[推荐] hyperMILL后处理的用户化修改
发表于 2009-5-18 14:56:10 | 只看该作者
谢谢谢谢
22
发表于 2009-11-22 11:11:49 | 只看该作者
oma文件  怎么打开
23
发表于 2010-5-4 12:59:17 | 只看该作者
黄瓜 发表于 2007-8-27 16:48
hyperMILL提供了可供用户自己修改格式的后处理,一般情况下OM提供给用户的后处理包含两个文件(.def文件和.oma文件)
请问哪里有下载的
24
发表于 2010-5-5 16:10:07 | 只看该作者
路过,顶...
25
发表于 2010-5-6 21:28:45 | 只看该作者
def是在hypermill裹面作一些對應机台的修改,例如換刀點
工作座標.....
oma及omf則是需要post處理器,2009.2版沒有看到,2007版就有
只要有原廠的說明文件,就可以編修出各种机型的後處理了
omf可以產生各种oma,而oma只能修改,所以omf比較少見
原廠跟本就不肯給
   " --- common ---" := "S: "
   " --- output ---" := "S: "
   "blockNumber" := "I:1"
   "number" := "S%06ld"
   "workoffset" := "S:G54"
   "file_start_sign" := "S:%"
   "freeStartNC1" := "S17"
   "freeStartNC2" := "S:-1"
   "file_start" := "S:-"
   "freeEndNC1" := "S16"
   "freeEndNC2" := "S:M09"
   "freeEndNC3" := "S:G92"
   "freeEndNC4" := "SQ000011)"
   "freeEndNC5" := "S:M5"
   "file_end" := "S:-"
   "file_end_sign" := "S:-"
   "final_M" := "S:M30"
   "rotary_axes_unclamp" := "S:-"
   "rotary_axes_clamp" := "S:-"
   "tcpm_ON" := "S:G182"
   "tcpm_OFF" := "S:G180"
   "rotary_axes_modal" := "I:1"
   " --- tool ---" := "S: "
   "Tcomment_mode" := "I:14"
   "freeStartTC1" := "S16"
   "file_TC_start" := "S:tc.txt"
   "freeEndTC1" := "S:-1"
   "file_TC_end" := "S:-"
   "M5_TC" := "I:0"
   "M9_TC" := "I:0"
   "toollength_comp_on" := "S:-"
   "toollength_comp_T" := "S:H%ld"
   "toollength_comp_off" := "S:-"
   "coolant_1" := "S:M08"
   "coolant_2" := "S:M12"
   "coolant_1_and_2" := "S:M10"
   " --- 2D ---" := "S: "
   "toolradius_comp_T" := "S:-"
   " --- cycles ---" := "S: "
   " --- safety ---" := "S: "
   "sP_before_TC" := "I:1"
   "sP_1st_move" := "I:1"
   "sP_end_of_file" := "I:1"
   "sP_file" := "S:sP.txt"
   " --- min/max ---" := "S: "
   "B_minimum" := "F:-30.0"
   "B_maximum" := "F:30.0"
   " --- 5th ---" := "S: "
   " --- 5X ---" := "S: "
   " --- specials ---" := "S: "
   "arc_tolerance" := "F:0.025"
   " --- VM settings ---" := "S: "
   "A_direction" := "F:1.0"
   "B_direction" := "F:1.0"
   "A_offset" := "F:-90.0"
26
发表于 2010-6-2 17:11:59 | 只看该作者
都是高手啊
27
发表于 2010-10-17 13:13:38 | 只看该作者
顶顶
28
发表于 2011-9-12 19:01:07 | 只看该作者
如何产生oma呢
29
发表于 2011-10-12 23:51:12 | 只看该作者
版主能分享一个带机床的后处理吗
30
发表于 2011-11-6 10:20:25 | 只看该作者
五轴的后处理会改吗,麻烦斑竹看一下,我们讨论一下。
邮箱:LSP331@163.com
GMT+8, 2025-10-16 18:01 , Processed in 0.057687 second(s), 15 queries , Gzip On, Redis On.
