【分享】日积月累话说pro\e有关配置参数秘笈
发表于 2002-10-26 14:33:22 | 只看该作者
如何设置CONFIG.PROE。以便在PROE2001之装配图中之装配单位为“MM”。我的CONFIG.PRO是PROE200I改的,在2000I中没有以上烦恼,我已
想过很多方法,终归失败。谁能赐教。
112
发表于 2002-10-26 15:36:24 | 只看该作者
已找到QWX99先生4月23日贴。谢谢!
113
发表于 2002-11-5 12:21:08 | 只看该作者
说明:下面是工程图配置文件的一个例子,我发现,它还是比较符合我们的国家标准。
! ! These options control text not subject to other options !
drawing_text_height 3.500000
text_thickness 0
text_width_factor 0.850000
! ! These options control views and their annotations !
broken_view_offset 5.000000
create_area_unfold_segmented YES
def_view_text_height 3.5
def_view_text_thickness 0.000000
detail_circle_line_style PHANTOMFONT
detail_view_circle ON half_view_line SYMMETRY
projection_type FIRST_ANGLE
show_total_unfold_seam YES
view_note std_din view_scale_denominator 1
view_scale_format ratio_colon
! ! These options control cross sections and their arrows !
crossec_arrow_length 5
crossec_arrow_style HEAD_ONLINE
crossec_arrow_width 2
crossec_text_place ABOVE_TAIL
cutting_line STD_ISO
cutting_line_adapt NO
cutting_line_segment 6
draw_cosms_in_area_xsec NO
remove_cosms_from_xsecs TOTAL
! ! These options control solids shown in views !
datum_point_size 8.000000
datum_point_shape CROSS
hlr_for_pipe_solid_cl NO
hlr_for_threads YES
location_radius DEFAULT(2.)
mesh_surface_lines OFF
thread_standard STD_ISO
hidden_tangent_edges DEFAULT
ref_des_display NO
! ! These options control dimensions
allow_3d_dimensions YES
angdim_text_orientation HORIZONTAL
associative_dimensioning YES
blank_zero_tolerance yes
chamfer_45deg_leader_style STD_ISO
clip_dimensions YES
clip_dim_arrow_style NONE
default_dim_elbows YES
dim_leader_length 5.000000
dim_text_gap 1.300000
draft_scale 1.000000
draw_ang_units ANG_DEG
draw_ang_unit_trail_zeros YES
dual_digits_diff 1
dual_dimension_brackets YES
dual_dimensioning NO
dual_secondary_units INCH
iso_ordinate_delta YES
lead_trail_zeros STD_METRIC
ord_dim_standard STD_ISO
orddim_text_orientation PARALLEL
parallel_dim_placement ABOVE
shrinkage_value_display PERCENT_SHRINK
text_orientation PARALLEL_DIAM_HORIZ
tol_display no tol_text_height_factor 0.600000
tol_text_width_factor 0.600000
witness_line_delta 1.500000
witness_line_offset 1.000000
! ! These options control text and line fonts !
default_font font
aux_font 1 filled
aux_font 2 leroy
aux_font 3 cal_alf
aux_font 4 cal_grek
aux_font 5 font3d
! ! These options control leaders !
draw_arrow_length 3.500000
draw_arrow_style FILLED
dim_dot_box_style DEFAULT
draw_arrow_width 1.500000
draw_sym_height DEFAULT
draw_sym_width DEFAULT
draw_dot_diameter 1.000000
leader_elbow_length 6.000000
! ! These options control axes !
axis_interior_clipping NO
axis_line_offset 5.000000
circle_axis_offset 4.000000
radial_pattern_axis_circle YES
! ! These options control geometric tolerancing information !
gtol_datums STD_ISO_JIS
gtol_dim_placement ON_BOTTOM
new_iso_set_datums YES
asme_dtm_on_dia_dim_gtol ON_GTOL
! ! These options control tables, repeat regions, and BOM balloons !
dash_supp_dims_in_region YES
def_bom_balloon_leader_sym filled_dot
model_digits_in_region NO
show_cbl_term_in_region YES
! ! These options control layers !
draw_layer_overrides_model NO
ignore_model_layer_status YES
! ! These options control model grids !
model_grid_balloon_size 4.000000
model_grid_neg_prefix -
model_grid_num_dig_display 0
model_grid_offset DEFAULT
! ! These options control theoretical piping bend intersection !
show_pipe_theor_cl_pts BEND_CL
pipe_pt_shape CROSS pipe_pt_size DEFAULT
! ! Miscellaneous options !
decimal_marker COMMA_FOR_METRIC_DUAL
drawing_units MM
line_style_standard STD_ANSI
max_balloon_radius 0.000000
min_balloon_radius 0.000000
node_radius DEFAULT
sym_flip_rotated_text NO
weld_symbol_standard STD_ISO y
es_no_parameter_display TRUE_FALSE
default_pipe_bend_note NO
114
发表于 2002-11-5 13:50:43 | 只看该作者
非常好的方法,以后请您多多的指教。早进先为师吗?我是PRO/E的初学者您可以把您学习它的一些经验传授给一个初学的迷茫者吗?对您表示中心的感谢!!!!!
