标题: 【求助】CATIA与UG之间的数据如何转换?能不能保留特征? [打印本页]
作者: inta    时间: 2002-4-21 10:30
不要说用igs哦。。。
作者: idesign    时间: 2002-4-21 11:45
特征可能不行吧,不过UG19增加了直接输入V4的MODEL,没有用过,不知道效果怎样?!
作者: inta    时间: 2002-4-21 19:53
thxs ,let me try ...
作者: fatdong    时间: 2002-4-25 09:59
As far as I know, It is impossible to keep all the features when the model is transferred from CATIA to UG, or from UG to CATIA.
From the view of point of engineering, the interface of data exchange in those large CAD/CAM softwares is not as good as we expect. Generally, the geometric shape of solid model could be hept. However, this condition, sometimes, doesn't happen to the surface, especially to complex surface model.
Good luck to you.
作者: huli37    时间: 2002-5-1 22:07
上头的写得太复杂
作者: m568382251    时间: 2010-7-24 10:05
呵呵 各位太有才了啊
作者: g466312005    时间: 2011-7-17 19:58
目前还是不能完成的一项任务,ug和catia。pooe    等软件的内核不是一样,特征是转换不了的 ,就算转换了,结果也会因为运算方式不一样而导致结果变化
