查看: 24536|回复: 16
【分享】Post Builder 變數一覽
发表于 2003-5-9 22:03:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
相信論壇上許多人對PostBuilder中到底有哪些變數可以引用而傷腦筋,現在3.0的版本終於列出變數表了,雖然還不是很詳盡,總是聊勝於無:I:I
发表于 2003-5-10 01:33:42 | 只看该作者
搭YEAGER兄的便车,我来给一些解析,英文的,不懂的提出来,能回答的就回答,不能回答的大家来共同研究!
This section describes miscellaneous parameters that are applicable to all event types.
mom_cutting_time
Actual cutting time till the current event in minutes.
Default is 0.
mom_date
The current date. This variable is loaded before any events are called.
mom_definition_file_name
The name of the current definition file. This variable is loaded before any events are called.
mom_event_handler_file_name
The name of the current event handler. This variable is loaded before any events are called.
mom_event_time
Total time required for the current event in minutes.
Default is 0.
mom_logname
The login name of the person running Unigraphics NX. This variable is loaded before any events are called.
mom_machine_name
MACHINE <name> is present in the Definition File. This variable is <name> of the primary Definition File. This variable is loaded before any events are called.
mom_machine_time
Total time required till the current event in minutes.
Default is 0.
mom_output_file_basename
The name of the output file without the path. This variable is loaded before any events are called.
mom_output_file_directory
The name of the directory where the output file is located. This variable is loaded before any events are called.
mom_output_file_suffix
The output file extension following the last "."
(i.e., ptp). This variable is loaded before any events are called.
mom_part_name
The name of the current part. This variable is loaded before any events are called.
mom_source_directory
The name of the directory where the event handler is located. 'Source'd files should probably reside in the same directory. This variable is loaded before any events are called.
mom_tool_count
Count of the tools used till the current event.
Default is 0.
mom_tool_use
tool_number, tool_usage_time (in minutes) couplets:
  Tool usage till the
Tool Number
  current event
mom_tool_use(0,0)
  mom_tool_use(0,1)
mom_tool_use(1,0)
  mom_tool_use(1,1)
mom_tool_use(n-1,0)
  mom_tool_use(n-1,1)
where n is the mom_tool_count
发表于 2003-5-10 01:42:33 | 只看该作者
mom_lathe_spindle_axis
The axis of the lathe (TLDATA parameter).
Values:
  MCSX (default)
  MCSY
mom_next_tool_status
The status of the next tool used in the task.
Values:
  NEXT (there is a next tool available)
  FIRST (there is no next tool available)
mom_operation_type
The type of machining operation.
Values:
  PLANAR_MILL
  POCKET_PROFILE
  SURFACE_MILLING
  FIX_CONTOUR
  VAR_CONTOUR
  GSSM
  PARAMETER_LINE
  ZIG_ZAG_SURFACE
  ROUGH_TO_DEPTH
  CAVITY_MILL
  LATHE
  LATHE_ROUGH
  LATHE_FINISH
  LATHE_GROOVE
  LATHE_THREAD
  LATHE_DRILL
  LATHE_FACE
  BASIC_MACHINING
  POINT_TO_POINT
  SEQ_CURVE_MILL
  LATHE_DRIVE_CURVE
  SHEET_METAL
  NESTING
  FLAT_PATTERNS
  PUNCH_PRESS
  PCB
  WEDM
  ORPHAN
  PLOP
  MILL_MACHINE_CONTROL
  LATHE_MACHINE_CONTROL
  WEDM_MACHINE_CONTROL
  MILL_USER
  LATHE_USER
  WEDM_USER
  UNDEFINED (default)
mom_tool_insert_width
Thread tool insert width.
Default is 0.0.
mom_tool_tip_offset
Thread tool insert tip offset.
Default is 0.0.
mom_tool_x_imaginery_offset
Imaginery tool tip xoffset.
Default is 0.0.
mom_tool_z_imaginery_offset
Imaginery tool tip zoffset.
Default is 0.0.
mom_path_name
The name of the current path.
mom_tool_name
The name of the current tool.
mom_tool_number
The number of the current tool.
mom_tool_adjust_register
The number of the current tool's adjust register.
mom_tool_type
The type of machining tool (TLDATA parameter).
Values:
  MILL
  DRILL
  TURN
  GROOVE
  THREAD
  WEDM
  BARREL
  TCUTTER
mom_tool_parameter_count
The number of parameters used to define the tool.
Default = 5
mom_tool_diameter
The diameter of the tool.
Default = 0.0
mom_tool_corner1_radius
The lower corner radius of the tool.
Default = 0.0
mom_tool_equipment
Type of machine used for the current operation.
Values:
  MILL
  LATHE
mom_tool_shape
Tool shapes applicable to turning operations.
Values:
  STANDARD
  BUTTON
  BORING_BAR
  RING
  BUTTRESS
  ACME
mom_tool_gage_length
The gage length of the tool.
Default = 0.0
mom_tool_taper_angle
The taper angle of the tool.
