以下红色代码写入到config,按下“QQ”即时可退出几乎任何进行中命令
! The following mapkeys will enable "qq" to quit any command and bring you to the first menu.
! These mapkeys have been updated for Wildfire3.0 therefore 'qq' may not work to exit out of all menus.
mapkey qq1 #done/return;#done/return;#done/return;#done/return;
mapkey qq2 #return;#return;#return;#return;
mapkey qq3 #Done-return;#Done-return;#Done-return;#Done-return;
mapkey qq4 #Done sel;#Done sel;#Done sel;#done;#done;#done;#done;
mapkey qq5 #quit refs;#quit del/sup;#QUIT;
mapkey qq6 #done;#quit;#done;#quit;#confirm;#done/return;#done;#done;
mapkey qq7 #done;#quit;#confirm;#done/return;#done;#done;
mapkey qq8 ~ Activate `Odui_Dlg_01` `cancel`;~ Activate `0_std_confirm` `OK`;
mapkey qq9 ~ Enter `Odui_Dlg_00` `sel.selbut.additional_q#1`;\
mapkey(continued) ~ Exit `Odui_Dlg_00` `sel.selbut.additional_q#1`;\
mapkey(continued) ~ FocusIn `Odui_Dlg_00` `sel.selbut.parent_quilt#0`;\
mapkey(continued) ~ Activate `Odui_Dlg_00` `stdbtn_2`;~ Activate `0_std_confirm` `OK`;
mapkey qq @MAPKEY_LABELQuit Any Command;%qq1;%qq2;%qq3;%qq4;%qq5;%qq6;%qq7;%qq8;%qq9;
10. 打开IE的*.bat文件内容如下:(新建 Notepad 或 Wordpad 文件, 然后将扩展名改为 bat)
@echo off
REM Start Pro/E Central in IE
set C:\Program Files\Internet Explorer
start iexplore.exe %www.sohu.com
exit
11. 打开Excel的*.bat文件内容如下:(新建 Notepad or Wordpad 文件, 然后将扩展名改为 bat)
@echo off
REM Start Microsoft Excel Beam Calculations
set C:\Program Files\Microsoft Office\Office
start excel.exe %D:\Documents\beamcalc.xls
exit
! For complete descriptions see ==
! FUNDAMENTALS User Guide. ==
