[分享] PROE 配置文件大全 含详细说明[jpg]
发表于 2009-11-19 13:57:09 | 只看该作者
多谢了!楼主
32
发表于 2009-11-19 19:01:56 | 只看该作者
谢谢,学习学习
33
发表于 2009-11-19 20:28:06 | 只看该作者
下了 是我需要的 THANK  YOU
34
发表于 2009-11-19 22:12:24 | 只看该作者
感谢楼主~....
35
发表于 2009-11-20 14:42:42 | 只看该作者
非常感谢,楼主好人啊
36
发表于 2009-11-20 15:08:37 | 只看该作者
先看看,谢谢提供
37
发表于 2009-11-20 15:27:24 | 只看该作者
有没有什么特别的啊???
38
发表于 2009-11-20 15:29:12 | 只看该作者
proe3.0 config.pro
! Printing & Plotting
delete_after_plotting yes
plotter HP LaserJet 6L
plotter_command WINDOWS_PRINT_MANAGER
use_8_plotter_pens yes
pen1_line_weight 2
pen2_line_weight 1
pen4_line_weight 1
pen5_line_weight 1
pen6_line_weight 2
pen7_line_weight 2
pen8_line_weight 3
plot_linestyle_scale 1
plot_proceed_dialog yes
plot_to_scale_full_window yes
postscript_compression yes
raster_plot_dpi 300
use_software_linefonts yes
variable_plots_in_inches no
default_font 10,Tahoma,regular
dim_offscreen_limit 1
disp_trimetric_dwg_mode_view yes
intf_out_auto_layer_ids yes
use_temp_dir_for_inst yes
summary_help yes
start_appmgr yes
spin_with_part_entities yes
spin_control click
sketcher_undo_reorient_view yes
pro_dtl_setup_dir D:\money\dwg_detail_dir
pro_font_dir C:\WINDOWS\Fonts
pro_group_dir D:\money\udf_dir
pro_material_dir D:\money\material_dir
pro_mf_param_dir D:\money
pro_plot_config_dir D:\money\plotters
pro_symbol_dir D:\money\symbol_dir
pro_unit_mass unit_gram
relation_file_editor protab
search_path .\
shade_mfg_ref_models yes
sketcher_starts_in_2d yes
clock no
search_path ./
search_path ./locate_ring
search_path ./moldbase
search_path ./standard
search_path ./slide
search_path ./slide2
search_path ./slide3
search_path ./slide4
search_path ./up_slide_side
search_path ./up_ang_ej
search_path ./up_ang_ej2
search_path ./model
search_path ./st
!=== 'IGES' INTERFACE Setup ========
step_appearance_layers_groups YES
iges_out_jamais_compliant yes
intf3d_out_extend_surface no
!intf_out_as_bezier yes
proe_memory_buffer_size 0
dxf_export_mapping_file D:\money\dxf_export.pro
dxf_out_stroke_text yes
dwg_export_format 2000
iges_in_dwg_color yes
step_export_dwg_views as_3d_views_assoc_draft
display_axis_tags no
drawing_ole_image_dpi 300
drawing_shaded_view_dpi 300
use_part_color_for_hidden_lines yes
show_shaded_edges yes
hole_diameter_override yes
                           DIR Setup
pro_crosshatch_dir D:\money\crosshatch_dir
color_windows all_windows
drawing_setup_file D:\money\dwg_detail_dir\WEI.dtl
trail_dir D:\money\train
format_setup_file D:\money\format.dtl
file_open_default_folder working_directory
system_colors_file D:\money\syscol.scl
pro_colormap_path D:\money
intf3d_ug_install_dir C:\Program Files\UGS\NX 4.0
pro_library_dir D:\money\lkm-MOLD_BASE
mdl_tree_cfg_file D:\money\tree.cfg
pro_format_dir D:\money\format_dir
allow_old_style_round no
default_ext_ref_scope ALL
set_trail_single_step NO
open_simplified_rep_by_default NO
show_dim_sign no
bell NO
text_height_factor 30
allow_round_all yes
display hiddenvis
display_coordinate_sys no
enable_absolute_accuracy YES
grid_snap NO
menu_font 24, ARIAL, BOLD
menu_translation both
model_tree_start yes
orientation isometric
pro_unit_sys mmns
retain_display_memory no
spin_center_display yes
template_designasm mmns_asm_design.asm
template_mfgmold mmns_mfg_mold.mfg
template_sheetmetalpart mmns_part_sheetmetal.prt
template_solidpart D:\money\templates\mmns_part_solid.prt.4
prompt_on_erase_not_disp no
skeleton_model_default_color 9
dxfio_in_sjis yes
intf_out_layer none
enable_offset_fan_curve yes
enable_tree_indep yes
floating_layer_tree no
reserved_menu_space .3
new_parameter_ui yes
new_relation_ui yes
display_planes no
display_points no
display_coord_sys no
display_axes no
visible_message_lines 1
accuracy_lower_bound 0.0012
intf3d_in_close_open_boundaries yes
intf3d_in_enable_layer_join yes
all_tmp_rmv_srf_feat yes
allow_anatomic_features yes
display_plane_tags yes
default_abs_accuracy yes
fix_boundaries_on_import yes
section_color default
color yes
open_window_maximized yes
cri_grafting_enable yes
topobus_enable yes
diagram_pin_edit_multi_line yes
msg_translation yes
style_state_transparency 90
number_user_colors 50
shaded_postscript_background no
shade_surface_feat yes
hlr_for_quilts yes
sketcher_intent_manager yes
flip_arrow_scale 2
sim_pp_background_color proe
prev_proc_comp_def_color 12.50.30
dialog_translation yes
help_translation yes
mfg_xyz_num_digits 2
step_export_format AP203_IS
iges_out_dwg_color yes
iges_in_group_to_dwg_layer yes
iges_clip_view_ent yes
allow_solid_split no
auto_customize yes
intf3d_show_import_log no
allow_move_view_with_move yes
save_drawing_picture_file embed
tangent_edge_display dimmed
sketcher_disp_constraints no
fasthlr yes
shade_with curves
sketcher_animated_modify no
39
发表于 2009-11-20 15:30:06 | 只看该作者
以上是我自己用的CONFIG,PRO,KEY的就不上了!
40
发表于 2009-11-20 20:43:11 | 只看该作者
多谢了,下来学习下!
GMT+8, 2025-2-27 10:20 , Processed in 0.026350 second(s), 11 queries , Gzip On, Redis On.
