我知道是什么问题
源文件发给你们
你们自己改吧
$$2D来回走刀$$
entity/obj,li(1000),pt,lo
number/XTRANS(12),di(2,1000,3),DP(3,3)
$$STRING/
q1=0.15
q2=1
n10:
mask/3,5,6,9
ident/'#风中残烛#提醒你:选择曲线',li,cnt,n,rsp
jump/n10:,trm:,,,rsp
n20:
PARAM/'#风中残烛#提醒你:输入参数',$
'吃刀深度...',q1,$
'偏置距离...',q2,$
altact,'==程式说明==',$
RSP
jump/n10:,trm:,,ZHONG2:,rsp
if/q2==0,jump/zhong1:
if/absf(q1)>absf(q2),Q1=Q2
mo=modf(absf(q2),absf(q1) ) $$最后一刀
$$print/mo
mn=(absf(q2)-mo)/absf(q1) $$次数
$$print/mn
if/n==1,obj = li(1)
if/n>1,obj = GROUP/li(1..n)
dO/n21:,i,1,n
di(1,i,1..3)=&Spoint(li(i)) $$开始点
di(2,i,1..3)=&epoint(li(i) ) $$结束点
n21:
k=0
dO/n22:,i,1,n
dO/n221:,M,1,n
ifthen/di(1,I,1..3)==di(2,M,1..3)
jump/n22:
endif
n221:
dO/n222:,M,1,n
ifthen/di(1,I,1..3)==di(1,M,1..3) AND m<>i
jump/n22:
endif
n222:
K=K+1
DP(K,1..3)=di(1,I,1..3)
if/k==3,jump/zhong:
n22:
dO/n23:,i,1,n
dO/n231:,M,1,n
ifthen/di(2,I,1..3)==di(1,M,1..3)
jump/n23:
endif
n231:
dO/n232:,M,1,n
ifthen/di(2,I,1..3)==di(2,M,1..3) AND m<>i
jump/n23:
endif
n232:
K=K+1
DP(K,1..3)=di(2,I,1..3)
if/k==3,jump/zhong:
n23:
$$print/dp
$$转向$$
if/q2<0,jump/n40:
XTRANS=MATRIX/TRANSL,0,0,absf(q1)
do/n30:,i,1,mn
obj=transf/XTRANS,obj
ifthen/ modf(i,2)==0
lo=LINE/DP(1,1..2),dp(1,3)-absf(q1)+absf(q1)*i$
, DP(1,1..2),dp(1,3)+absf(q1)*i
else
lo=LINE/DP(2,1..2),dp(2,3)-absf(q1)+absf(q1)*i$
, DP(2,1..2),dp(2,3)+absf(q1)*i
endif
n30:
ifthen/mo>0
XTRANS=MATRIX/TRANSL,0,0,mo
$$print/i
ifthen/ modf(mn,2)==1
lo=LINE/DP(1,1..2),dp(1,3)+absf(q1)*i$
, DP(1,1..2),dp(1,3)+absf(q1)*i+mo
else
lo=LINE/DP(2,1..2),dp(2,3)+absf(q1)*i$
, DP(2,1..2),dp(2,3)+absf(q1)*i+mo
endif
endif
jump/trm:
n40:
XTRANS=MATRIX/TRANSL,0,0,-absf(q1)
do/n50:,i,1,mn
lo=LINE/DP(1,1..2),dp(1,3)+absf(q1)-absf(q1)*i$
, DP(1,1..2),dp(1,3)-absf(q1)*i
else
lo=LINE/DP(2,1..2),dp(2,3)+absf(q1)-absf(q1)*i$
, DP(2,1..2),dp(2,3)-absf(q1)*i
endif
n50:
ifthen/mo>0
XTRANS=MATRIX/TRANSL,0,0,-mo
$$print/i
lo=LINE/DP(1,1..2),dp(1,3)-absf(q1)*i$
, DP(1,1..2),dp(1,3)-absf(q1)*i-mo
else
lo=LINE/DP(2,1..2),dp(2,3)-absf(q1)*i$
, DP(2,1..2),dp(2,3)-absf(q1)*i-mo
endif
endif
jump/trm:
trm:
halt
ZHONG:
messg/'所选曲线有间隙...','请重新选择'
jump/n10:
ZHONG1:
messg/'无效深度...','请重新输入'
jump/n20:
ZHONG2:
print/'2D来回走辅助线'
print/''
print/'本程式由风中残烛编写'
print/'使用上有任何问题请与我联系!'
print/'Email: ZHONG.2@126.COM QQ: 52290025'
print/'声明:'
print/'本人外挂免费无限制提供,并不对程式使用造成任何损失负责!'
print/'未经本人允许,本外挂可随便传播,但不得用于商业用途!'
print/'如果你对外挂整合出售,请在外挂功能提示上注明风中残烛XXX'
print/'且不加收取任何费用!'
print/''
print/'使用帮助:'
print/''
print/'本程式只对坐标Z轴向有效!'
print/'本程式只生成线并不是刀路'
print/'如果你要生成刀路请结合光面的走曲线功能进行使用!'
print/'如果你熟悉宏和刀路模版,可以用宏调用本程式一次生成刀路'
print/'如果你对CLSF有兴趣且熟悉二次开发的话也可开发成直接生成刀路'
print/''
print/''
print/''
print/' 2008-3-7 风中残烛 '
print/''
print/''
print/''
print/''
print/''
print/''
jump/n20: |
