection code, 0=no, 1=yes
max_speed : 10000 #Maximum spindle speed
你的arcoutput : 1 #0 = IJK, 1 = R no sign, 2 = R signed neg. over 180
应该是arcoutput : 2把它改为1试一下,再看一下有没有事。
[ 本帖最后由 cwandyk 于 2006-9-10 10:57 编辑 ] |
