查看: 16730|回复: 4
[求助] WARNING: The specified flow rate exceeds the
发表于 2007-3-29 14:48:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Residual Stress Analysis
analysis is beginning ....
  Filling phase:             Status: V  = Velocity control
                                     P  = Pressure control
                                     V/P= Velocity/pressure switch-over
|  Time  | Volume|  Pressure   | Clamp force|Flow rate|Ram Pos.| Status|
|  (s)   |  (%)  |    (MPa)    |  (tonne)   |(cm^3/s) |  (mm)  |       |
|   0.10 | 58.91 |       60.11 |       5.07 |  102.33 |   7.63 |   V   |
|   0.15 | 92.30 |    WARNING: The specified flow rate exceeds the
   maximum machine injection rate, using maximum machine injection rate|
|   0.15 | 92.30 |       75.57 |      10.52 |  108.75 |   5.00 |V/P by ram pos.|
|   0.16 |100.00 |       60.45 |      11.55 |   38.59 |        |Filled |
Filling phase results summary :
   Maximum injection pressure          (at   0.147 s) =     75.5678 MPa
End of filling phase results summary :
   Time at the end of filling                         =      0.1626 s
   Total weight                                       =     13.7057 g
   Maximum Clamp force - during filling               =     11.5500 tonne
提示超出了机器的最大注射率该怎么办?filling control 是由Ram speed profile 控制的
 楼主| 发表于 2007-3-29 14:53:34 | 只看该作者
发表于 2007-3-29 21:25:36 | 只看该作者
发表于 2007-3-29 22:14:55 | 只看该作者
发表于 2008-10-29 17:05:48 | 只看该作者
GMT+8, 2024-11-27 14:28 , Processed in 0.028375 second(s), 11 queries , Gzip On, Redis On.
© 2002-2024 www.iCAx.org