115
发表于 2002-11-5 22:44:28 | 只看该作者
感谢cowboycn兄,你回答那位兄弟的问题,正是我好久以来没搞清处,确是值得我们这些初学者一看,并强烈感谢!
116
发表于 2002-11-6 10:54:49 | 只看该作者
请教一下,我本来装的中文版,装好之后是中文,可我想改成双语的,就把MENU_TRANSLATION改成BOTH了,现在倒好,只有英文了,改成哪个都没用了。怎么办?
117
发表于 2002-11-8 21:14:13 | 只看该作者
我也有,但不好用,能不能看看你的有什么不同?
jie@upm-products.com.hk
thanks a lot!
118
发表于 2002-11-14 11:28:37 | 只看该作者
我來給一些, 只要給點分我,
119
发表于 2002-11-14 11:29:41 | 只看该作者
只要點分我, 我發上去
120
发表于 2002-11-14 11:32:28 | 只看该作者
关于配置文件选项
为配置文件输入所需的设置,可以预设环境选项和其它全局设置。要设置配置文件选项,使用“选项”对话框(“实用工具”>“选项”)。
本帮助模块含有一个按字母顺序显示每一选项或相关选项组的配置选项列表:
[$#8226]配置选项名称。
[$#8226]相关变量或值。选项的缺省值显示为斜体。
[$#8226]简单说明。
accuracy_lower_bound         数值(在1.0e-6和1.0e-4之间)
输入一个精确值来覆盖缺省下限0.0001。上限固定为0.01
add_java_class_path            <搜索路径>
此选项涉及到有关JAVA环境变量CLASSPATH的选项值,它用于查找J-Link程序中使用的类。可在同一行上指定多个搜索路径,在UNIX中用“:”隔开,在Windows NT中用“;”隔开。设定此选项后,启动第一个J-Link应用程序时才会生效
add_weld_mp         yes, no
yes - 系统在计算质量属性时,包括焊接。
no - 系统在计算质量属性时,排除焊缝。
allow_anatomic_features          yes, no
将此配置文件现象设置为yes,使得下列选项可用:
“扭曲”菜单中:“局部拉伸”、“半径圆顶”、“截面圆盖”、“耳”、“唇”。
“实体”菜单中:“开槽”、“轴肩”、“凸缘”、“ 退刀槽”。
“基准”菜单中:“计算”。
allow_cycle_optimize            yes, no
在18.0以前的版本中,有一个孔加工序列参数,允许用户优化孔加工序列CL-数据的循环输出。自版本18.0以来,该参数不再有效。
yes - 使该参数在序列中可见
no - 该参数在序列中不可见
allow_move_in_dtl_move          yes, no
确定绘图模式中的“移动”和“移动附属”命令是 (yes) 否 (no) 一起执行
allow_move_view_with_move                yes, no
设置为“yes”时,可以使用“绘图”模式中的“移动”命令,移动绘图视图。
allow_old_style_round              yes, no
确定系统使用哪一个倒圆角创建功能。
yes - 使用旧(版本16.0)功能。
no - 使用新功能。
allow_package_children                all, feature, none
设定参照包装元件的特征的允许度。设定此选项后,即可在当前的Pro/ENGINEER进程中立即生效。
all - 允许使用特征和元件两者的放置参照
feature - 仅允许使用几何特征参照
none - 禁用特征和元件的放置参照
allow_ply_cross_section        yes, no
yes - 允许Pro/COMPOSITE创建一个复合摺的横截面。
allow_redo_intersections         yes, no
yes - 显示“装配特征”菜单中的“重新求交”命令。
allow_ref_scope_change          yes, no
no - 当“参照范围”用户界面改变时,显示消息“配置文件设置禁止参照范围的变化”。
GMT+8, 2025-4-30 02:51 , Processed in 0.024096 second(s), 10 queries , Gzip On, Redis On.
