查看: 15988|回复: 3
[求助] 版主帮帮忙!!!!
发表于 2007-11-1 11:06:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我做四轴的,我以前都用台湾的软件,我现在想用Cimatron可是后处理不出来,后来我弄了个MPFAN.PST文件,不知道有没有用而且不知道怎么弄进去才能后处理,帮我看下是不是这个文件:
# Post Name           : MPFAN
# Product             : MILL
# Machine Name        : GENERIC FANUC
# Control Name        : GENERIC FANUC
# Description         : GENERIC FANUC MILL POST
# Associated Post     : NONE
# Mill/Turn           : NO
# 4-axis/Axis subs.   : YES
# 5-axis              : NO
# Subprograms         : YES
# Executable          : MP 8.00
# WARNING: THIS POST IS GENERIC AND IS INTENDED FOR MODIFICATION TO
# THE MACHINE TOOL REQUIREMENTS AND PERSONAL PREFERENCE.
# Revision log:
# Programmers Note:
# CNC 01/27/00  -  Initial post setup, don
# Features:
# This post supports Generic Fanuc code output for 3 and 4 axis milling.
# It is designed to support the features of MasterCAM Mill V8.
# Following Misc. Integers are used:
# mi1 - Work coordinate system
#        0 = Reference return is generated and G92 with the
#            X, Y and Z home positions at file head.
#        1 = Reference return is generated and G92 with the
#            X, Y and Z home positions at each tool.
#        2 = WCS of G54, G55.... based on Mastercam settings.
# mi2 - Absolute or Incremental positioning at top level
#        0 = absolute
#        1 = incremental
# mi3 - Select G28 or G30 reference point return.
#        0 = G28, 1 = G30
#Canned text:
#    Entering cantext on a contour point from within Mastercam allows the
#    following functions to enable/disable.
#    Cantext value:
#    1 = Stop = output the "M00" stop code
#    2 = Ostop =  output the "M01" optional stop code
#    3 = Bld on = turn on block delete codes in NC lines
#    4 = bLd off = turn off block delete codes in NC lines
#Milling toolpaths (4 axis)
#Layout:
# The term "Reference View" refers to the coordinate system associated
# with the Top view (Alt-F9, the upper gnomon of the three displayed).
# Create the part drawing with the axis of rotation about the axis
# of the "Reference View" according to the setting you entered for
# 'vmc' (vertical or horizontal) and 'rot_on_x' (machine relative
# axis of rotation).
# vmc = 1 (vertical machine) uses the top toolplane as the base machine
# view.
# vmc = 0 (horizontal machine) uses the front toolplane as the base machine
# view.
# Relative to the machine matrix -
# Rotation zero position is on the Z axis for rotation on X axis.
# Rotation zero position is on the Z axis for rotation on Y axis.
# Rotation zero position is on the X axis for rotation on Z axis.
# The machine view rotated about the selected axis as a "single axis
# rotation" are the only legal views for 4 axis milling.  Rotation
# direction around the part is positive in the CCW direction when
# viewed from the plus direction of the rotating axis.  Set the variable
# 'rot_ccw_pos' to indicate the signed direction.  Always set the work
# origin at the center of rotation.
#Toolplane Positioning:
# Create the Cplane and Tplane as the rotation of the machine view about
# the selected axis of rotation.  The toolplane is used to calculate
# the position of the rotary axis.  This is the default setting.
#3 Axis Rotary (Polar)
# Polar positioning is offered in Mastercam 3 axis toolpaths through the
# rotary axis options dialog.  The selected toolpath is converted to angle
# and radius position.  The axis of rotation is forced to zero.
#Axis substitution:
# Use the Rotary axis substitution by drawing the geometry flattened
# from the cylinder.  The rotary axis button must be active for axis
# substitution information to be output to the NCI file. The radius of
# the rotary diameter is added to all the Z positions at output.
#Simultaneous 4 Axis (11 gcode):
# Full 4 axis toolpaths can be generated from various toolpaths under the
# 'multi-axis' selection (i.e. Rotary 4 axis). All 5 axis paths are
# converted to 4 axis paths where only the angle about the rotation axis
# is resolved.
#Drill:
# All drill methods are supported in the post.  See Simultaneous 4 Axis.
#Additional Notes:
# 1) Disable 4 axis by setting the numbered question 164. to 'n'.
# 2) G54 calls are generated where the work offset entry of 0 = G54,
#    1 = G55, etc.
# 3) Metric is applied from the NCI met_tool variable.
# 4) Incremental mode calculates motion from home position at toolchanges.
#    The home position is used to define the last position of the tool
#    for all toolchanges.
# 5) The variable 'absinc' is now pre-defined, set mi2 (Misc. Integer) for
#    the 'top level' absolute/incremental program output.  Subprograms are
#    updated through the Mastercam dialog settings for sub-programs.
# 6) Always avoid machining to the center of rotation with rotary axis!
# 7) Transform subprograms are intended for use with G54.. workshifts.
# Debugging and Factory Set Program Switches
m_one       : -1    #Define constant
zero        : 0     #Define constant
one         : 1     #Define constant
two         : 2     #Define constant
three       : 3     #Define constant
four        : 4     #Define constant
five        : 5     #Define constant
c9k         : 9999  #Define constant
恳求帮忙!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
发表于 2007-11-1 11:16:53 | 只看该作者
mastercam和cimatron的后处理是不同用的
发表于 2007-11-1 12:28:05 | 只看该作者
哦,我这个是mastercam的?那该怎么办才可以用cimatron编四轴,还得麻烦版主指导指导!!!
发表于 2007-11-1 12:30:53 | 只看该作者
那该怎样才可以用cimatron编四轴?还得版主指导制导!!!真不好意思麻烦你这么多
GMT+8, 2025-2-28 03:09 , Processed in 0.023355 second(s), 10 queries , Gzip On, Redis On.
