查看: 17815|回复: 4
[求助] MPost中怎样把A(旋转轴)的值放到X值和Y值前面啊
发表于 2007-1-16 11:08:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
MPost中怎样把A(旋转轴)的值放到X值和Y值前面啊,我改了配置文件中的次序可没用,恳请各位指点。
发表于 2007-1-18 12:19:06 | 只看该作者
把你用的xxxxx.M4 貼上來, 偶幫你看看
发表于 2007-1-19 08:22:44 | 只看该作者
谢版大,如下:
name HAAS 4 axis (Metric)
% 00
/ 00
O >4
N >4
G >2
g >2 G
X ->4.>3
Y ->4.>3
Z ->4.>3
A ->4.>3 W Limit -8000 8000
I ->4.>3
J ->4.>3
K ->4.>3
Q ->4.>3
R ->4.>3
P >40
F >3.1
H >2
D >2
T >2
M >2
S >4
ModalLetters X Y Z F A
ModalGs 0 1 2 3 73 74 76 80 81 82 83 84 85
Sequence#s N 0 1 1
First#? N
Last#? N
HCode X
VCode Y
Dcode Z
FeedCode F
Comment ( )
Spindle 3 4 5
Coolant 8 9 7
DComp 41 42 40
LComp 43 49
Feed G<1>
Rapid G<0>
Cw G<2>
Ccw G<3>
Inc/Abs G 91 90
CtrCode I J
Helical? Y
Spaces? Y
Incremental? N
CtrIncremental? Y
ByQuadrants? N
UppercaseComments? Y
Drill                                 # Drilling canned/manual cycle
G81 X[H] Y[V] Z[D] R[Vclear] F[FRate]
end cancel
Peck                                  # Pecking canned/manual cycle
G83 X[H] Y[V] Z[D] Q[VBite] R[Vclear] F[FRate]
end cancel
Tap                                   # Tapping canned/manual cycle
G84 X[H] Y[V] Z[D] R[Vclear] F[Frate] Q[VBite]
end cancel
LTap                                  # Left handed tapping cycle
G74 X[H] Y[V] Z[D] R[Vclear] F[FRate]
end cancel
Ream                                  # Reaming canned/manual cycle
G85 X[H] Y[V] Z[D] R[Vclear] F[FRate]
end cancel
Bore                                  # Boring canned/manual cycle
G86 X[H] Y[V] Z[D] R[Vclear] F[FRate]
end cancel
Back                                  # Back boring canned/manual cycle
G87 X[H] Y[V] Z[D] R[Vclear] F[FRate]
end cancel
Cancel                                # Cancel a canned/manual cycle
G80
end
Index X                               # Index the rotary table
G0 G49 G90 Z0
G[Work] X[H] Y[V] A[Rotangle]
G43 Z[D] H[Lcomp] M[Cool]
End
UnWind                                # Unwind the rotary table
G0 G49 G90 Z0
A0
G0 X[LastH] Y[LastV] A[LastRotAng]
G1 Z[LastD]
End
StartCode                             # Start of the program
%0
O[Program#]
G90 G80 G40 G17
End
1stToolChange                         # First tool change
T[Tool] M6
M[Direct] S[Speed]
G0 G[Work] X[H] Y[V] A[Rotangle]
G43 Z[D] H[Lcomp]
M[Cool]
End
Infeed                                # Enable cutter comp
G[Side] X[H] Y[V] D[DComp] A[Rotangle] F[FRate]
end
Outfeed                               # Disable cutter comp
G1 G40 X[H] Y[V]
Z[D]
end
ToolChange                            # Secondary tool changes
G0 G49 Z0 M9
N[Block] T[Tool] M6
G0 G90 G[Work] X[H] Y[V] S[Speed] M[Direct] A[Rotangle]
End
EndCode                               # End of the program
G0 G49 G90 Z0 M9
G28 g91 Y0 Z0 A0
M30
%0
End
我想用HASS的改一下,我把边部分的输出次序改过但无作用。
发表于 2007-1-21 10:40:29 | 只看该作者
% 00
/ 00
O >4
N >4
G >2
g >2 G
A ->4.>3 W Limit -8000 8000   <-----------    移到 X  Y Z 前面
X ->4.>3
Y ->4.>3
Z ->4.>3
I ->4.>3
J ->4.>3
K ->4.>3
Q ->4.>3
R ->4.>3
P >40
F >3.1
H >2
D >2
T >2
M >2
S >4
发表于 2007-1-24 20:07:46 | 只看该作者
谢谢版大,已搞定.
GMT+8, 2025-4-26 20:15 , Processed in 0.021667 second(s), 10 queries , Gzip On, Redis On.