Default = 0.0
mom_tool_tip_angle
The tip angle of the tool.
Default = 0.0
mom_tool_corner1_x
The first component of the center of the arc repesenting the lower corner radius of the tool.
Default = 0.0
mom_tool_corner1_y
The second component of the center of the arc repesenting the lower corner radius of the tool.
Default = 0.0
mom_tool_flute_length
The flute length of the tool.
Default = 0.0
mom_tool_corner2_radius
The upper corner radius of the tool.
Default = 0.0
mom_tool_corner2_x
The first component of the center of the arc repesenting the upper corner radius of the tool.
Default = 0.0
mom_tool_corner2_y
The second component of the center of the arc repesenting the upper corner radius of the tool.
Default = 0.0
mom_tool_holder_width
The width of the tool holder plus the insert.
Default = 0.0
mom_tool_lead_angle
The angle of the leading edge of the cutting insert.
Default = 0.0
mom_tool_heel_angle
The angle of the trailing edge of the cutting insert.
Default = 0.0
mom_tool_holder_height
The holder height (TLDATA parameter).
Default = 0.0
mom_tool_orient_angle
The orientation of the tool holder with respect to the turning axis.
Default = 0.0
The width of the tool insert.
Default = 0.0
mom_tool_left_radius
The left corner radius of the tool insert.
Default = 0.0
mom_tool_right_radius
The right corner radius of the tool insert.
Default = 0.0
mom_tool_max_depth
The maximum depth that a grooving tool can cut into the part.
Default = 0.0
mom_tool_insert_angle
The orientation of the insert with respect to the tool holder.
Default = 0.0
mom_wire_guides_upper_plane
The upper plane for wire EDM.
Default = 0.0
mom_wire_guides_lower_plane
The lower plane for wire EDM.
Default = 0.0
mom_tool_barrel_radius
The radius of the arc defining the profile shape of the sides of a barrel cutter.
Default = 0.0
mom_tool_barrel_y
The height of the center of the arc defining the profile of the outside edge of a barrel cutter.
Default = 0.0
mom_tool_shank_diameter
The diameter of the shank at the top of a barrel cutter.
Default = 0.0
mom_tool_orientation
The turning tool orientation.
Values:
  LEFT
  RIGHT
mom_tool_work_side
The cutting side for the turning tool.
Values:
  INSIDE
  OUTSIDE
mom_tool_track_side
The tracking side for the grooving tool.
Values:
  LEFT
  CENTER
  RIGHT
mom_paint_arrow
Value:
  TRUE
  FALSE
mom_paint_feed
Value:
  TRUE
  FALSE
mom_paint_line_number
Value:
  TRUE
  FALSE
mom_paint_path_type
Values:
  SOLID
  DASHED
  SILHOUTTE_WITH_TOOL_AXIS
  SILHOUTTE_WITH_SILHOUTTE_NORMAL
  NONE
mom_paint_pattern
Value:
  TRUE
  FALSE
mom_paint_silhoutte_percentage
mom_paint_speed
Value:
  TRUE
  FALSE
mom_paint_speed_value
mom_paint_tool
Values:
  NONE
  2D
  3D
mom_tool_display_type
Values:
  TOOL_AXIS
  TWO_DIMENSIONAL
  THREE_DIMENSIONAL
mom_tool_display_frequency
发表于 2003-5-10 23:32:33 | 只看该作者
内容已经被删除!
发表于 2003-5-11 10:52:26 | 只看该作者
xianglong wrote:
::6::6::6
发表于 2003-5-11 10:53:11 | 只看该作者
  mom_cutting_time
  Default is 0.
  mom_date
  mom_event_time
  Default is 0.
  mom_logname
  mom_machine_name
  mom_machine_time
  Default is 0.
  mom_part_name
  mom_tool_count
  Default is 0.
  mom_tool_use
  Tool usage till the
  Tool Number
  current event
  mom_tool_use(0,0)
  mom_tool_use(0,1)
  mom_tool_use(1,0)
  mom_tool_use(1,1)
  mom_tool_use(n-1,0)
  mom_tool_use(n-1,1)
::y::y::K::K
发表于 2003-5-12 06:30:47 | 只看该作者
flash_star兄真是有心人啊!!呵呵.....
发表于 2003-5-14 22:46:46 | 只看该作者
大家打开.tcl文件可能已经注意到有以MOM_开头的KEYWORD也有mom_开头的,不知大家是否知道两者的区别?
MOM开头是过程,相当于子程序;
mom开头的则是变量;
发表于 2003-5-15 08:49:47 | 只看该作者
谢谢!
发表于 2003-5-24 10:52:13 | 只看该作者
刚开始UG的CAM很莱,目前还在用MASTERCAM,不懂后处理怎么做,可不可以E一个后处理给偶,EMAIL—zsifan@sina.com...多多谢!!!!
GMT+8, 2025-2-24 07:41 , Processed in 0.026291 second(s), 11 queries , Gzip On, Redis On.
